'70 a-body ps column to manual box? #458294
09/03/09 01:03 PM
09/03/09 01:03 PM
OK
70SWGR Offline OP
70SWGR  Offline OP
OK
I know adapters are available but I seem to remember someone on here removing the pin then redrilling after fitting to a manual box?
Re: '70 a-body ps column to manual box? [Re: 70SWGR] #458295
09/03/09 02:15 PM
09/03/09 02:15 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Not sure on E-bodies, but B-bodies differ in column length and the gearbox splined shaft size PS/MS.
If that also applies to E-bodies, and I can't imagine it wouldn't, then IF you can swap the coupler you'll have to move the dash bracket about 1.5" and the steering wheel will be that much further away. I don't know if a PS shaft can be used in a MS column, but it would seem possible.
Re: '70 a-body ps column to manual box? [Re: topside] #458296
09/03/09 05:40 PM
09/03/09 05:40 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I have seen people break the nylon pins for the collapsible column and slide the inner shaft out. You still need the adapter, and I personally would weld the inner shaft to the outer because it is pretty close to slipping out of the tube IIRC.
Re: '70 a-body ps column to manual box? [Re: 70SWGR] #458297
09/03/09 07:27 PM
09/03/09 07:27 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
My 2 cents worth.......use the adaptor!!
Somehow that frigging with the steering shaft and stuff scares me.
I'm in the process of changing over to manual steering on my Challenger....and everyone I've talked to about it used the adaptor....pricey...but correct.
Re: '70 a-body ps column to manual box? [Re: 70SWGR] #458298
09/03/09 08:22 PM
09/03/09 08:22 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
Keep the top half of the column intact.
Pull apart the upper and lower shafts. They are held together by plastic bolts.
Slide in manual shaft and attach box. Tack weld or reinsert new plastic bolts.
Adapters? We don't need no stinking adapters.
Re: '70 a-body ps column to manual box? [Re: superwrench] #458299
09/03/09 09:10 PM
09/03/09 09:10 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Agree with SuperWrench! Don't mess with the steering shaft, don't weld! I switched from power to manual on my '69 Road Runner and bought the adapter from Rick Ehrenberg. I think he's a member of this board. I've bought a bunch of Mopar parts from Rick. Very nice guy, very knowledgable about chassis and steering. With his adapter everything bolted together easily and works perfect. Jeff
Re: '70 a-body ps column to manual box? [Re: 1969RR] #458300
09/03/09 10:02 PM
09/03/09 10:02 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Go to a junkyard and find a B-van with the adapter. Theyre not so uncommon
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
