Broken motor mount ears on block #447678
08/23/09 11:46 PM
08/23/09 11:46 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
This block came back from the machine shop with one ear broke on each side.
Can this block still be used with the stock mounts?
Id really like to not have to run a plate/elephant ears as it will be bear to mount my alt and get pulley alignment, but....
If it matters, I do use a chain on the drivers side to stop torquing.
Opinions?
Re: Motor mount ear pics [Re: Von] #447679
08/23/09 11:47 PM
08/23/09 11:47 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Other side.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Motor mount ear pics [Re: Von] #447680
08/23/09 11:48 PM
08/23/09 11:48 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
If it were a Factory big block A body the driver side would not be a concern .
is it the one single ear on the other side ?
Re: Motor mount ear pics [Re: JohnRR] #447681
08/23/09 11:50 PM
08/23/09 11:50 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
[quote
is it the one sigle ear on the other side ?
If you mean the one single ear broke, yes. One ear on both sides is broke.
Re: Motor mount ear pics [Re: Von] #447682
08/24/09 12:11 AM
08/24/09 12:11 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Von, i just put a plate on my car and mounted the alternator down low, it wasnt hard and didnt cost a penny. if you decide to go that route i could send you pics
Re: Motor mount ear pics [Re: sixpackgut] #447683
08/24/09 12:12 AM
08/24/09 12:12 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Thanks for the offer. If I go that route I'll hit you up for the pics.
Any opinion on the ears?
Re: Motor mount ear pics [Re: Von] #447684
08/24/09 12:17 AM
08/24/09 12:17 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
i really dont know.
Re: Motor mount ear pics [Re: sixpackgut] #447685
08/24/09 05:45 AM
08/24/09 05:45 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I use elephant ears and haven't had a problem, if you look in the tech section on BBD, It shows you how to make and fit them.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Motor mount ear pics [Re: deaks] #447686
08/24/09 06:43 AM
08/24/09 06:43 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
easy fix, done this before. you get a special arc welding rod that welds to cast iron. wind the amps up & get your mate to keep the weld area hot with the oxy acetylene or similar. you just build up a big blob that you grind into shape, redrill the hole & bobs your uncle it's fixed! a coat of paint & no one will know. i assisted a dirt track racer to do this exact repair, it's pretty strong!
Re: Motor mount ear pics [Re: rebel] #447687
08/24/09 11:08 AM
08/24/09 11:08 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Call the shop and tell them to find the broken piece. They broke it, atleast they can find it. With this piece, it can be welded with a Ni rod, or stainless rod...
IMO
I wouldnt sweat it.You have the other two bolts to hold the engine. All of them on the other side, use the torque strap, and forget it.
Re: Motor mount ear pics [Re: Bob_Coomer] #447688
08/24/09 11:22 AM
08/24/09 11:22 AM
Indiana
maxie Offline
maxie  Offline
Indiana
why redrill it, when you can put a piece off copper in it, weld around it, pull the copper out and there will be a hole there?
Re: Motor mount ear pics [Re: maxie] #447689
08/24/09 11:24 AM
08/24/09 11:24 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Check this repair stuff out
Check this stuff out
http://www.aluminumrepair.com/video_new.asp
Re: Motor mount ear pics [Re: Bob_Coomer] #447690
08/24/09 11:45 AM
08/24/09 11:45 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
exactly! I would be more upset with the machine shop, and make them fix it, and then re-check everything for square!
if THEY broke the ears off, then THEY need to fix it, and adding that much heat to the block, you might distort cylinder bores or something, so THEY should check everything to make sure it hasn't moved
but, bottom line, yes it can be fixed and use your stock motor mounts. I saw bob george's work fixing some blocks for his customers, and holy crap! I used to think a window in the side of the block meant it was junk, but not anymore!
**Photobucket sucks**
Re: Motor mount ear pics [Re: Von] #447691
08/24/09 12:21 PM
08/24/09 12:21 PM
U.S.S.A.
U.S.S.A.
doooh , yes like that , you added the second picture as I was typing my reply , I didn't see it .
Re: Motor mount ear pics [Re: sixpackgut] #447692
08/24/09 12:49 PM
08/24/09 12:49 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
We have a small block with the ears on the torque side and we have it in a 65 belvy with no issues, it came out of a dirt car, and got hammered pretty hard on the drivers front. Hasnt hurt anything yet, we just have a strap on it.
Kasey
Re: Motor mount ear pics [Re: 70Cuda383] #447693
08/24/09 01:44 PM
08/24/09 01:44 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Well the ears were broke off 2 years ago when this block was machined. The guy who did the machine work is a good enough machinist, but a clown. Took about 6 months or more to get the block from him, finally got it home and didnt notice the ears were gone a few months down the line. Before I figured out he was a clown I took him the 440 block that is in my car at the moment. I paid to have the cam bearing journals corrected. (Journals too small from the factory, cam fit WAY too tight.) When I picked the block up he had scraped the bearings to fit my cam. No biggie, but I paid to have the block corrected. He also tried to charge me an extra 150 for a line hone. No dice, didnt ask for it, block didnt need it. Didnt pay for it and wont ever pay for it. Short verstion of the story, I never had a chance to get the ears back.
Like said above, no way I'll braze or weld on the block now. Warped cylinders dont appeal to me.
Just for giggles I think I'll fashion something and epoxy it. Maybe a thin bushing, epoxy it to the block, etc. Yeah, I know its a waste, but I want to see if the epoxy will adhere to the block and stay adhered.
Re: Motor mount ear pics [Re: Von] #447694
08/24/09 01:55 PM
08/24/09 01:55 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Von, i just took the shumacher torque strap off my car. sell it to you $50 if your interested
Re: Motor mount ear pics [Re: sixpackgut] #447695
08/24/09 02:27 PM
08/24/09 02:27 PM
sweden
sshemi Offline
sshemi  Offline
sweden
i wouldnt worry about it.
its pretty common on pre -75 blocks.
In 75 the ears got beafier.
Re: Broken motor mount ears on block [Re: Von] #447696
08/24/09 07:45 PM
08/24/09 07:45 PM
build it up with JB weld - might take a couple of tubes by looking at the pix. I built up a mounting boss on my Jeep 4.0 and have run it 4 years on the strip with no prob;ems. You might drill and tap the mt and put a 1/4 20 bolt in to wrap the JB around - Make a form with tape and cardboard, then add the JB
Re: Motor mount ear pics [Re: sshemi] #447697
08/24/09 07:54 PM
08/24/09 07:54 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Don't waste your time and just put a plate on.I mounted my alternator on the power steering ear on the water pump and also ended up with a shorter alternator belt too
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
