Here's a good one for you motor guys! #467117
09/13/09 06:28 PM
09/13/09 06:28 PM
IL
hemiclone Offline OP
mopar addict
mopar addict
IL
OK 440 rebuilt a few years ago just installed, motor wont start I went threw everything! Hours have been spent on this and I found one thing that dosn't seem correct? I noticed two of the four cylinders on each side of the motor dont have the correct sequence for the opening of the intake and exhaust valves? Almost as if the incorrect cam is installed? As you know the valves quickly open Exhaust then intake then you have your pause and then again a quik bump of the exhaust then intake. Well on cylinder 1 and 3 (and the passenger side I cant remember what two cylinders)its in the order of intake then exhaust.
If your confused ask me some question and I will try to answer.
Thanks!
Re: Here's a good one for you motor guys! [Re: hemiclone] #467118
09/13/09 07:21 PM
09/13/09 07:21 PM
hooziewhatsit Offline
At least on a small block, the ports go IEEIIEEI, so if you're watching the rockers they won't match each other front to back. Two of the cylinders will be opposite the other two.
Is it just cranking and never firing?
Re: Here's a good one for you motor guys! [Re: hooziewhatsit] #467119
09/13/09 07:56 PM
09/13/09 07:56 PM
IL
mopar addict
mopar addict
IL
Thanks yes I know they go (1)EI (3)IE (5)EI (7)IE
3 and 7 are ok a quick push on the exhaust then intake then the crank goes around about a turn before they hit again. 1 and 5 I get a quick hit on intake then exhaust
Re: Here's a good one for you motor guys! [Re: hemiclone] #467120
09/13/09 08:41 PM
09/13/09 08:41 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Did you somehow wind up with a Hemi camshaft???
Re: Here's a good one for you motor guys! [Re: hooziewhatsit] #467121
09/13/09 08:55 PM
09/13/09 08:55 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
big and small block: E-II-EE-II-E
For the original poster's above comparison you have to figure in the firing order for the valve opening and closing sequence.
Re: Here's a good one for you motor guys! [Re: MoparforLife] #467122
09/13/09 09:24 PM
09/13/09 09:24 PM
IL
mopar addict
mopar addict
IL
Im very confused, my thought is it doesnt matter what firing order or sequence of cylinders...Im thinking about any one cylinder going threw its four strokes and the valves opening and closing at the proper time for that one cylinder
Re: Here's a good one for you motor guys! [Re: 1_WILD_RT] #467123
09/13/09 09:25 PM
09/13/09 09:25 PM
IL
mopar addict
mopar addict
IL
Isnt the Hemi Cam the same sequence as the 383 and 440?
Re: Here's a good one for you motor guys! [Re: hemiclone] #467124
09/13/09 09:37 PM
09/13/09 09:37 PM
Upper Midwest
Upper Midwest
Just what is the problem??? Is it that it won't run? It won't start or fire or what?
The intake valve and exhaust valve should each open 1 time for every 2 revelutions of the crankshaft.
It is real tough (at least for me) to understand what you are getting at.
With out being there to look at it I would say that you are misinterpeting the engine sequence but I am not there to see it myself. Prime it, put the valve covers on, time it and start it.
Re: Here's a good one for you motor guys! [Re: hemiclone] #467125
09/13/09 09:39 PM
09/13/09 09:39 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The ports are evenly spaced, so if they are the rockers are where things get funny.... It's been 25+ years since I owned a hemi & I could well be wrong but I know the ports are evenly spaced...
I'm sittin here thinkin about how Hemi rockers are laid out & I doubt the lobes are sequenced the same from a Hemi to a wedge...
Re: Here's a good one for you motor guys! [Re: MoparforLife] #467126
09/13/09 09:40 PM
09/13/09 09:40 PM
Deleted prior to arrival of politically biased moderators
Re: Here's a good one for you motor guys! [Re: 1_WILD_RT] #467127
09/13/09 09:43 PM
09/13/09 09:43 PM
IL
mopar addict
mopar addict
IL
When you say evenly spaced are you saying EI EI EI EI for valve location?
Re: Here's a good one for you motor guys! [Re: hemiclone] #467128
09/13/09 09:48 PM
09/13/09 09:48 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What compression are you getting in all cylinders? Are you sure you haven't got the distributer installed 180* out. Happens a lot.
Re: Here's a good one for you motor guys! [Re: hemiclone] #467129
09/13/09 09:49 PM
09/13/09 09:49 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
The valve layout on a Hemi is definitely different than a wedge. If I remember correctly they are laid out EIEIIEIE. If so, then it would seem likely you have a Hemi cam in there.
Re: Here's a good one for you motor guys! [Re: PC-CHARGER] #467130
09/13/09 09:52 PM
09/13/09 09:52 PM
IL
mopar addict
mopar addict
IL
The motor is acting like the came is set up for EI EI EI EI
Holy Cow!!!!!
DO I have a Hemi Cam in my 440 !!!!!!!!!!!!!!
Re: Here's a good one for you motor guys! [Re: hemiclone] #467131
09/13/09 09:53 PM
09/13/09 09:53 PM
IL
mopar addict
mopar addict
IL
Unbelievable!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Im going to cry!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Re: Here's a good one for you motor guys! [Re: stumpy] #467132
09/13/09 09:56 PM
09/13/09 09:56 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Looks like EI EI EI EI to me..
Re: Here's a good one for you motor guys! [Re: 1_WILD_RT] #467133
09/13/09 09:59 PM
09/13/09 09:59 PM
IL
mopar addict
mopar addict
IL
It sure does!
Re: Here's a good one for you motor guys! [Re: hemiclone] #467134
09/13/09 10:00 PM
09/13/09 10:00 PM
IL
mopar addict
mopar addict
IL
The Hemi cam does fit into a 440 correct?
Re: Here's a good one for you motor guys! [Re: hemiclone] #467135
09/13/09 10:01 PM
09/13/09 10:01 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
It sure does!
Hey throw down with one of those beers! We drink together... Sorry buddy..
Yeah the hemi cam will fit, it started life with the same block...
Re: Here's a good one for you motor guys! [Re: 1_WILD_RT] #467136
09/13/09 10:05 PM
09/13/09 10:05 PM
IL
mopar addict
mopar addict
IL
Thankyou for your help!
