Re: Gains switching to larger intake valve
[Re: 416challenger]
#468393
09/14/09 10:26 PM
09/14/09 10:26 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
I will be freshening up my motor after this season and I was considering going from a 2.02 valve to a 2.05. What kind of gains if any can be had? The heads are Edelbrock RPM that flow the as followed-
Intake Exhaust .100" 82.8 N/A .200" 149.0 112.1 .300" 211.2 169.3 .400" 255.6 203.2 .450" 269.4 218.0 .500" 276.3 226.0 .550" 281.5 229.8 .600" 284.6 231.2 .650" 284.6 231.5 .700" 284.6 232.9
The cam is 262in 268ex @.050 w/ 675" lift. I would like to run 7.00 in the heat, I normally run around 7.09 @ 3800 da. Has anyone made a similar change, if so what kind of results?
82.8 CFM @ .100" lift??
![](/ubbthreads/images/graemlins/violin.gif)
[Re: goldmember]
#468394
09/14/09 10:28 PM
09/14/09 10:28 PM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
On my ported X heads I changed from stock 2.02 valves to a race style 2.05 intake and it picked up .2, I don't recall how much MPH it gained. I also replaced the stock exhaust valves with SS valves as well so there might be some gain from that.
68 Barracuda Formula S 340
[Re: Bad340fish]
#468395
09/14/09 11:01 PM
09/14/09 11:01 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
You bring up a good point. I have seen gains of .2 in the 1/8mile with a simple valve angle change,same valves. It's obvious that it was on different days so weather and track conditions cannot be ruled out.
[Re: 416challenger]
#468397
09/14/09 11:42 PM
09/14/09 11:42 PM
S/ST 3040
S/ST 3040-What did you mean by your comment???
82.8 CFM @ .100" is not even in the ball park.
I've been through this before and I've never seen a 2.02" valve flow more than 66 CFM @ .100" Being that far off at .100" lift, only makes me question the 284+ at higher lifts.
I've seen similar flow numbers before, posted here.
Contrary to popular belief, this is a subject I know a little about.
[Re: 416challenger]
#468399
09/15/09 12:01 AM
09/15/09 12:01 AM
S/ST 3040
Unless you send them back to the same guy to flow them with the 2.05 valves, you are going to be very disappointed. I can tell from your flow sheet. 2.02" valve is capable of flowing at least 324 CFM @ .700" 2.05" valve is OK in an Edelbrock head but, you won't see any improvement unless the valve job on 2.02" seat was no good to begin with. ![](/ubbthreads/images/graemlins/Twocents.gif) This is a set I did with the valves listed: ...........INTAKE........................ EXHAUST .100"_____64.1___________________54.6 .200"____131.6__________________118.6 .300"____194.4__________________158.6 .400"____242.5__________________177.1 .500"____270.8__________________192.4 .550"____279.3__________________199.5 .600"____282.2__________________204.4 2.055" IN x 1.600" EX
[Re: S/ST 3040]
#468402
09/15/09 07:42 AM
09/15/09 07:42 AM
Posts: 415 New Braunfels, TX
416challenger
New Braunfels, TX
My combination is-73 Challenger, 418 cid, 11.55:1 comp, Edelebrock RPM heads, Vitor intake, 950HP carb, 262in 268ex 675" lift, 727 tran, 9 1/2" 4800 converter, Dana 60 w/ 4.10 gears, 28 x 12.5 ET Street tire, and the weight is 3720 w/ driver. I have ran a best of 6.92 @97.2 and 10.98 @120.7 w/ 1.50 60' time.
[Re: cgall]
#468405
09/15/09 10:00 AM
09/15/09 10:00 AM
Posts: 2,172 Ohio
theclutcher
Ohio
Probably no gain unless you unshroud the valve by machining the combustion chamber. ![](/ubbthreads/images/graemlins/iagree.gif)
if that is shrouded, you can expect very little then bore size comes into play. imo...
[Re: theclutcher]
#468406
09/15/09 10:18 AM
09/15/09 10:18 AM
S/ST 3040
Anytime I've tried unshrouding the intake valve (straight wall side) on an OEM head, it hurt flow. I haven't tried it on the RPM though.
[Re: 416challenger]
#468407
09/15/09 10:20 AM
09/15/09 10:20 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
If the port already stalls at .550 then adding more valve without adding port volume ahead of it isn't going to do much. I don't think shrouding is an issue. Or it's less of one than many think. I am curious tho... with those flow numbers, why such a small duration and huge lift? I would think more power will be made staying in the .650 range but adding another 15°-20° of duration at .050. I wouldnt have specd a cam any taller than .630 for those heads.
[Re: S/ST 3040]
#468410
09/16/09 09:10 AM
09/16/09 09:10 AM
Posts: 2,172 Ohio
theclutcher
Ohio
That is interesting, Have only seen the opposite.
