360 ideas? #454147
08/30/09 01:18 AM
08/30/09 01:18 AM
Branson, Mo.
joedust451 Offline OP
super gas
super gas
Branson, Mo.
Sence i have this new 71 318 swinger project, i've decided to just keep it SB, so i'll be building up a 360 most likely, i'm wanting to achieve mid. 12s NA or there abouts, i've heard good things about the 360 Magnum roller motors, would a good used one get the job done with the basic bolt-ons/converter/gears? Or would i be better off with the older 360 & just building it from scatch, i'll be useing the 904 trans.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: 360 ideas? [Re: joedust451] #454148
08/30/09 01:43 AM
08/30/09 01:43 AM
Santa Rosa, NOR*CAL.
Just Cameron Offline
Either one can be built to make good power.
Re: 360 ideas? [Re: joedust451] #454149
08/30/09 01:45 AM
08/30/09 01:45 AM
SoCal
Brian Hafliger Offline
SoCal
All the factory LA and Magnum heads like to crack...so investing in them is a waste.
So if you replace them with new cast iron heads from say EQ, then I would build a magnum engine, use a nice hyd roller comp grind, mildly port the heads and use 1.7 rockers (make sure the grind matches the rocker ratio).
Rpm intake, 950HP carb and 9.8:1 compression and it should make 400HP pretty easily.
A nice 3500stall converter and 4.10 gears should net you mid to low 12's with a good slick.
Brian Hafliger
Re: 360 ideas? [Re: Brian Hafliger] #454150
08/30/09 02:40 AM
08/30/09 02:40 AM
Branson, Mo.
super gas
super gas
Branson, Mo.
Just say i find a good running magnum engine, what all will i need to do to drop it in, other then intake/carb? Will it bolt up to my 71 904 trans?
Also, what year did the magnum start getting a roller cam?
Re: 360 ideas? [Re: joedust451] #454151
08/30/09 03:56 PM
08/30/09 03:56 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
Also, whats a good year to look for
Anyone know
Re: 360 ideas? [Re: joedust451] #454152
08/30/09 04:33 PM
08/30/09 04:33 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
all Magnum 360 have roller cams..
the LA 360 got roller cams in 1989...but only lasted to 1991..then the magnum came about.
Tony
70 AARCuda Vitamin C
Re: 360 ideas? [Re: 70AARcuda] #454153
08/30/09 05:54 PM
08/30/09 05:54 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
Thanks, so do i need to stay with the LA 360, or will say a 95 Magnum drop in with minor mods?
Re: 360 ideas? [Re: joedust451] #454154
08/30/09 07:30 PM
08/30/09 07:30 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
With that car it will not be too tough to achieve mid twelves without using up a budget. Mill the heads to about 60 CC's, leave your stock pistons, porting not needed but will help, (mine wasn't and with 1.88 valves or 2.02, made 0 difference), run a 271 HDP Crower Cam, an LD340 intake and 750 Holley and some nice gears and tires and you are there. If I can do it anyone can.
Re: 360 ideas? [Re: MoparforLife] #454155
08/30/09 10:10 PM
08/30/09 10:10 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Doesn't take much to get a early 70's A-body to run mid 12's. Any year magnum 360 will work. Yes a mid 90's mag will work. If you want to use the serpentine belt setup there's some tinkering to be done there to get the newer ps pump to mate with your ps box. Alternatively the old 318/360 front end(timing cover/water pump housing/brackets/70's alternator & ps pump) will all bolt up if you want to keep that old style look with the stock 70's V-belts instead of the serpentine setup.
If you take a 90's mag 360 and do eddy rpm intake, 650 holley carb, recurved or aftermarket dist, cam and headers with some rear gearing and a 3k stall converter I think you should see mid 12's.
Re: 360 ideas? [Re: DaytonaTurbo] #454156
08/30/09 10:24 PM
08/30/09 10:24 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
Thanks guys
Re: 360 ideas? [Re: joedust451] #454157
08/30/09 10:29 PM
08/30/09 10:29 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
I have a scamp with the la 360,9 to 1,eddy heads,2800 stall and 3:73's
It'l run mid 12's all day long on street tires.
Re: 360 ideas? [Re: west] #454158
08/31/09 02:13 AM
08/31/09 02:13 AM
Branson, Mo.
super gas
super gas
Branson, Mo.
Found a 95 360 out of a 4x4, it was supposedly rebuild with only 3K miles untill the truck got rolled, he got it 3 yrs. ago but never used it, its complete, but been outdoors under a heavy tarp for over 2 yrs. (now indoors), he's asking 500.00 but its neg. Should i take the chance?
Re: 360 ideas? [Re: joedust451] #454159
08/31/09 02:23 AM
08/31/09 02:23 AM
1st thing to do is put a breaker bar on the harmonic dampener bolt & see if it turns free. I'm personally leery of engines that have sat outside unused for long periods of time. His price is too high.
Re: 360 ideas? [Re: RapidRobert] #454160
08/31/09 02:41 AM
08/31/09 02:41 AM
Branson, Mo.
super gas
super gas
Branson, Mo.
I feel the same way, he said he will turn it with a breaker bar for me, he just did it the other day for someone, but for some reason they passed on it.
Re: 360 ideas? [Re: joedust451] #454161
08/31/09 08:40 AM
08/31/09 08:40 AM
Missouri
MY340 Offline
MY340  Offline
Missouri
The motor in my signature was built using a PAW 360 block bored .030 Excellent hp & torque and pulls really strong with a 904 tranny/2600 convertor and 3.91 gears.
The timeslips I got with the car say mid-high 12's with slicks.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
