4-speed guys shifter question #450644
08/26/09 01:16 PM
08/26/09 01:16 PM
southern Idaho
moparcyco Offline OP
southern Idaho
I need a shifter for my 70 challenger,my friend has a new in the box comp plus shifter he got from summit he will sell me cheap he bought it for a 69 charger so I know the rods won't work but can I buy the corrrect rods for my car and use this shifter?I hope so because a new one is a lot more than I have right now.or is there any other affordable option out there?Thanks for the help
Re: 4-speed guys shifter question [Re: moparcyco] #450645
08/26/09 01:28 PM
08/26/09 01:28 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
Shifter will work with the correct mounting plate for your car and the correct rods.
Brewer's have what you will need.
http://www.brewersperformance.com/products.asp?id=53
http://www.brewersperformance.com/products.asp?id=114
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: 4-speed guys shifter question [Re: Mick70RR] #450646
08/26/09 02:10 PM
08/26/09 02:10 PM
Martinsville, VA
440child Offline
440child  Offline
Martinsville, VA
Brewers has excellent stuff, Summit also has the complete kit w/ shift levers & all for a non-console car. The only thing with Summit's is that it comes w/ nylon shift lever bushings, but you can get the Hurst Pit Pack w/ metal shift bushings from Summit but it costs extra.
Re: 4-speed guys shifter question [Re: 440child] #450647
08/27/09 02:03 AM
08/27/09 02:03 AM
Auburn Hills, Michigan
K
kieron_kohlmann Offline
K
i got my install kit off ebay. saved me about $20. i agree go with the steel bushings.
Re: 4-speed guys shifter question [Re: kieron_kohlmann] #450648
08/27/09 05:57 AM
08/27/09 05:57 AM
Spring Hill, Fl.
tecmopar Offline
tecmopar  Offline
Spring Hill, Fl.
The shifter mechaniam for a '69 B-body is not the same as one for an E-body. The levers in the E-body mech. are splayed out further because its mounted on the very back of the trans. If you use a B-body unit you will wind up with possible binding problems, good luck.
