90/10s #466879
09/13/09 09:29 AM
09/13/09 09:29 AM
UK
602heavy Offline OP
602heavy  Offline OP
UK
Fitted the comp engineering shocks & think one shock has been built back to front , the 90/10 setting is set to the XF mark , one of the shocks has to be set to the 50/50 setting for it to be the same rebound as the other shock , this was tested on the bench.
Any thoughts?
Re: 90/10s [Re: 602heavy] #466880
09/13/09 01:30 PM
09/13/09 01:30 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I tried comp no good at best a 70/30 and hard to set right??, carrara and lakewood finally got 90/10
Cal tracs and happy camper now
Post deleted by moparts [Re: 602heavy] #466881
09/14/09 12:57 PM
09/14/09 12:57 PM
Re: 90/10s #466882
09/14/09 06:32 PM
09/14/09 06:32 PM
UK
602heavy Offline OP
602heavy  Offline OP
UK
Spoke with Comp today & they are aware of the problems , they say the 'pin' has moved in the shock which is why one of them does'nt line up with the correct mark.
I can either send them back or just use them as they are , they are both set on the lightest extension irrespective of the marking.
Re: 90/10s [Re: 602heavy] #466883
09/14/09 07:24 PM
09/14/09 07:24 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
i have a set under the bench. bought the caltrac 90/10. these caltracs are way better.
