this may be a dumb qustion #467711
09/14/09 06:22 AM
09/14/09 06:22 AM
iowa usa
daves72dart Offline OP
iowa usa
i am putting caltracks on my dart and i need to lower and get 5" of play in the frontend of my dart.so my question is how do i lower and get the 5" of play in my front end? thanks and i hope this is not to dumb of a question.
Re: this may be a dumb qustion [Re: daves72dart] #467712
09/14/09 06:27 AM
09/14/09 06:27 AM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
No such thing as a dumb question ......
Could you explain "5" of play" and why you need that particular amount ? I assume it`s in upward travel ?
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: this may be a dumb qustion [Re: chryco] #467713
09/14/09 06:32 AM
09/14/09 06:32 AM
iowa usa
iowa usa
caltracks said that is what thay need to work to there fullest and yes im talking about upwards travel. thanks for not thinking it was a dumb qustion.
Re: this may be a dumb qustion [Re: daves72dart] #467714
09/14/09 07:02 AM
09/14/09 07:02 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
You can lower the front with the torsion bar adjustment bolts. It's a bolt in the center of the lower control arm near the frame rail end.
Re: this may be a dumb qustion [Re: Bigcube] #467715
09/14/09 07:08 AM
09/14/09 07:08 AM
iowa usa
iowa usa
thanks. will this change the front end alignment?
Re: this may be a dumb qustion [Re: daves72dart] #467716
09/14/09 07:18 AM
09/14/09 07:18 AM
yes
Re: this may be a dumb qustion [Re: daves72dart] #467717
09/14/09 11:43 AM
09/14/09 11:43 AM
you can also trim the lower control arm bumper to lower it some more
Re: this may be a dumb qustion [Re: daves72dart] #467718
09/14/09 12:06 PM
09/14/09 12:06 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I run cal-tracs and trimmed the upper rubber stop way down and as Cab said, I also trimmed the lower stop to 1/2" in height and made sure I had a 1/2" of air gap bet. the lower stop and controll arm so it won`t ride like a truck.
Re: this may be a dumb qustion [Re: Thumperdart] #467719
09/15/09 02:17 AM
09/15/09 02:17 AM
iowa usa
iowa usa
thanks for the help guys.
