Gains switching to larger intake valve #468391
09/14/09 10:13 PM
09/14/09 10:13 PM
New Braunfels, TX
416challenger Online content OP
416challenger  Online Content OP
New Braunfels, TX
I will be freshening up my motor after this season and I was considering going from a 2.02 valve to a 2.05. What kind of gains if any can be had? The heads are Edelbrock RPM that flow the as followed-
Intake Exhaust
.100" 82.8 N/A
.200" 149.0 112.1
.300" 211.2 169.3
.400" 255.6 203.2
.450" 269.4 218.0
.500" 276.3 226.0
.550" 281.5 229.8
.600" 284.6 231.2
.650" 284.6 231.5
.700" 284.6 232.9
The cam is 262in 268ex @.050 w/ 675" lift. I would like to run 7.00 in the heat, I normally run around 7.09 @ 3800 da. Has anyone made a similar change, if so what kind of results?
Re: Gains switching to larger intake valve [Re: 416challenger] #468392
09/14/09 10:19 PM
09/14/09 10:19 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Depends on the port.Simply installing a larger valve in the same port often won't help.
Re: Gains switching to larger intake valve [Re: 416challenger] #468393
09/14/09 10:26 PM
09/14/09 10:26 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Intake Exhaust
.100" 82.8 N/A
.200" 149.0 112.1
.300" 211.2 169.3
.400" 255.6 203.2
.450" 269.4 218.0
.500" 276.3 226.0
.550" 281.5 229.8
.600" 284.6 231.2
.650" 284.6 231.5
.700" 284.6 232.9
82.8 CFM @ .100" lift??
Re: Gains switching to larger intake valve [Re: goldmember] #468394
09/14/09 10:28 PM
09/14/09 10:28 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
On my ported X heads I changed from stock 2.02 valves to a race style 2.05 intake and it picked up .2, I don't recall how much MPH it gained. I also replaced the stock exhaust valves with SS valves as well so there might be some gain from that.
68 Barracuda Formula S 340
Re: Gains switching to larger intake valve [Re: Bad340fish] #468395
09/14/09 11:01 PM
09/14/09 11:01 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
You bring up a good point. I have seen gains of .2 in the 1/8mile with a simple valve angle change,same valves. It's obvious that it was on different days so weather and track conditions cannot be ruled out.
Re: Gains switching to larger intake valve [Re: S/ST 3040] #468396
09/14/09 11:29 PM
09/14/09 11:29 PM
New Braunfels, TX
New Braunfels, TX
S/ST 3040-What did you mean by your comment???
Re: Gains switching to larger intake valve [Re: 416challenger] #468397
09/14/09 11:42 PM
09/14/09 11:42 PM
S/ST 3040 Offline
S/ST 3040  Offline
82.8 CFM @ .100" is not even in the ball park.
I've been through this before and I've never seen a 2.02"
valve flow more than 66 CFM @ .100" Being that far off at
.100" lift, only makes me question the 284+ at higher lifts.
I've seen similar flow numbers before, posted here.
Contrary to popular belief, this is a subject I know a little about.
Re: Gains switching to larger intake valve [Re: S/ST 3040] #468398
09/14/09 11:47 PM
09/14/09 11:47 PM
New Braunfels, TX
New Braunfels, TX
S/ST 3040- I was not aware that this number is abnormal(incorrect), that is why I asked. It is what is listed on the flow sheet. The heads were ported by a respected member from this site, so I assume the numbers were correct.
Re: Gains switching to larger intake valve [Re: 416challenger] #468399
09/15/09 12:01 AM
09/15/09 12:01 AM
S/ST 3040 Offline
S/ST 3040  Offline
Unless you send them back to the same guy to flow them with the
2.05 valves, you are going to be very disappointed. I can tell from
your flow sheet.
2.02" valve is capable of flowing at least 324 CFM @ .700"
2.05" valve is OK in an Edelbrock head but, you won't see any
improvement unless the valve job on 2.02" seat was no good
to begin with.
This is a set I did with the valves listed:
...........INTAKE........................ EXHAUST
.100"_____64.1___________________54.6
.200"____131.6__________________118.6
.300"____194.4__________________158.6
.400"____242.5__________________177.1
.500"____270.8__________________192.4
.550"____279.3__________________199.5
.600"____282.2__________________204.4
2.055" IN x 1.600" EX
Re: Gains switching to larger intake valve [Re: S/ST 3040] #468400
09/15/09 12:08 AM
09/15/09 12:08 AM
New Braunfels, TX
New Braunfels, TX
I am not hung up on the flow numbers. I am just looking for somewhere in my combination that I can make some improvement with minimal investment.
Re: Gains switching to larger intake valve [Re: 416challenger] #468401
09/15/09 12:13 AM
09/15/09 12:13 AM
S/ST 3040 Offline
S/ST 3040  Offline
Give us the whole build. Plus transmission, converter, race weight, gear and tire size.
Re: Gains switching to larger intake valve [Re: S/ST 3040] #468402
09/15/09 07:42 AM
09/15/09 07:42 AM
New Braunfels, TX
New Braunfels, TX
My combination is-73 Challenger, 418 cid, 11.55:1 comp, Edelebrock RPM heads, Vitor intake, 950HP carb, 262in 268ex 675" lift, 727 tran, 9 1/2" 4800 converter, Dana 60 w/ 4.10 gears, 28 x 12.5 ET Street tire, and the weight is 3720 w/ driver. I have ran a best of 6.92 @97.2 and 10.98 @120.7 w/ 1.50 60' time.
Re: Gains switching to larger intake valve [Re: 416challenger] #468403
09/15/09 09:09 AM
09/15/09 09:09 AM
S/ST 3040 Offline
S/ST 3040  Offline
Honestly, that is not bad for 11.55 compression and 3720 lbs. (505 HP)
Since you mentioned "improvement with minimal investment", I'd start
looking for places to take out weight. That's about as cheap as you
can get.......and effective.
Everything else looks pretty decent together. Maybe another 1.5 point
compression with another 10º cam, an 8' converter in a 2.74 low gear
904. Nothing really as cost effective as whittling down the weight.
After I got as much weight out of it, as I could, then I'd swap to a 2.74
904 with a matching 8" converter. Only then would I start messing with
the engine. The weight alone (200 lbs.) should get you 7.0s.
Good luck.
Re: Gains switching to larger intake valve [Re: S/ST 3040] #468404
09/15/09 09:33 AM
09/15/09 09:33 AM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Probably no gain unless you unshroud the valve by machining the combustion chamber.
Re: Gains switching to larger intake valve [Re: cgall] #468405
09/15/09 10:00 AM
09/15/09 10:00 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
if that is shrouded, you can expect very little then bore size comes into play.
imo...
Re: Gains switching to larger intake valve [Re: theclutcher] #468406
09/15/09 10:18 AM
09/15/09 10:18 AM
S/ST 3040 Offline
S/ST 3040  Offline
imo...
Anytime I've tried unshrouding the intake valve (straight wall side) on an
OEM head, it hurt flow. I haven't tried it on the RPM though.
Re: Gains switching to larger intake valve [Re: 416challenger] #468407
09/15/09 10:20 AM
09/15/09 10:20 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Intake Exhaust
.100" 82.8 N/A
.200" 149.0 112.1
.300" 211.2 169.3
.400" 255.6 203.2
.450" 269.4 218.0
.500" 276.3 226.0
.550" 281.5 229.8
.600" 284.6 231.2
.650" 284.6 231.5
.700" 284.6 232.9
If the port already stalls at .550 then adding more valve without adding port volume ahead of it isn't going to do much. I don't think shrouding is an issue. Or it's less of one than many think. I am curious tho... with those flow numbers, why such a small duration and huge lift? I would think more power will be made staying in the .650 range but adding another 15°-20° of duration at .050. I wouldnt have specd a cam any taller than .630 for those heads.
Re: Gains switching to larger intake valve [Re: moper] #468408
09/15/09 01:12 PM
09/15/09 01:12 PM
New Braunfels, TX
New Braunfels, TX
The car runs on pump gas, so I really do not want to raise the compression any more. I was kind of leaning toward lightening it up. I have a steel hood and will probably go to a fiberglass hood. I also will be going to a 29.5" x 10.5" ET Drag and was thinking about a low gear set in the transmission. Anyone know the weight of a steel Challenger hood?
Moper- The only reason for the high lift is I reused the 1.6 rockers that I had, with 1.5 I would have 632" lift.
Re: Gains switching to larger intake valve [Re: 416challenger] #468409
09/15/09 01:21 PM
09/15/09 01:21 PM
S/ST 3040 Offline
S/ST 3040  Offline
At 3720 lbs. there should be plenty of places to remove weight
without spending any money. It obviously gets harder (and more
expensive) the lighter you get.
Going up 1.5" in tire will lower your drive shaft RPM over 300
RPM at the same speed. Wrong direction, I think.
With 4% slip, I have you figured at about 6250 engine RPM, currently.
Re: Gains switching to larger intake valve [Re: S/ST 3040] #468410
09/16/09 09:10 AM
09/16/09 09:10 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
imo...
That is interesting,
Have only seen the opposite.
