Re: Odd Overheating Problem
[Re: 10sec440]
#460403
09/07/09 07:16 PM
09/07/09 07:16 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Back to the original topic, why not put the 160 degree thermo back in and see if your problem goes away and go from there?
If you have a good stat it will not/can not cause over heating.
[Re: convertriple]
#460405
09/13/09 08:21 PM
09/13/09 08:21 PM
Posts: 115 Tampa Bay
BadFishy
Tampa Bay
Okay, I am back. Problem solved and CHALLENGER1 WINS! Does anybody want to buy a slightly defective thermostat housing? ;-)
I pulled the housing and checked the machined edge - the side that mounts on the pump. Sure enough, there was a very small, about 1/4 inch depression right where the gasket had blown out. It wasn't noticeable until I sanded the entire surface with a hard sanding block and, voila, there it was! I guess what had happened was that before, when I was having no problems, I had put enough sealer on the gasket to seal the housing in spite of the defect. But upon putting in the new thermostats, I had only used cork gaskets, with no sealant, and that was not enough.
Looking inside the housing, I see it was made in Taiwan - nice chrome, but obviously lousy quality. Anyway, I junked the housing and bought a Billet Specialties polished billet housing. That one comes with and O-ring instead of using a gasket, and allen wrench bolts. It looks great and matches several other aluminum parts under the hood too. I took it out for a test drive, got on it several times and no problems whatsoever.
Thanks everyone for the input. And I have to admit, I was thinking that... well, if a head is cracked, I guess it wouldn't be too bad a day if I had to go out and buy a set of those aluminum Eddy's!
1971 Cuda, 440 custom-build
[Re: Challenger 1]
#460407
09/13/09 08:43 PM
09/13/09 08:43 PM
BadFishy
Tampa Bay
Probably not worth driving from Cincy for a defecto Chinese thermostat housing! But if you want, you can also have a couple bags of rock salt and two snow shovels since I am moving to Florida. Oh, wait, I gave those to my mother-in-law.
[Re: Crizila]
#460410
09/14/09 11:37 AM
09/14/09 11:37 AM
Challenger 1
Cincinnati, Ohio
Where do I pickup my prize?
Right here Just because his stat housing doesn't leak anymore, doesn't mean his problem is gone. Appears as though his over-heat problem went away with the new stat housing also?????????? Normally, the highest cooling system pressure occurs after shut down, when the engine heat soaks ( and that's when the stat housing leaks at it's worst), not as you rev up the motor - unless you are pumping air in to the cooling system. Not sure who anymore, but someone used to sell a kit that would detect exhaust gasses in the cooling system. Good way to verify that all is ok.
He didn't have a overheating problem before he changed the thermostat, why would have one after changing it other than the thermostat housing leaking???
What do you think he should do? Change the head gaskets??
[Re: Challenger 1]
#460411
09/14/09 12:04 PM
09/14/09 12:04 PM
Posts: 7,506 Az
Crizila
Az
Read his entire post - including the post title ( "odd overheating problem "). Leaky t-stat housings don't cause overheats, but overheats can cause leaky t-stat housings. I think he should go a little farther to verify he doesn't have a head gasket problem - if his initial post and diagnosis as an overheating problem ( only when he mashed on the gas pedal )was correct. Obviously, time will tell. Here is your prize =
Fastest 300
