My balancer spun about 8 degrees????
#446954
08/23/09 11:46 AM
08/23/09 11:46 AM
Posts: 344 Phoenix
jinxy
Phoenix
My balancer has spun about 8 degrees on my pump gas,internal balance,408" small block. The brand is Romac. When I went to adjust timing I discovered this.
Is this a big problem, other than setting timing?
What brand do you guys recommend? I need to bolt on the factory 70 Dart pulley.
Jeff
Re: My balancer spun about 8 degrees????
[Re: Quicktree]
#446957
08/23/09 12:14 PM
08/23/09 12:14 PM
Posts: 705 Michigan
Hemiroid
take it back to walmart and get an ATI
You're on a roll today
All kidding aside, you have a bomb with the fuse lit. Immediately remove and disgard it, as it's a disaster waiting to happen. ATI is without a doubt the way to go.
[Re: Hemiroid]
#446959
08/23/09 01:06 PM
08/23/09 01:06 PM
Quicktree
I try it makes good movies
[Re: jinxy]
#446961
08/23/09 01:08 PM
08/23/09 01:08 PM
Quicktree
TCI Rattler $363 at Jegs.
Anyone use this one?
are you having troulble reading? ATI
[Re: dOOc]
#446963
08/23/09 01:35 PM
08/23/09 01:35 PM
Posts: 344 Phoenix
jinxy
Phoenix
[Re: jinxy]
#446964
08/23/09 01:55 PM
08/23/09 01:55 PM
Quicktree
Do you work for ATI?
no
[Re: weedlayer]
#446970
08/23/09 04:07 PM
08/23/09 04:07 PM
Posts: 3,210 robin hood country
deaks
robin hood country
When they spin that much is it obvious on inspection.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#446971
08/23/09 04:20 PM
08/23/09 04:20 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
We run Summit SFI ones.Mine has been on 10 years and no problems.Rocky
Chrysler Firepower
