8 3/4 axle bearing and adjuster kit?
#456335
09/01/09 11:03 AM
09/01/09 11:03 AM
Posts: 549 Oregon
abodyman
super street
super street
Getting an axle bearing replaced, primarily because the outer seal was leaking. and I couldnt replace it, unless the whole nearing assembly needed to be removed, to even get to it. Anyhoo....My machine shop, "Ed" called and told me there used to be available, a kit, which replaced the whole assembly. Bearing,seal,and the adjuster assembly? I was just wondering, if anyone knows, if the kit, like that, is still available? Just for next time! Thanks, Robert.
Re: 8 3/4 axle bearing and adjuster kit?
[Re: abodyman]
#456337
09/01/09 11:31 AM
09/01/09 11:31 AM
Posts: 74,992 U.S.S.A.
JohnRR
U.S.S.A.
The OUTER SEAL is a DUST seal, it only has GREASE behind, if you are leaking gear oil the INNER seal in the tube is the problem.
It takes some work, and hopefully it hasn't been destroyed yet, but the bearing can be removed without destroying the outer plate, it involves removing the outer race first, cut the cage to remove the rollers, cut and remove the outer sleeve that goes on after the bearing to make it easier to pull the bearing off, replace the outer seal and reinstall the set 7 bearing which comes with that second ring that goes on after the bearing.
Done it many times and I have extra plates too from junk axles. NOS bearing kits from mopar came with both retaining plates, buy a set 7 bearing and the 2 seals and you have a complete bearing set, too bad they went NS1 years ago ...
[Re: MoparforLife]
#456344
09/02/09 08:21 AM
09/02/09 08:21 AM
Posts: 15,487 Florida
scratchnfotraction
greese for the bearing oil for the chunk in housing a leak on the tube seal will wash the greese out of bearings,so make sure its repacked with greese on install I use a greese needle on mine to get it in between the rollers and cage
[Re: Snoopy]
#456350
09/02/09 10:13 PM
09/02/09 10:13 PM
Posts: 13,577 md
mopars4ever
md
[Re: JohnRR]
#456352
09/04/09 02:38 AM
09/04/09 02:38 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
I just had the bearings and seals done on my 8 3/4 at a local place, I pulled the axles and dropped them off. These guys knew what they were doing and my adjusters were in excellent condition. But I almost fell down at the price.. New Bearing set $80....PER SIDE ! Seals about $25 ea x4 Labor $50 / side..They were kind enough to give me a 10% discount on parts... Total $350... OUCH...Yes I live in the Big City and everything is more here, But they did it right and it is really nice not to listen to the grindy noise anymore... So the Ebay price in not that bad...
[Re: JohnRR]
#456354
09/05/09 03:38 AM
09/05/09 03:38 AM
sthemi
Chicago Burbs
NO Kisses, but a 4 hour turn around on the job. FWIW, the parts at Rock auto are about half what I paid.. bearings are $34 ea and seals $12... Hard to complain about bearings lasting 41 years tho... ,
