Re: Is a sway bar REALLY THAT important...? #445617
08/22/09 04:48 PM
08/22/09 04:48 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
The GTX belts out in excess of 600hp to the wheels and I had no problems steering with one hand (manual steering no less) while rowing the shifter with slicks out back with 8 pounds of air inflation.
That's a real poor example, as you (I guess) are referring to dragstrip scenerio
And I made it equally clear that it was a street driven car, matter of fact it was my daily driver well through 80's and part of the 90's along with a really healthy '67 Dart.
Re: Is a sway bar REALLY THAT important...? [Re: gdonovan] #445618
08/22/09 05:52 PM
08/22/09 05:52 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
I need to ask where on the vehicle did it break. Are you talking the mounting tab on the lower control arm or what? Hopefully if the break is there at that spot mentioned the repair can be done without having to tear the lower arm components apart. My vote would be to try and fix it. I have a 66 Chrysler 300 that came with a front sway bar and boy am I glad it does. These big cars handle real nicely with them. Without? I woundn't want to find out.....
Re: Is a sway bar REALLY THAT important...? [Re: CR8CRSHR] #445619
08/22/09 06:56 PM
08/22/09 06:56 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
My 67 R/T vert has a factory front swaybar and I installed a firm feel rear sway bar in it.. Quite a noticable difference after installing the rear bar... For a large car, by todays standards, it handles pretty well on the street...
Re: Is a sway bar REALLY THAT important...? [Re: gdonovan] #445620
08/22/09 07:23 PM
08/22/09 07:23 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Really depends on how you drive it on the street. If you drive it like I do my mercedes, yes you need it. After reading his post on how he drives on the freeway, I doublt he drives any faster than my grandma around the corners.
I have a 10.50 street car that I removed the front swaybar. Afterwards I drove the car like a grandma around the turns. It sucked badly if I tried to push on the street around a corner. It suck even worst when I put a rear sway bar on it, but I got 1.40s in the 60 foot times with the rear bar so thats why I put it there.
You see more cornering in the street than a 1/4 mile track.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Is a sway bar REALLY THAT important...? [Re: HealthServices] #445621
08/22/09 07:32 PM
08/22/09 07:32 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I'm sorry, perhaps you could help me clarify what I posted.
What part of STREET DRIVEN DAILY DRIVER was not clear?
I drove it too and from work, a fair distance every single day. And being in New England there were actual corners time to time! I even ran errands with it as you would a daily driven car.
With 15" rallyes and the factory HD suspension the handling was very acceptible.
Re: Is a sway bar REALLY THAT important...? [Re: gdonovan] #445622
08/22/09 07:37 PM
08/22/09 07:37 PM
So Cal
So Cal
Basically you found it acceptable and I did not. So we have different views.
Re: Is a sway bar REALLY THAT important...? [Re: gdonovan] #445623
08/22/09 07:41 PM
08/22/09 07:41 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
"Acceptable" and "well" are a world apart in handling. If you had driven it with the bar hooked up you would have realized how much better it handled on the street. There is no way in hades that a car without a bar handles as well as one with.
Re: Is a sway bar REALLY THAT important...? [Re: stumpy] #445624
08/22/09 07:55 PM
08/22/09 07:55 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
My 67 Barracuda used to lean just using the round about near my home. I added a front sway bar and it is a different car. I can't praise enough the better conering.
Re: Is a sway bar REALLY THAT important...? [Re: stumpy] #445625
08/22/09 08:41 PM
08/22/09 08:41 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
What makes you think I did not?
The bar is still in the car, all I did was disconnect the links. The handling between running with the bar hooked up and without was not worth me getting excited about.
With good rubber and rims the difference shrinks, as I already pointed out several posts ago.
Again, as the original poster states (whom this thread is about) would **he** find a difference in having a bar hooked up or not.
Based on his expected driving style I doubt he would notice a difference since in this day and age I doubt he would be running 30 year old bias ply tires.
Re: Is a sway bar REALLY THAT important...? [Re: Chucklehead] #445626
08/22/09 09:56 PM
08/22/09 09:56 PM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
is that the wagon that was on craiglist around the Payson area?
No I found this locally in southeastern Az. Wasnt advertised for sale,just sittin in a yard and I asked about it.
Re: Is a sway bar REALLY THAT important...? [Re: SPWC] #445627
08/22/09 11:59 PM
08/22/09 11:59 PM
SPWC Offline OP
SPWC  Offline OP
Here are some pics of the broken bracket. Any ideas of how this can be repaired? Is it as easyu as just disconnecting the link,having the bracket welded back in place and reinstalling the link? Or is this repair more involved?
passenger side(Bracket broke off)
Drivers side(Bracket still intact)
Re: Is a sway bar REALLY THAT important...? [Re: SPWC] #445628
08/23/09 12:02 AM
08/23/09 12:02 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
In a emergency move it will help a bunch. The "daily no frills" can be tested at any moment. Lot of mass to keep under control if you have to..
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Is a sway bar REALLY THAT important...? [Re: SPWC] #445629
08/23/09 12:15 AM
08/23/09 12:15 AM
So Cal
So Cal
Yeah your sway bar is not doing anything right now.
Is this something you can clean up and take to a muffler shop or someone with a mig welder?
It does not look like a tough job may even cost as little as $20
Re: Is a sway bar REALLY THAT important...? [Re: SPWC] #445630
08/23/09 09:01 AM
08/23/09 09:01 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
"Anti-sway bars are an important handling aid on any car and in particular big iron like a wagon."
The stock bar is the bare minimum.
Rick
Re: Is a sway bar REALLY THAT important...? [Re: Rick_Ehrenberg] #445631
08/23/09 09:53 AM
08/23/09 09:53 AM
scratchnfotraction Offline
yea thats an easy fix.IMO
remove the links and weld it back to the frame and hook it back up
use PM function for the guys..not the mans post thats looking for help
can you all agree,that you disagree?? so drop it,run what you brung
Re: Is a sway bar REALLY THAT important...? [Re: scratchnfotraction] #445632
08/23/09 11:19 AM
08/23/09 11:19 AM
Az
Crizila Offline
Crizila  Offline
Az
This car needed a rear sway bar.
Fastest 300
Re: Is a sway bar REALLY THAT important...? [Re: SPWC] #445633
08/23/09 11:38 AM
08/23/09 11:38 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
necesary NOT. important YES, AND A LOT... you'll notice a BIG diff without. so WELD IT BACK!!!!
Re: Is a sway bar REALLY THAT important...? [Re: Crizila] #445634
08/23/09 12:04 PM
08/23/09 12:04 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
That's a nice looking car!
Re: Is a sway bar REALLY THAT important...? [Re: SPWC] #445635
08/23/09 02:48 PM
08/23/09 02:48 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Pretty easy, just weld it back with some reinforcements. (maybe a plate over the frame before putting the bracket back on.
The sway bar actually improves handling, and came on most of the larger cars because of the vehicle weight and mild torsen bar spring rates (for that soft ride.) Installing stiffer torsen bars or reducing the vehicle weight will improve handling, but the ride will be stiffer.
I think if the sway bar is removed the car may want to understeer more than if it is installed.
Re: Is a sway bar REALLY THAT important...? [Re: 451Mopar] #445636
08/23/09 03:05 PM
08/23/09 03:05 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I would say it depends on the T-bar rates also.
Small/stock t-bars on that car and I would definately want a sway bar, if you put bigger t-bars on it would do fine with out them.
Several different lines of thought to think about, some guys like heavy t-bars and mild or no sway bars at all, this kind of a set up tends to brake better because you get less brake dive meaning the rear tires stay planted better and can do more stoping work. Setting your car up this way will have a stiffer ride and arguably good handling.
Second line of thought is big sway bars and little t-bars, this will give you a better ride and good handling but brakeing suffers, weight transfer on acceleration is better this way though.
As for the original poster I would want anything that would help my handling on that beast especially if it is all stock suspension
