My balancer spun about 8 degrees???? #446954
08/23/09 11:46 AM
08/23/09 11:46 AM
Phoenix
jinxy Offline OP
jinxy  Offline OP
Phoenix
My balancer has spun about 8 degrees on my pump gas,internal balance,408" small block. The brand is Romac. When I went to adjust timing I discovered this.
Is this a big problem, other than setting timing?
What brand do you guys recommend? I need to bolt on the factory 70 Dart pulley.
Jeff
Re: My balancer spun about 8 degrees???? [Re: jinxy] #446955
08/23/09 11:58 AM
08/23/09 11:58 AM
Q
Quicktree Offline
Quicktree  Offline
Q
take it back to walmart and get an ATI
Re: My balancer spun about 8 degrees???? [Re: jinxy] #446956
08/23/09 12:09 PM
08/23/09 12:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Today it s moved 8*....tomorrow you might be buying
a new hood... or worse
Re: My balancer spun about 8 degrees???? [Re: Quicktree] #446957
08/23/09 12:14 PM
08/23/09 12:14 PM
Hemiroid Offline
Hemiroid  Offline
You're on a roll today
All kidding aside, you have a bomb with the fuse lit. Immediately remove and disgard it, as it's a disaster waiting to happen. ATI is without a doubt the way to go.
Re: My balancer spun about 8 degrees???? [Re: Hemiroid] #446958
08/23/09 12:37 PM
08/23/09 12:37 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
A bad balancer is one of the fastest ways to trash a stroker crank
Re: My balancer spun about 8 degrees???? [Re: Hemiroid] #446959
08/23/09 01:06 PM
08/23/09 01:06 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I try it makes good movies
Re: My balancer spun about 8 degrees???? [Re: emarine01] #446960
08/23/09 01:07 PM
08/23/09 01:07 PM
Phoenix
jinxy Offline OP
jinxy  Offline OP
Phoenix
TCI Rattler $363 at Jegs.
Anyone use this one?
Re: My balancer spun about 8 degrees???? [Re: jinxy] #446961
08/23/09 01:08 PM
08/23/09 01:08 PM
Q
Quicktree Offline
Quicktree  Offline
Q
are you having troulble reading? ATI
Re: My balancer spun about 8 degrees???? [Re: Quicktree] #446962
08/23/09 01:24 PM
08/23/09 01:24 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
Which if any brands have a ridge to prevent the outer ring from flying off?
Re: My balancer spun about 8 degrees???? [Re: dOOc] #446963
08/23/09 01:35 PM
08/23/09 01:35 PM
Phoenix
jinxy Offline OP
jinxy  Offline OP
Phoenix
Do you work for ATI?
Re: My balancer spun about 8 degrees???? [Re: jinxy] #446964
08/23/09 01:55 PM
08/23/09 01:55 PM
Q
Quicktree Offline
Quicktree  Offline
Q
no
Re: My balancer spun about 8 degrees???? [Re: Quicktree] #446965
08/23/09 02:06 PM
08/23/09 02:06 PM
San Diego, CA
brktracr Offline
super street
brktracr  Offline
super street
San Diego, CA
I've run a Rattler for many years without any problem. I think it's a good product.
1.298 60 ft 6.001 1/8 mile 114 mph 9.52 1/4 mile 140.87 mph @ 3110 lbs
Re: My balancer spun about 8 degrees???? [Re: brktracr] #446966
08/23/09 02:43 PM
08/23/09 02:43 PM
Phoenix
jinxy Offline OP
jinxy  Offline OP
Phoenix
Thanks brktracr.
Any one else have any recs?
ATI, TCI, ????
Re: My balancer spun about 8 degrees???? [Re: jinxy] #446967
08/23/09 02:46 PM
08/23/09 02:46 PM
Florida STAYcation
dOOc Offline
dOOc  Offline
Florida STAYcation
To totally avoid any "spinning" issues .... some people way back when bought those aluminum hubs. Remember those ?
Remember what happened when people put those on their moders ?
Re: My balancer spun about 8 degrees???? [Re: jinxy] #446968
08/23/09 02:57 PM
08/23/09 02:57 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
My move 4 deg..off it came!! ATI here...everyone I talk to says it the best one..362.00 at jegs..My was a summit brand . I think it a romac ?
I think maybe it crack my crank..not sure ..lots of things was wrong in my motor..so don't know for sure what happen first..but you need to get it off there right away !
Re: My balancer spun about 8 degrees???? [Re: VernMotor] #446969
08/23/09 03:00 PM
08/23/09 03:00 PM
CheddarHead till October
weedlayer Offline
weedlayer  Offline
my BHJ or BJH, or whatever it is makes a nice doorstop after it spun a few degrees. ATI since with no problems. 7+ years??
Re: My balancer spun about 8 degrees???? [Re: weedlayer] #446970
08/23/09 04:07 PM
08/23/09 04:07 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
When they spin that much is it obvious on inspection.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: My balancer spun about 8 degrees???? [Re: deaks] #446971
08/23/09 04:20 PM
08/23/09 04:20 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We run Summit SFI ones.Mine has been on 10 years and no problems.Rocky
Chrysler Firepower
Re: My balancer spun about 8 degrees???? [Re: therocks] #446972
08/23/09 06:15 PM
08/23/09 06:15 PM
Phoenix
jinxy Offline OP
jinxy  Offline OP
Phoenix
I can't tell by looking at it, but you can when you put the timing light on it.
Re: My balancer spun about 8 degrees???? [Re: jinxy] #446973
08/23/09 06:21 PM
08/23/09 06:21 PM
weedlayer Offline
weedlayer  Offline
was told a long time ago, paint a line across the body and the ring and keep an eye on the line to see it stays lined up.
