After market tach hookup #455939
08/31/09 08:21 PM
08/31/09 08:21 PM
NW Pa
DARTROD Offline OP
DARTROD  Offline OP
NW Pa
I have a 97 Dodge van with a 3.9 V6, i'd like to hookup an after market tach, where do you hook up wires ? I don't want screw anything up.
PROUD member of The Patriot Guard Riders
Re: After market tach hookup [Re: DARTROD] #455940
09/11/09 10:01 PM
09/11/09 10:01 PM
NW Pa
DARTROD Offline OP
DARTROD  Offline OP
NW Pa
BTT
Re: After market tach hookup [Re: DARTROD] #455941
09/11/09 10:03 PM
09/11/09 10:03 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Use your 12v test light to poke around the fuse box for a switched 12v power supply and a backlighting power supply. Then run the tach signal wire to the coil negitive terminal and the last wire from the tach should be a ground.
