Siamese Bore R3's for Street Use #437828
08/14/09 03:52 PM
08/14/09 03:52 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Do you guys drill them between the bores for better cooling or no?
Re: Siamese Bore R3's for Street Use [Re: Hot 340] #437829
08/14/09 04:24 PM
08/14/09 04:24 PM
Phoenix, Arizona
HerboldRacing Offline
Phoenix, Arizona
The whole point of a siamese bore block is to allow you to have bigger bores due to lack of water jacket between cylinders. These are really expensive blocks... and the thought of drilling out water passages between bores make me want to cry.
Give the block to me!
Marvin Herbold 1973 Plymouth Duster 340 Drag Car Blog - http://www.HerboldRacing.com Videos - http://www.YouTube.com/mherbold Pictures - http://gallery.herbold-family.com/main.php?g2_itemId=10331
Re: Siamese Bore R3's for Street Use [Re: HerboldRacing] #437830
08/14/09 04:41 PM
08/14/09 04:41 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
I am pretty sure Chevy 400's were siamese bore, and they have logged hundreds of thousands of street miles
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Siamese Bore R3's for Street Use [Re: B3422W5] #437831
08/14/09 04:47 PM
08/14/09 04:47 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Thanks Don, just read some stuff in Jim Szilagyi's book that said it should be done, but some of his other info made me question his techniques...a little outdated maybe.
Re: Siamese Bore R3's for Street Use [Re: Hot 340] #437832
08/14/09 05:11 PM
08/14/09 05:11 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Some blocks have been drilled between cylinders. You drill at an angle back to the water jacket. If you look a lot of the circle track heads had water passages drilled between cylinders. Most head gaskets have two small holes between cylinders this is where the hole starts and is angled about 45 degree towards the water jacket.
Simply because you are asking I would say do not do this. This mod is for someone who is fully aware of the problems they may cause and what bore they can get away with after doing this.
Leon
Re: Siamese Bore R3's for Street Use [Re: Leon441] #437833
08/14/09 05:50 PM
08/14/09 05:50 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Leon
Maybe you could enlighten us all...?
As I understand it, the holes are not there to flow water> They are mainly just steam escape holes. The holes can be very small, and should not effect strength much at all. All low deck R3's I've seen already have this done. The only one's I've seen that don't have the steam holes are tall decks...
Mopar doesn't put any further bore limitations on a tall deck then they do a short deck?
Re: Siamese Bore R3's for Street Use [Re: B3422W5] #437834
08/14/09 07:35 PM
08/14/09 07:35 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
All chevys have steam holes in the 400 block
Re: Siamese Bore R3's for Street Use [Re: dizuster] #437835
08/15/09 10:11 AM
08/15/09 10:11 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Leon
The reason for the bore limit is because once the holes are drilled, you can't get the max bore out of the block anymore. You need to keep enough metal between the piston and steam jacket so you don't blow thru
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Siamese Bore R3's for Street Use [Re: Hot 340] #437836
08/15/09 05:37 PM
08/15/09 05:37 PM
i drill the 3 lower holes. (most blocks already have the center hole between the middle cylinders drilled) as well as the heads. just like a chevy 400.
Re: Siamese Bore R3's for Street Use [Re: DemonDust] #437837
08/16/09 07:13 AM
08/16/09 07:13 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Obviously if you drill a big hole in the wrong spot it can cause weakness issues. But done properly, I don't see how it can hurt much unless you're really trying to get every .001" of bore you can out of it.
Like I said short deck R3 blocks already have steam holes right from Mopar. Tall deck R3's do not. But Mopar doesn't put any different bore limitations on either...
Re: Siamese Bore R3's for Street Use [Re: dizuster] #437838
08/16/09 10:29 AM
08/16/09 10:29 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
My R5 also has the steam holes in it, but they Look to be in a different location than the few R3 race blocks I've come across..
SDG Motorsports
Re: Siamese Bore R3's for Street Use [Re: DemonDust] #437839
08/16/09 11:02 AM
08/16/09 11:02 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Here is a pic of my old 9.600" deck R3 bored 4.245". There would have been no issue with steam holes at this bore as they start from a 4 O'clock position and are angled 45 degrees from the deck surface entering the water jacket.
The issue with this block if had had steam holes "may" have been when repairing the block with sleeves. This block had two next to each other on #6 and #8 that worked well.
Leon
Re: Siamese Bore R3's for Street Use [Re: Leon441] #437840
08/16/09 11:05 AM
08/16/09 11:05 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
This is a pic of my 358WC R3 9.00" deck block. This block has a 4.200" bore. The pic is not that good but the steam holes are there between all cylinders.
Re: Siamese Bore R3's for Street Use [Re: Leon441] #437841
08/16/09 11:12 AM
08/16/09 11:12 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Here is a pic of a stock block 69' 340 that was done before there were better blocks. It is sleeved and 3/4 filled bored 4.125". No steam holes and driven on the street when it was 4.100" bore.
Re: Siamese Bore R3's for Street Use [Re: Leon441] #437842
08/16/09 03:37 PM
08/16/09 03:37 PM
south louisiana
lowell66dart Offline
south louisiana
That book about building big inch smallblocks that came out a few years ago has some info about drilling siamese R3 blocks.
2021 Dodge 2500 4WD Cummins
2020 Challenger R/T Scat Widebody
2007 Charger R/T 5.7
