Smoking out of only one side of dual exhaust.
#448974
08/25/09 11:29 AM
08/25/09 11:29 AM
Posts: 406 Houma, Louisiana
twister360
Houma, Louisiana
I have a 74 Duster with a mild 360, headers, and dual exhaust. I do not have an h or x pipe in the system, just straight from engine to rear tips. I drove the car yesterday and noticed it blows smoke from the driver side exhaust. It smells like gas, but I am not sure. Is it possible for the car to be rich only on one side? I have about 1500 miles on the build and it does not use oil.
My car 74 Duster mild 360/904/3.91 13.44/101.54
Son's car 75 Dart Sport 318/904/4.10 looking for a 360 or 408
2004 Dodge Ram 1500 Laramie 5.7
2010 Dodge Challenger R/T Classic B-5 6 speed
2010 Jeep SRT8 for the little wife
Re: Smoking out of only one side of dual exhaust.
[Re: twister360]
#448975
08/25/09 11:51 AM
08/25/09 11:51 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I don't think it's possible to be rich on just "one side" because I think just about every intake, when at WOT, will feed 2 cylinders on each side from 1 circuit of the carb...for example, the front primaries would feed 1, 4, 6, 7. and the secondaries would feed 2, 3, 5, 8. or something similar to that--with most dual planes anyway....single planes would be more like front primaries on carb feed front 4 cylinders, and the secondaries feed the back 4 cylinders...
but, I don't know for sure, if the carb is gummed up or something it could be possible that one venturi is running rich, making 1 or 2 cylinders richer than the rest...
what color is the smoke? Blue/Grey? Black? White?
**Photobucket sucks**
[Re: twister360]
#448976
08/25/09 11:55 AM
08/25/09 11:55 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
what color smoke? white=water, blue=oil, black=rich
if it's a dual plane manifold, typically one side of the carb feeds 1/2 the cylinders. on an eddie RPM or air gap, the DS of the carb feeds 1,7,4,6 and the pass side feeds 3,5,2,8 (looking at the pics on summit)
[Re: ph23vo]
#448978
08/25/09 12:57 PM
08/25/09 12:57 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
intake gasket or surface... dan
could be sucking oil on one bank.
[Re: patrick]
#448979
08/25/09 01:36 PM
08/25/09 01:36 PM
twister360
Houma, Louisiana
I have a dual plane air gap. The smoke is blackish and smells somewhat of gas. Any test to check out the problem? Thanks
[Re: twister360]
#448981
08/25/09 09:39 PM
08/25/09 09:39 PM
patrick
Grand Haven, MI
hmm...only thing I can think of would be an intake manifold gasket not sealing, causing a vaccuum leak on one side, leaning out that bank of cyls?
[Re: patrick]
#448982
08/26/09 02:38 PM
08/26/09 02:38 PM
twister360
Houma, Louisiana
Could I spray starting fluid along the manifold gasket and see if it effects the running of the engine?
