Page 3 of 4 1 2 3 4
Re: Post up your oil choice!!! [Re: Bob_Coomer] #451394
08/27/09 10:34 PM
08/27/09 10:34 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Brad Penn here
Gus
64 Plymouth Savoy
Dana 60
Re: Post up your oil choice!!! [Re: Bob_Coomer] #451395
08/27/09 10:37 PM
08/27/09 10:37 PM
Port Alberni, British Columbia
MoparDonny Offline
MoparDonny  Offline
So what do you guys think is so special about your oils? I never know what to buy because everyone claims their's is best anyway. I've been using Pennzoil 10w30 or Castrol GTX 10w30. I used to run 15w40 Rotella. And I've used 10w40 Royal Purple, still have half a case in the shop. I can get Mobil 1 10w30 easy enough and thought I'd try that. Never had a problem with any of them.
Pennzoil 10w30 is in my car now though.
Don.
Re: Post up your oil choice!!! [Re: Bob_Coomer] #451396
08/27/09 10:45 PM
08/27/09 10:45 PM
Burlington,Ont.
77DragracerR/T Offline
Burlington,Ont.
It was a solid lift cam but i think my "advice" on springs was too much as i was running K-Motion 800 springs on a Crane cam 560/580 lift 258/268 with Howard lifters.Just to clear things here I'm not saying one or the other product was to blame! But i ran the VR1 oil as it is recommended for flat tappet push rod engines and now that i have a MP590 cam in there i will be running that oil again.I think the pressure of the springs was too much IMO.Right now i will be running a little less pressure then recommended.Still in shock mode I guess.I don't know who too believe anymore? Never enough spring pressure,too much spring pressure???
Just don't know why it hit #7 intake and everything else was perfect? Not even one full season.
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
Re: Post up your oil choice!!! [Re: MoparDonny] #451397
08/27/09 11:03 PM
08/27/09 11:03 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Don.
People prefer “special” oils because of what’s formulated into them.
Nothing wrong with Pennzoil 10w30, Castrol GTX 10w30 or Mobil 1 10w30, but they are API (SM) rated oils. SM rated oils are required to have lower zinc and phosphorus levels which is not a problem in newer cars.
If you’re running a older modified V8 with a high performance flat-tappet camshaft, you need motor oil with higher levels of zinc and phosphorus.
Do a search here of the board for zinc and phosphorus (ZDDP).
Re: Post up your oil choice!!! [Re: 77DragracerR/T] #451398
08/27/09 11:33 PM
08/27/09 11:33 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I'm running a fast ramp Comp solid, 350# open w/double springs. About 1,000 street miles and a little dyno time. So far, so good...
I ripped the oil sample from another member here...
Re: Post up your oil choice!!! [Re: 64Post] #451399
08/28/09 12:08 AM
08/28/09 12:08 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I've found that the filter is more important than the oil. The zinc thing is something to consider these days but head to head, oil is oil. I'm talking a given 10W-40 versus another 10W-40, etc. Not a syn oil against a dino, or any other combinations like that.
I want my fair share
Re: Post up your oil choice!!! [Re: SomeCarGuy] #451400
08/28/09 11:54 AM
08/28/09 11:54 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
You are right that motor oil filtration is an important factor.
The Society of Automotive Engineers (SAE) has known this for a while now.
See also: SAE Oil Filter Testing and Correlation Between Engine Wear.pdf - link
As for motor oil, if we are talking about comparing a non-race off-the-shelf name brand API rated petroleum 10W-40 to another 10W-40, probably not much difference there.
However, motor oil formulators have a vast menu of base oils and additives to consider when formulating a motor oil product. This goes for both conventional petroleum oils as well as synthetic oils. Based on a price to performance ratio, formulators can use inexpensive ingredients or high dollar ingredients to meet their objectives.
This is why some motor oils cost more than others; because motor oil is not created equal.
Retired VP of Marketing at the Hatco Corporation, Tom Schaefer, can explain this better than I can.
Excerpt from fom Schaefer’s article, What’s In Your Oil: Choosing the right components of the right chemistry in the right dosages is a real balancing act, as each of the components have their own pluses and minuses and can interact or compete with each other. Don’t try this at home - leave it to companies you trust who have the technology, R&D, and resources to achieve the necessary balance so critical to performance.
Read Tom Schaefer’s full article: What’s In Your Oil - link
Re: Post up your oil choice!!! [Re: CompSyn] #451401
08/28/09 12:13 PM
08/28/09 12:13 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
So I guess I'm the only one using Kedall 30WT...
Re: Post up your oil choice!!! [Re: 70dusterjohn] #451402
08/28/09 12:20 PM
08/28/09 12:20 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
summit's 10w40 race oil
Re: Post up your oil choice!!! [Re: 05dakota] #451403
08/28/09 06:55 PM
08/28/09 06:55 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Caterpillar 15-30 with Hughes additive.
Re: Post up your oil choice!!! [Re: moparmattkos] #451404
08/29/09 09:42 PM
08/29/09 09:42 PM
Suwanee, Georgia
srracing8 Offline
srracing8  Offline
Suwanee, Georgia
Royal Purple 20W50 Racing Synthetic
Amsoil Syn in the Trans
1/8@5.83/120mph 1/4@9.28/143mph
Re: Post up your oil choice!!! [Re: srracing8] #451405
08/29/09 09:57 PM
08/29/09 09:57 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
What is so great about Brad Penn everyone recommends.. other than saying brad penn list why? I am gonna run a solid roller setup... local speed shop has it for $13 qt
Mopar Performance
Re: Post up your oil choice!!! [Re: moparniac] #451406
08/29/09 11:23 PM
08/29/09 11:23 PM
Iowa
I
ironjay Offline
ironjay  Offline
I
Iowa
What so great about Brad Penn is it is $3.75 a qt. for 10-30 and 20-50 here, and it is the only oil that my engine builder says to use.
Re: Post up your oil choice!!! [Re: ironjay] #451407
08/29/09 11:27 PM
08/29/09 11:27 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
i paid over 7 bucks since nobody within 100 miles stocks it.
Re: Post up your oil choice!!! [Re: CompSyn] #451408
08/31/09 10:01 AM
08/31/09 10:01 AM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Absolutely nothing....other than it's NOS SJ
I buy old forumlations where I can find them and get a good deal on them.
Re: Post up your oil choice!!! [Re: ZIPPY] #451409
08/31/09 10:05 AM
08/31/09 10:05 AM
Canada
RobR Offline
RobR  Offline
Canada
Pennzoil 50 for me.
Re: Post up your oil choice!!! [Re: RobR] #451410
08/31/09 10:22 AM
08/31/09 10:22 AM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
Mobil One 5/20 in bracket mode. Gibbs 0wt for class.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Post up your oil choice!!! [Re: moparniac] #451411
08/31/09 01:43 PM
08/31/09 01:43 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Look at the phosphorus and zinc content in the lab test I posted above and compare it to the other brands.
Re: Post up your oil choice!!! [Re: 64Post] #451412
08/31/09 01:52 PM
08/31/09 01:52 PM
Mid Missouri
E
ETASPEN Offline
ETASPEN  Offline
E
Mid Missouri
Brad Penn 20/50 in race car
Rotella T 15/40 in CTD truck
Re: Post up your oil choice!!! [Re: ETASPEN] #451413
08/31/09 01:57 PM
08/31/09 01:57 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Brad Penn 20/50 here!!!!!!!
Page 3 of 4 1 2 3 4
