Re: Siamese Bore R3's for Street Use
[Re: B3422W5]
#437831
08/14/09 04:47 PM
08/14/09 04:47 PM
Posts: 3,396 Pa
Hot 340
Pa
I am pretty sure Chevy 400's were siamese bore, and they have logged hundreds of thousands of street miles
Thanks Don, just read some stuff in Jim Szilagyi's book that said it should be done, but some of his other info made me question his techniques...a little outdated maybe.
[Re: Hot 340]
#437832
08/14/09 05:11 PM
08/14/09 05:11 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Some blocks have been drilled between cylinders. You drill at an angle back to the water jacket. If you look a lot of the circle track heads had water passages drilled between cylinders. Most head gaskets have two small holes between cylinders this is where the hole starts and is angled about 45 degree towards the water jacket.
Simply because you are asking I would say do not do this. This mod is for someone who is fully aware of the problems they may cause and what bore they can get away with after doing this.
Leon
[Re: Leon441]
#437833
08/14/09 05:50 PM
08/14/09 05:50 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Leon
Maybe you could enlighten us all...?
As I understand it, the holes are not there to flow water> They are mainly just steam escape holes. The holes can be very small, and should not effect strength much at all. All low deck R3's I've seen already have this done. The only one's I've seen that don't have the steam holes are tall decks...
Mopar doesn't put any further bore limitations on a tall deck then they do a short deck?
[Re: dizuster]
#437835
08/15/09 10:11 AM
08/15/09 10:11 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
Leon
The reason for the bore limit is because once the holes are drilled, you can't get the max bore out of the block anymore. You need to keep enough metal between the piston and steam jacket so you don't blow thru
[Re: Hot 340]
#437836
08/15/09 05:37 PM
08/15/09 05:37 PM
i drill the 3 lower holes. (most blocks already have the center hole between the middle cylinders drilled) as well as the heads. just like a chevy 400.
[Re: DemonDust]
#437837
08/16/09 07:13 AM
08/16/09 07:13 AM
dizuster
Oakland, MI
Obviously if you drill a big hole in the wrong spot it can cause weakness issues. But done properly, I don't see how it can hurt much unless you're really trying to get every .001" of bore you can out of it.
Like I said short deck R3 blocks already have steam holes right from Mopar. Tall deck R3's do not. But Mopar doesn't put any different bore limitations on either...
[Re: DemonDust]
#437839
08/16/09 11:02 AM
08/16/09 11:02 AM
Leon441
Lynchburg, VA
Here is a pic of my old 9.600" deck R3 bored 4.245". There would have been no issue with steam holes at this bore as they start from a 4 O'clock position and are angled 45 degrees from the deck surface entering the water jacket.
The issue with this block if had had steam holes "may" have been when repairing the block with sleeves. This block had two next to each other on #6 and #8 that worked well.
Leon
[Re: Leon441]
#437840
08/16/09 11:05 AM
08/16/09 11:05 AM
Leon441
Lynchburg, VA
This is a pic of my 358WC R3 9.00" deck block. This block has a 4.200" bore. The pic is not that good but the steam holes are there between all cylinders.
[Re: Leon441]
#437841
08/16/09 11:12 AM
08/16/09 11:12 AM
Leon441
Lynchburg, VA
Here is a pic of a stock block 69' 340 that was done before there were better blocks. It is sleeved and 3/4 filled bored 4.125". No steam holes and driven on the street when it was 4.100" bore.
[Re: Leon441]
#437842
08/16/09 03:37 PM
08/16/09 03:37 PM
Posts: 885 south louisiana
lowell66dart
south louisiana
That book about building big inch smallblocks that came out a few years ago has some info about drilling siamese R3 blocks.
2021 Dodge 2500 4WD Cummins 2020 Challenger R/T Scat Widebody 2007 Charger R/T 5.7
