hemi cuts out #440186
08/16/09 07:56 PM
08/16/09 07:56 PM
hudson valley n.y.
GEORGE68HEMIRR Offline OP
super street
super street
hudson valley n.y.
did some 1/8 mile today...first run she ran great but second and last run engine was cutting out during the run and picked back up at the end .....i have the msd 6 al,pro billet distrib,hvc11 blaster coil...earlier this year i replaced cap and rotor and noticed like rust and crap around the module....scraped and cleaned that....msd 6al is around 11 years old...distrib is around 6 years old....coil around 3 years old.....do you think its electrical??does the box when it goes bad does it go out and on or just die completely.....it was real hot today....over 100...the 6al was real hot to touch....yes its under the hood on front of the inner fender...the car is a 68 roadrunner...572 hemi
Re: engine cuts out [Re: GEORGE68HEMIRR] #440187
08/16/09 08:20 PM
08/16/09 08:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Number 1 thing would be getting the box out from
under the hood
Re: engine cuts out [Re: MR_P_BODY] #440188
08/16/09 08:23 PM
08/16/09 08:23 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
this is a mostly street car....driven... its never done this before
Re: engine cuts out [Re: GEORGE68HEMIRR] #440189
08/16/09 08:49 PM
08/16/09 08:49 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Did you pull a plug and look for a misfire? Those Old MSD 6AL are tough as a piece of flat iron. When the go they go, personally never had one go bad.
Re: hemi cuts out [Re: GEORGE68HEMIRR] #440190
08/16/09 08:52 PM
08/16/09 08:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
So far what have you checked
Re: hemi cuts out [Re: GEORGE68HEMIRR] #440191
08/16/09 08:59 PM
08/16/09 08:59 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
This so called gasoline we have today and that heat???? I wonder if that isn't your problem?
Re: hemi cuts out [Re: MR_P_BODY] #440192
08/16/09 09:03 PM
08/16/09 09:03 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
so far....i just got it off the trailer.....i can sit there and holder her at say 5grand and it dont cut out....i did watch the fuel pressure gauge run up to 9psi while holding the revs...its set for 6psi.....i know...should be 7.5psi....i am just looking for the possiblities
that mallory 250 electric fuel pump is 10 years old too
Re: hemi cuts out [Re: GEORGE68HEMIRR] #440193
08/16/09 09:12 PM
08/16/09 09:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When you say... cutting out... do you mean missing
pull your plugs and take a look, sounds like you dont
tune it up too often
Re: hemi cuts out [Re: MR_P_BODY] #440194
08/16/09 09:23 PM
08/16/09 09:23 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
brand new plugs ,new wires,cap,rotor,fuel filter....how about that rusted msd module that i cleaned up...it dont cut out reving and holding....when i said cutting out....like dead on her face dead ...then it would take off ... the track 116 degrees with my heat gun
i am going take it out for a ride in the morning and see what happens
Re: hemi cuts out [Re: GEORGE68HEMIRR] #440195
08/16/09 09:30 PM
08/16/09 09:30 PM
Hemiroid Offline
Hemiroid  Offline
What fuel system is on it? If it's a mechanical pump it's probably vapor locking or boiling the fuel in the fuel line.
Re: hemi cuts out [Re: GEORGE68HEMIRR] #440196
08/16/09 09:31 PM
08/16/09 09:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well you pretty well got the igition covered except
for the box.... for right now lets say its fine...
look to the fuel system... I got my car so lean
it tried to do the same thing.... is this right off
the line that this occurs
Re: hemi cuts out [Re: MR_P_BODY] #440197
08/16/09 09:39 PM
08/16/09 09:39 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
i am just nailing second when it falls on its face then comes back to life and does fine after that....its not breaking up just dead then on
Re: hemi cuts out [Re: Hemiroid] #440198
08/16/09 09:44 PM
08/16/09 09:44 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
its a mallory 250 electic pump and mallory fuel filter....8an stainless braded to front....bg regulator to 6an braded to carbs
Re: hemi cuts out [Re: GEORGE68HEMIRR] #440199
08/16/09 09:48 PM
08/16/09 09:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Time to try and reproduce the problem.... get the car
hot(up to the temp you run) and do a flow test on
the fuel system... sounds like its starving
Re: hemi cuts out [Re: MR_P_BODY] #440200
08/16/09 09:59 PM
08/16/09 09:59 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
i am looking at 70dusterjohns post and was thinking the same thing and read on someones elses responce about the fuel cell foam breaking up...the launce and the foam blocking it up.....this is a old triangler 20 gallon cell which is say 10 years old...could be??
Re: hemi cuts out [Re: GEORGE68HEMIRR] #440201
08/17/09 04:27 PM
08/17/09 04:27 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
well i removed filter and tore it apart wasnt alot of stuff.....pulled the distributor cap and the stator is all rusted up with the pickup....is that normal heres some pics...
Re: hemi cuts out [Re: GEORGE68HEMIRR] #440202
08/17/09 04:29 PM
08/17/09 04:29 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
hers the filter crap..i guess this rules out the foam coming apart..still have to test the pump
Re: hemi cuts out [Re: GEORGE68HEMIRR] #440203
08/17/09 04:34 PM
08/17/09 04:34 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
is it possible for the fuel cell foam to block off the pick-up during a launch.....i have to get a new filter and launch it and watch the fuel pressure gauge which i didnt get a chance to do
Re: hemi cuts out [Re: GEORGE68HEMIRR] #440204
08/17/09 05:13 PM
08/17/09 05:13 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
this could be a problem too....should put the pump and filter under the pickup
Re: hemi cuts out [Re: GEORGE68HEMIRR] #440205
08/17/09 06:02 PM
08/17/09 06:02 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
i was just talking to my buddy and he heard my car popping like crazy as it went down the track....i shift at 6800 and the rev limiter is set at 7200..i have that dial job instead of the pills..so i am not running into that
