Weight difference: Hemi+Dana vs. 440+ 8 3/4 ??? #450309
08/26/09 02:06 AM
08/26/09 02:06 AM
Europe
BB 70 Challenger Offline OP
Europe
Hello,
This is my first posting here. Looking forward to this great board!
Where can I find exact weights for following drivetrains:
- 426 Hemi and TF727 and Dana
- 440 Magnum and TF727 and 8 3/4
Even links to separate weights is very much appreciated.
Thanks for links/info !
Re: Weight difference: Hemi+Dana vs. 440+ 8 3/4 ??? [Re: BB 70 Challenger] #450310
08/26/09 09:42 AM
08/26/09 09:42 AM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
i.d say around 400 lbs dan
Re: Weight difference: Hemi+Dana vs. 440+ 8 3/4 ??? [Re: ph23vo] #450311
08/26/09 09:53 AM
08/26/09 09:53 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
A dana is about 50 to 80 lb more than a 8 3/4 (some say 110??) and a hemi is about 30 lb heavier than a 440
Re: Weight difference: Hemi+Dana vs. 440+ 8 3/4 ??? [Re: Dodgem] #450312
08/26/09 10:02 AM
08/26/09 10:02 AM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
My 8 3/4 to Dana conversion added 36lbs total. Comparing Sure Grip to Sure Grip. Both housings were narrowed a few inches, and the 8 3/4 had a billet aluminum yoke. But I'd say 35-40 lbs would be a good range. Same brakes in my case.
Re: Weight difference: Hemi+Dana vs. 440+ 8 3/4 ??? [Re: LAR_414] #450313
08/26/09 11:23 AM
08/26/09 11:23 AM
ar.
bobs69 Offline
bobs69  Offline
ar.
A street hemi is 765 pounds a 440 is 670 pounds.
Re: Weight difference: Hemi+Dana vs. 440+ 8 3/4 ??? [Re: bobs69] #450314
08/26/09 08:30 PM
08/26/09 08:30 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
My old '69 383 4spd Roadrunner weighed 3600 with me in it. My '68 Hemi 4 spd GTX weighed 3900 with me in it. Dave
Re: Weight difference: Hemi+Dana vs. 440+ 8 3/4 ??? [Re: BB 70 Challenger] #450315
08/26/09 09:55 PM
08/26/09 09:55 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
A dana weighs 50 lbs more than an 8 3/4 on a scale. A 426 hemi with iron heads weighs about 100 lbs more than an iron 440.
Sheldon
Re: Weight difference: Hemi+Dana vs. 440+ 8 3/4 ??? [Re: RUNCHARGER] #450316
08/30/09 03:20 PM
08/30/09 03:20 PM
Europe
Europe
Thank you very much, gentlemen !
