Page 27 of 41 1 2 25 26 27 28 29 40 41
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: CuriousYella70] #43770
12/23/08 11:13 PM
12/23/08 11:13 PM
Millersville, PA
HemiChallenger Offline OP
Millersville, PA
CuriousYella70 Thanks man! Alls i can say is try it yourself. It takes time to get it right but its a learning expierence. You will learn from it (mostly how NOT to do things ) Best of luck with the project too. Start a thread everyones comments really help you stay on track with it
WILD BILL I look back at the forum once and awhile and always cannot believe the difference. I also always see picture that make me remember stuff that was done. Your thinking for what it will look like is exactly what it will look like. Blacked out. Black body, bumps, R/T lights, stripes, interior. I will be putting on some polished Alum. or chrome wheels, never was a fan of black wheels, thats when it too black, just looks gothic to me
Thanks Joe and Bill. Color Is on the way soon May be painting a few of the pieces here soon. Since its black you really dont have a problem of the panels being different shades
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: HemiChallenger] #43771
12/27/08 12:08 PM
12/27/08 12:08 PM
Millersville, PA
Millersville, PA
Well No color just yet but more prep work pictures...First off the quarter panel extensions had some pits in them so filled them in and smoothed them up, Sanded BEA parts donated mirror, and finished going at the fenders again...
Then sprayed on second coats all of the above pieces and a third on the rear valance...
Wet sanded the body on everything but the roof, resprayed the roof, fixed little imperfections on the body and put some primer over those areas too...
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: HemiChallenger] #43772
12/28/08 12:13 AM
12/28/08 12:13 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Looking good!
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: 69Cuda340S] #43773
12/29/08 10:07 PM
12/29/08 10:07 PM
Millersville, PA
Millersville, PA
Thanks Bill!
Well Got the engine bay sanded down and ready for paint completely...
Then went to put the hood and fenders on to check for some gaps and placement of the hinges. The car is going to be painted with the hinges and fenders on so to find the right location of them they were put on and checked for gaps. Well the passenger side hinge is no good. It will not pass the first tooth on there so donor hinges are to be used. You can see the first signs of color. Sprayed black on the areas that are covered up so they have color on them, the rest is left for when the entire car is to be sprayed...
Sanded on the decklid some. It has too large low spots on it, most likely from someone sitting on it but they need some light filler to bring up to par...
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: HemiChallenger] #43774
12/30/08 12:05 PM
12/30/08 12:05 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I can't wait
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: WILD BILL] #43775
12/30/08 07:00 PM
12/30/08 07:00 PM
Millersville, PA
Millersville, PA
Alright so today wasnt anything to much special, but did make progress. Good things happened today...
First before any finishing work was done to the hood i wanted to get the hood pins drilled and mocked up. Got this kit for the car last christmas from my girlfriend
Put the rod in its location then put paint on the top of them and closed the hood to make sure they closed where they should...you can see the dot of black at the top...
Once the main hole was drilled (drilled it larger than factory but think weight savings ) put the gasket down and drilled the four screw holes. Then put the bezel on and threaded the screws...
Also worked on getting the front end aligned. Had to swap hinges today too. I stole them from my challenger so i need to find a set for them. The gaps look good and everything is lining up good as well...
Also sprayed the decklid in primer again and then did the final sand on the valances (paint for them is tommarrow
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: HemiChallenger] #43776
12/30/08 07:29 PM
12/30/08 07:29 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Can't wait to see color. I still remember that car at your BBQ sitting behind your shed with the floor totally rusted out. I walked back and took a close look and it looked really bad. It didn't look savable from what I remember seeing. What a long way it has come.
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: 69Cuda340S] #43777
12/31/08 07:30 PM
12/31/08 07:30 PM
Millersville, PA
Millersville, PA
Thanks Bill. It has come a long way and its almost unreal to think its almost one color This car really is not my personal taste but i have so many hours in it that this will be another one to take to the grave
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: 69Cuda340S] #43778
12/31/08 07:36 PM
12/31/08 07:36 PM
Millersville, PA
Millersville, PA
Well that long awaited day is here (not fully but it is very satisfying...COLOR!
Layed down the basecoat on the valances, quarter extensions, and mirror
Then layed down the clear, it is awesome to see this stuff in color and just think of what it looked like originally
Also in between the drying times did some work to the hood and gave it another coat
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: HemiChallenger] #43779
01/01/09 01:50 PM
01/01/09 01:50 PM
Tri-Cities, Washington
V
VITC_GTX Offline
VITC_GTX  Offline
V
Color!!!!
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: VITC_GTX] #43780
01/02/09 11:03 AM
01/02/09 11:03 AM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
This has been so much fun to follow. And now COLOR!
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: DynoDave] #43781
01/02/09 07:23 PM
01/02/09 07:23 PM
Thunder Bay,ON
LilRedDave Offline
LilRedDave  Offline
Thunder Bay,ON
Color good It's been so long now but what the original colors and what is the combo you decided to go with again?
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: LilRedDave] #43782
01/03/09 09:39 AM
01/03/09 09:39 AM
Millersville, PA
Millersville, PA
Thanks guys! All the painted parts are now buffed and wrapped up awaiting final assembly
LilRedDave The original color of the car was White with vinyl top (color unknown), and it had the rare gunmetal interior
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: HemiChallenger] #43783
01/04/09 02:56 PM
01/04/09 02:56 PM
Austria
3eighty3 Offline
3eighty3  Offline
Austria
What an amazing project! I've never seen anyone replace so many small bits and pieces on a car. Thumbs up for saving that one
thomas
______________________________________
cuda blog
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: 3eighty3] #43784
01/04/09 07:22 PM
01/04/09 07:22 PM
Millersville, PA
Millersville, PA
Thanks Thomas. The car had every panel replaced or patched on it except for the front fenders and frame.
Did some more work. First off the did the final sanding on the roof, doors, and fenders. Fixed some tiny areas on the doors and fenders, will be ready for paint after sanded there...
Also blasted some items that we will need for paint. Did all sorts of little brackets, the sidemarkers, and most importantly BOLTS!
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: HemiChallenger] #43785
01/05/09 06:46 AM
01/05/09 06:46 AM
Austria
3eighty3 Offline
3eighty3  Offline
Austria
Great progress Steve! Won't the paint scratch off the bolts once you tighten them?
thomas
_______________________________________________
cuda blog
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: 3eighty3] #43786
01/05/09 07:57 AM
01/05/09 07:57 AM
Millersville, PA
Millersville, PA
thomas
cuda blog
Yes it will but i am putting all the bolts on the front end NOW so they wont have to be touched after paint
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: HemiChallenger] #43787
01/05/09 07:32 PM
01/05/09 07:32 PM
Millersville, PA
Millersville, PA
Alright guys so today i pulled the fenders off the car for the last time. Sprayed them in the areas that will be covered/hard to reach areas. Then did the same to the underside of the inner fenders. Then put them back on with the correct original bolts, aligned the fenders to the hood and doors and now the fenders wont be removed again!
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: HemiChallenger] #43788
01/05/09 10:16 PM
01/05/09 10:16 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Getting closer!!
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: 69Cuda340S] #43789
01/05/09 10:51 PM
01/05/09 10:51 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
That's what I call attention to details
