Ignition conversion #447875
08/24/09 05:26 AM
08/24/09 05:26 AM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Hello, I posted this over in the general section but will hopefully get more replies over here. I finally bought a dragcar a 72 Dart with a warmed up 318 and I'm having a blast. But It has points and I did have some issue's with it. I'm thinking of doing the pertronix conversion for right now. looking for some input good or bad.
Re: Ignition conversion [Re: flatiron] #447876
08/24/09 05:37 AM
08/24/09 05:37 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
FBO ignition kit, I've not used them but a lot of people i know have and speak highly off them.
There's a member on here who sells their stuff, i think it's Dave 571.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Ignition conversion [Re: flatiron] #447877
08/24/09 10:24 AM
08/24/09 10:24 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Pertronix works very well.Neighbor has them on his Studebakers.Get the Ignitor II kit.
If it were me,I would just wire in a Chrysler electronic ignition.
Nautilus Racing-
Re: Ignition conversion [Re: Chris2581] #447878
08/24/09 10:25 AM
08/24/09 10:25 AM
an8sec70cuda Offline
I put a Pertronix kit on a friend's '69 road runner, nice kit and works good. I like my MSD stuff though. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Ignition conversion [Re: an8sec70cuda] #447879
08/24/09 10:36 AM
08/24/09 10:36 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I used the Ignitor Petronix kit for this Accel Duel point Dist. Its a great option, and works with the Aftermarket MSD box's also. These old dist can still be found fairly cheap, and I wanted the added look of Nostalgia for my car. Of coarse hidden under the dash will be the MSD 7 box.
The kit was about $90 IIRC. And works well if your wanting to do something like I am, or want to keep the original numbers dist.
If your not worried, it might be cheaper, if you scrounged the junk yard for a late 70's early 80's electronic system. Stay away from the lean burn stuff.
Re: Ignition conversion [Re: Chris2581] #447880
08/24/09 04:34 PM
08/24/09 04:34 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
I was also thinking of going this route. looking at Mancini's web site I see a few choice's Mopar performance offers a orange or a chrome ecu. and Mancini's has a package that includes the coil and plug wire's. Any input which route to go
Re: Ignition conversion [Re: flatiron] #447881
08/24/09 08:23 PM
08/24/09 08:23 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Bttt
Re: Ignition conversion [Re: flatiron] #447882
08/24/09 09:12 PM
08/24/09 09:12 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Go with a OEM Mopar electronic igntion. Parts are readily availble and get the parts to do it at the local parts house and the local bone yard for the plug in.
Re: Ignition conversion [Re: MoparforLife] #447883
08/24/09 11:20 PM
08/24/09 11:20 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I don't sell the FBO stuff anymore.
It is decent. Based on oem, so you can always sub in stock stuff if it breaks down.
What's nice, is you can have don curve you a distributor at the same time, so you know you have it all matched.
If the motor has any knid of cam or other mods, the recurve is well worth the money
