Getting an axle bearing replaced, primarily because the outer seal was leaking.
and I couldnt replace it, unless the whole nearing assembly needed to be removed, to even get to it.
Anyhoo....My machine shop, "Ed" called and told me there used to be available, a kit, which replaced the whole assembly.
Bearing,seal,and the adjuster assembly?
I was just wondering, if anyone knows, if the kit, like that, is still available?
Just for next time!
Thanks,
Robert.
