Door to Fender gap #444174
08/20/09 11:36 AM
08/20/09 11:36 AM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Anybody know what the door to fender gap is on a 68 Roadrunner? Thanks
Re: Door to Fender gap [Re: bobs69] #444175
08/20/09 12:58 PM
08/20/09 12:58 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I don't have my car here to measure, but it is pretty wide.
Here is a picture. This car has never been apart (fenders or doors) and never had a front end hit.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Door to Fender gap [Re: bobs69] #444176
08/20/09 01:00 PM
08/20/09 01:00 PM
Mt. Eden Ky.
Mt. Eden Ky.
Side view.
1996 Ram 1500 Sport
1968 road runner
Re: Door to Fender gap [Re: bobs69] #444177
08/20/09 03:44 PM
08/20/09 03:44 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
There is no set dimension. Just get a nice consistant spacing between the quater panel/door, rocker panel/door, and the fender/door.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Door to Fender gap [Re: sixpackbee] #444178
08/20/09 09:11 PM
08/20/09 09:11 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
,.......nothing worse than varing gaps, top to bottom, panel to panel,....if the panels are fresh, meaning ready for primer/paint/etc....I general aim for a 1/4" gap between panels, doors, fender, trunks, hoods, etc....after numerous coats of primer, paint, esp BC/CC the gap will decrease to about 3/16,.....if you start with tight gaps, on vintage cars, after paintwork, you run the chance of paint breaks/chips because the panels may rub for example in the door to fender gap,.....older vehicles weren't designed with tight tolerance opening gaps, that you see on modern vehicles
Mike
this is a 1/4" door gap finish on a 69 RR,....actually measures around 3/16" after paint, I don't "break"(sand) the edges of paint/primer build up when painting a car, after setting gaps during the initial hanging
Re: Door to Fender gap [Re: sixpackbee] #444179
08/20/09 09:21 PM
08/20/09 09:21 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Even the cowl to fender area gets the 1/4" gap treatment, sometimes with 2 nd gen B bodies, panel alignment can be fustrating, it's even worse for someone who has painted a vehicle disasembled, and trying to reassemble it, best to set gaps on panels, leaving them in place prior to painting, as it seems you can never acheive that initial fit, after removing the panel,....if unifom gaps are your goal, you may/will find yourself doing some creative metal work to obtain the gaps you desire,....don't use bondo on edges to create gaps, it will only come back to haunt you later!,....generaly after the cars painted!
Mike
Re: Door to Fender gap [Re: DAYCLONA] #444180
08/20/09 09:31 PM
08/20/09 09:31 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Here's a good shot of a 1/4" door gap on my own personal car, measuring actually 3/16" after paint,....again anything tighter in the fender/door opening you could have contact between the panels, esp at the upper door/cowl/fender opening point
Mike
Re: Door to Fender gap [Re: DAYCLONA] #444181
08/20/09 09:45 PM
08/20/09 09:45 PM
Williamsport, PA
Kingy Offline
Royal Pain
Kingy  Offline
Royal Pain
Williamsport, PA
3/16 about the thickness of a good paintstick.
Re: Door to Fender gap [Re: Kingy] #444182
08/22/09 01:24 AM
08/22/09 01:24 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
After trying to find the same answer, I went with a little under .250 and it wound up at about 7/32ths. (.200 or so)
I am not in paint yet but I think it should be good.
