1972 fender tag code list #439948
08/16/09 02:54 PM
08/16/09 02:54 PM
NE Ohio
ixelerate Offline OP
Go Buckeyes!
Go Buckeyes!
NE Ohio
Hi all, I'm getting ready to sell my car and would like to list the fender tag info on my car. Unfortunately, the car has no tag, but since it is an original car it has all it's original options. Could someone point me to a list of all options so I could piece together my tag? thanks very much!!
[img][/img][img]http://i277.photobucket.com/albums/kk45/ixelerate/random/falcon.gif[/img]
Re: 1972 fender tag code list [Re: ixelerate] #439949
08/16/09 03:22 PM
08/16/09 03:22 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Are you going to make or purchase a "Fake" tag?
Depending on the rarity of the model and the target market for the car, having the "Original" fender tag can affect the sale price / value of the car.
Just depends who is buying it and why.
That said, You "could" look for the Original Factory Build "Broadcast Sheet" (usually found under seats, under / behind the rear seats, etc, but it may have disappeared over time.
Finally, you could write down the Options / Standard Equipment items you have on the car, and Decode / Translate these into the Factory Code numbers.
Here is a fairly good Tag Decode List:
Tag Decode List
Re: 1972 fender tag code list [Re: D_C] #439950
08/16/09 03:30 PM
08/16/09 03:30 PM
NE Ohio
Go Buckeyes!
Go Buckeyes!
NE Ohio
Yes, this is what I had been planning on doing. The car is very original, but was involved in an accident where the front left fender was replaced and the fender tag never put back on. I am planning on just decoding what the car has now. I know already it has the E-Z order package, and some other smaller options. I just want a list so I could list the fender codes for potential buyers. I have already checked under seats for buildsheet. Thank you for the list! I assume it is very close to what a 72 would have.
Re: 1972 fender tag code list [Re: ixelerate] #439951
08/16/09 03:46 PM
08/16/09 03:46 PM
D_C Offline
D_C  Offline
Should be "similar" if not identical code numbers, 1971 versus 1972. There "may" be some difference, but from all I have seen, not much if any.
Re: 1972 fender tag code list [Re: ixelerate] #439952
08/16/09 10:45 PM
08/16/09 10:45 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
A couple of thoughts....
Lynch Road cars (A plant) have minimal option codes on the tag. STL built cars will have more codes.
Not all option or package codes were listed on the tag.
What was listed changed from year to year and plant to plant.
Due to the complexities of determining options and whether they were or were not coded on the tag, you would probably be better off just listing what options or features your car has in your ad instead of trying to reconstruct what was on the tag.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
