starter not engaging flywheel. Mopar mini #466234
09/12/09 02:19 AM
09/12/09 02:19 AM
Auburn Hills, Michigan
K
kieron_kohlmann Offline OP
K
hi ive got a mopar mini starter mounted on a scattershield. the starter tooth barely hits the flywheel. any way i can fix this?
Re: starter not engaging flywheel. Mopar mini [Re: kieron_kohlmann] #466235
09/12/09 08:47 AM
09/12/09 08:47 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
SB or BB?On BBs for sure you need a 143 flywheel or the kit to move the starter in toward the crank.I have the mini on my 440 with shield and 143 and its flawless.RockyRocky
Chrysler Firepower
Re: starter not engaging flywheel. Mopar mini [Re: therocks] #466236
09/13/09 02:31 AM
09/13/09 02:31 AM
K
K
BB with a 10.5" flywheel. where can i get this kit from? it already has the holes drilled to move the starter in but thats not enough.
Re: starter not engaging flywheel. Mopar mini [Re: kieron_kohlmann] #466237
09/13/09 05:44 AM
09/13/09 05:44 AM
Spring Hill, Fl.
tecmopar Offline
tecmopar  Offline
Spring Hill, Fl.
What you need is the starter nose cup that bolts inside the bellhousing. I have one if need it, check out Summitt's site or Jegs first then let me know, good luck.
Re: starter not engaging flywheel. Mopar mini [Re: tecmopar] #466238
09/13/09 05:09 PM
09/13/09 05:09 PM
K
K
can you explain to me what the starter nose cup does?
Re: starter not engaging flywheel. Mopar mini [Re: kieron_kohlmann] #466239
09/14/09 05:36 AM
09/14/09 05:36 AM
Spring Hill, Fl.
tecmopar Offline
tecmopar  Offline
Spring Hill, Fl.
If you look at your starter you'll see that the front of it has as part of the casting, a stub that hold the gear shaft end. his stub goes into the cup and keeps the starter from moving around with just the 2 bolts in it. The stock bellhousings have this cast into it.
