Re: Here's a good one for you motor guys!
[Re: hemiclone]
#467118
09/13/09 07:21 PM
09/13/09 07:21 PM
Posts: 3,892 Oregon
hooziewhatsit
At least on a small block, the ports go IEEIIEEI, so if you're watching the rockers they won't match each other front to back. Two of the cylinders will be opposite the other two. Is it just cranking and never firing?
[Re: hooziewhatsit]
#467121
09/13/09 08:55 PM
09/13/09 08:55 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
big and small block: E-II-EE-II-E For the original poster's above comparison you have to figure in the firing order for the valve opening and closing sequence.
[Re: MoparforLife]
#467122
09/13/09 09:24 PM
09/13/09 09:24 PM
Posts: 484 IL
hemiclone
mopar addict
mopar addict
IL
Im very confused, my thought is it doesnt matter what firing order or sequence of cylinders...Im thinking about any one cylinder going threw its four strokes and the valves opening and closing at the proper time for that one cylinder
[Re: 1_WILD_RT]
#467123
09/13/09 09:25 PM
09/13/09 09:25 PM
Posts: 484 IL
hemiclone
mopar addict
mopar addict
IL
Did you somehow wind up with a Hemi camshaft???
Isnt the Hemi Cam the same sequence as the 383 and 440?
[Re: hemiclone]
#467124
09/13/09 09:37 PM
09/13/09 09:37 PM
MoparforLife
Upper Midwest
Just what is the problem??? Is it that it won't run? It won't start or fire or what? The intake valve and exhaust valve should each open 1 time for every 2 revelutions of the crankshaft. It is real tough (at least for me) to understand what you are getting at. With out being there to look at it I would say that you are misinterpeting the engine sequence but I am not there to see it myself. Prime it, put the valve covers on, time it and start it.
[Re: MoparforLife]
#467126
09/13/09 09:40 PM
09/13/09 09:40 PM
Deleted prior to arrival of politically biased moderators
[Re: 1_WILD_RT]
#467127
09/13/09 09:43 PM
09/13/09 09:43 PM
Posts: 484 IL
hemiclone
mopar addict
mopar addict
IL
The ports are evenly spaced, so if they are the rockers are where things get funny.... It's been 25+ years since I owned a hemi & I could well be wrong but I know the ports are evenly spaced...
When you say evenly spaced are you saying EI EI EI EI for valve location?
I'm sittin here thinkin about how Hemi rockers are laid out & I doubt the lobes are sequenced the same from a Hemi to a wedge...
[Re: hemiclone]
#467131
09/13/09 09:53 PM
09/13/09 09:53 PM
Posts: 484 IL
hemiclone
mopar addict
mopar addict
IL
[Re: 1_WILD_RT]
#467136
09/13/09 10:05 PM
09/13/09 10:05 PM
Posts: 484 IL
hemiclone
mopar addict
mopar addict
IL
[Re: hemiclone]
#467139
09/13/09 11:50 PM
09/13/09 11:50 PM
The motor is acting like the came is set up for EI EI EI EI Holy Cow!!!!! DO I have a Hemi Cam in my 440 !!!!!!!!!!!!!!
you better reverse that for a hemi cam. the first cam lobe on a hemi is the intake, on a wedge it would be exhaust.
