BB Water neck - is there a style that doesn't leak? #463402
09/08/09 09:25 PM
09/08/09 09:25 PM
Cleveland, Ohio
northcoastmopar Offline OP
Cleveland, Ohio
I have tried both the OEM cast and a chrome aftermarket style like the one below. I have sanded off the chrome, tried different sealers, even tried the Right Stuff gasket maker...still leaks. Has anyone used the O-ring style or a billet aluminum type? If so, how well do they seal? I'm running an oem iron water pump housing. Do the new aluminum housings seal better? Thanks in advance!!
Re: BB Water neck - is there a style that doesn't leak? [Re: northcoastmopar] #463403
09/08/09 09:45 PM
09/08/09 09:45 PM
MNobody Offline
MNobody  Offline
Chrome = junk, buy a billet, cast steel or sand the stock one flat and use that.
Re: BB Water neck - is there a style that doesn't leak? [Re: northcoastmopar] #463404
09/08/09 09:46 PM
09/08/09 09:46 PM
I would suggest drawfiling the water pump manifold itself also & making sure the bolts aren't bottoming out just before they get tight.
Re: BB Water neck - is there a style that doesn't leak? [Re: RapidRobert] #463405
09/08/09 09:50 PM
09/08/09 09:50 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I bought mine from Roger Gibson Restorations about 2 yrs. ago and hasn't leaked yet.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: BB Water neck - is there a style that doesn't leak? [Re: 70sixpkrt] #463406
09/08/09 10:10 PM
09/08/09 10:10 PM
IN
ahy Offline
ahy  Offline
IN
I ent through this. Here's what I learned. 1) Avoid the chrome MP type - they warp if you look at them too hard. 2) Iron (NAPA)or steel (440 source) works best. Some folks have had good results with billet aluminum (Mancini). Check flatness with a straight edge and trial fitting. If there's any rock when trial fitting without gasket you've got warpage. Use a belt sander or file to get the mating surfaces flat. Use some hardening type Permatex with a gasket as insurance. Don't overtorque - it will cause warpage and leaks.
Re: BB Water neck - is there a style that doesn't leak? [Re: northcoastmopar] #463407
09/08/09 10:48 PM
09/08/09 10:48 PM
Cleveland, Ohio
Cleveland, Ohio
Thanks guys, I will pick up a Napa iron one tomorrow.
Re: BB Water neck - is there a style that doesn't leak? [Re: northcoastmopar] #463408
09/09/09 08:08 AM
09/09/09 08:08 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Mancini Billet. One and only. Chrome Junk. NAPA Superstat 180. All good.
Re: BB Water neck - is there a style that doesn't leak? [Re: DennisH ] #463409
09/09/09 08:32 AM
09/09/09 08:32 AM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
hey John,mine leaked at first,then i filed both surfaces,new gasket used red high heat permatex,bolted it down(be sure bolts aern't bottoming out) then i let it sit overnight before adding any coolant,i know it sounds aweful simple but it hasn't leaked since.and i'm using my original neck. good luck Darren
Re: BB Water neck - is there a style that doesn't leak? [Re: northcoastmopar] #463410
09/09/09 10:13 AM
09/09/09 10:13 AM
Washington, IL
Hughes Offline
Hughes  Offline
Washington, IL
These CSR hosuings are all we use. We have good luck with them and sell quite a few.
http://www.hughesengines.com/Index/produ...mp;partid=24196
Re: BB Water neck - is there a style that doesn't leak? [Re: Hughes] #463411
09/09/09 10:17 AM
09/09/09 10:17 AM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
What do you recommend for a thermostat for the CSR swivels? CSR recommends the small Chevy style but it is so small it falls right into the hole in the pump housing.
Re: BB Water neck - is there a style that doesn't leak? [Re: DennisH ] #463412
09/09/09 11:06 AM
09/09/09 11:06 AM
I'll be using the same here with the exception of a Mr. Gasket 180* stat.
I have the aluminum housing with the chrome pot metal water neck and a nice, super slow, weeping leak.
I think it has to do with the dissimilar metals heating and cooling at different rates which causes them to leak.
Using the aluminum billet piece along with the aluminum housing should prevent that from happening.
Iron housing should run iron neck as well.
Re: BB Water neck - is there a style that doesn't leak? [Re: PC-CHARGER] #463413
09/10/09 11:04 AM
09/10/09 11:04 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
I used a Meziere swivel o-ringed one on my 383, I just positioned the thermostat right in the middle and its been fine for years. Maybe the Chevy one I bought is a tiny bit bigger than yours although it is close.
Ride eternal, shiny and chrome
Re: BB Water neck - is there a style that doesn't leak? [Re: DirectSubjection] #463414
09/10/09 11:09 AM
09/10/09 11:09 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I had a troublesome water neck. I ended up using a file to "block sand" the water pump housing, and did the same to the water neck. once I started filing down to shiney new metal, I could see that BOTH parts were not flat. once they were both flat, no more problems.
**Photobucket sucks**
Re: BB Water neck - is there a style that doesn't leak? [Re: 70Cuda383] #463415
09/10/09 11:17 AM
09/10/09 11:17 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Never used anything but OEM.The "very" few that I had leak took one trip over the belt sander and never leaked again.One of the other problems is the paper gasket with the peel off adhesive backing.Get a good gasket or make your own out of good material.
Re: BB Water neck - is there a style that doesn't leak? [Re: 62maxwgn] #463416
09/10/09 02:47 PM
09/10/09 02:47 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
I'm using the OEM with two gaskets and black permatex. no leaky
Re: BB Water neck - is there a style that doesn't leak? [Re: DirectSubjection] #463417
09/10/09 02:53 PM
09/10/09 02:53 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
I have the Mopar Performance aluminum housing. Maybe the opening is slightly larger than the stock cast iron or maybe as you said, your thermostat is a bit larger. CSR said to use the 52mm Chevy but as I said, that one just drops down the hole.
Re: BB Water neck - is there a style that doesn't leak? [Re: PC-CHARGER] #463418
09/10/09 02:57 PM
09/10/09 02:57 PM
Denver
E
Explodo Offline
Explodo  Offline
E
Denver
My story regarding the chevy thermostat:
I tried a Meziere water neck that's listed as working for an RB engine. They don't tell you that you have to mill it if you're using a stock type water pump. After calling and finding out to mill it and use a chevy thermostat, I got it milled and then went to put it on to find out that the thermostat is the same size as the water pump outlet. I was not pleased.
I'm using a MP 90 degree water neck with no trouble at all.
'67 440 Satellite
Re: BB Water neck - is there a style that doesn't leak? [Re: Explodo] #463419
09/10/09 04:32 PM
09/10/09 04:32 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
Hey John, I have a stock iron neck, and i use the brown liquid sealer in a bottle I get from CarQuest. No leaks ever. I knew an old truck mechinac, he always used weatherstriping glue for gaskets. Bear to get off, but never leaked.
1981 Dodge D150 360 auto
Re: BB Water neck - is there a style that doesn't leak? [Re: basketcase] #463420
09/10/09 05:06 PM
09/10/09 05:06 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Indian head gasket sealer is that the name of it?
Re: BB Water neck - is there a style that doesn't leak? [Re: northcoastmopar] #463421
09/10/09 05:37 PM
09/10/09 05:37 PM
Cali S.B
Sub95 Offline
super gas
Sub95  Offline
super gas
Cali S.B
I dont use gaskets on the thermostat housings, as they all will leak over time, plus i like shiny things lol.
Get a can of right stuff, put a 1/8 bead all the way around the housing and tighten it up. you will never have a leak again
