oil pan removal ? #437903
08/14/09 05:10 PM
08/14/09 05:10 PM
Allenton Mi
dodgecharger68 Offline OP
Allenton Mi
I have a 1968 satellite. I wont to remove the oil pan. Do I need to unbolt the motor mounts and lift the motor to remove the pan and replace.its just a stock pan being replaced by a stock pan. Thanks for the help!!!
Re: oil pan removal ? [Re: dodgecharger68] #437904
08/14/09 05:37 PM
08/14/09 05:37 PM
St. Paul, Mn.
Jim_S Offline
Jim_S  Offline
St. Paul, Mn.
Here is how I did mine in a 69 Roadrunner auto. Disconnect neg. batt. cable, disconnect the centerlink so it can be swung away, remove inspection cover, un-do pan bolts. On mine I had to move the pan against the flex plate to clear the oil pickup. if the front is still hung up, you can turn the engine by hand so the crank finds a high spot up front.
69 Roadrunner 383 stock
Re: oil pan removal ? [Re: dodgecharger68] #437905
08/14/09 09:21 PM
08/14/09 09:21 PM
Allenton Mi
Allenton Mi
Thank you very much I will try that.
Re: oil pan removal ? [Re: Jim_S] #437906
08/14/09 11:13 PM
08/14/09 11:13 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Makes it easier if you undo the mounts and lift the engine also.I can do my 8qt pan in the 65 with no trouble doing that.There isnt very much room between the K and the bolts that hold the pan on.Rocky
Chrysler Firepower
