Re: Degreeing a cam in..
[Re: VernMotor]
#437222
08/13/09 09:44 PM
08/13/09 09:44 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I like duration at .050 /2 -32 268.5 /2 = 134.25 - 32 = 102.25 or your way. I have a milidon gear drive and you set the cam @ .050 then turn crank to desired BTDC number then line the top gear up to inner hub there are seven bolt holes. then go through various methods of checking @ .050 .0200 .050 before and after max lift and so on! I like where you are going to degree it help the big girl get moving!!! ![](/ubbthreads/images/graemlins/wrench.gif)
[Re: BobsProFab]
#437224
08/13/09 09:50 PM
08/13/09 09:50 PM
Posts: 1,163 Newark, OH
Hunted Duck
Newark, OH
i do it @ .050 before and after max lift add then divid by 2
Bob
This is how I do mine also.
[Re: BobsProFab]
#437225
08/13/09 09:52 PM
08/13/09 09:52 PM
Posts: 1,532 off the grid
340B5
off the grid
I do it the same, after setting 0 the same way on the crank degree wheel.
Yeah, it's got a smallblock.
[Re: BobsProFab]
#437226
08/13/09 09:52 PM
08/13/09 09:52 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
Bob
I did that also..it come out the same way..
[Re: Dodgem]
#437227
08/13/09 09:54 PM
08/13/09 09:54 PM
VernMotor
Mt.Vernon ,Ohio
Yea I had it at 104.5 ..thought this might help
[Re: VernMotor]
#437228
08/13/09 10:01 PM
08/13/09 10:01 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Ok let talk about this some..I wanted my cam in at 102. numbers are intake open at 32 deg and close at 56.5 . that is @ .050 after opening and .050 before closing. Now there are two-three ways to do this.. Not saying any one way is wrong. This is how I do it.. might be wrong ??
add 32+56.5 + 180 = 268.5 div by 2 =134.25 - 32 =102.25 show me your numbers and how you do it.
Jamie thats the same way I check the numbers but when I install it I sorta cheat. I have a gear drive so I would (in your case) set the crank to 102 and have the #1 intake at the top with my indicator on it and slide the idler gear on... then make the before and after(.050) checks to see if its correct and adjust if needed ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Hunted Duck]
#437229
08/13/09 10:05 PM
08/13/09 10:05 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Bob
Make that three
[Re: WILD BILL]
#437233
08/13/09 10:32 PM
08/13/09 10:32 PM
VernMotor
Mt.Vernon ,Ohio
Bob
Make that three
One thing comes in to play here is how your degree wheel reads ..my is broke in to 90 deg segments...not all degree wheels are this way.
[Re: VernMotor]
#437234
08/13/09 10:48 PM
08/13/09 10:48 PM
Posts: 43,292 Bend,OR USA
Cab_Burge
Your doing it the way the cam companys want you to ![](/ubbthreads/images/graemlins/thumbs.gif) I don't like doing the lobe centers that way so I do it at the valve retainers, I also always check the exhaust after getting the intake lobe center where I want it. This makes sure the cam lobe centers are ground correctly on both lobes, the exhaust lobe center should be retarded the exact same amount the intake lobe is advanced. IE Lobe seperation angles are 108, you install the cam with four degrees advance on the intake lobe, which means the intake lobe is installed at 104 max lift after top dead center, the exahust lobe max lift should be exactly at 112 BTDC ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: VernMotor]
#437235
08/13/09 10:50 PM
08/13/09 10:50 PM
WILD BILL
BROOK PARK, OH
Ari440
First you need to find true TDC. Use a stop and bring the piston up to it and record the reading (i.e. 10* to the right of 0). Now go backwards till the piston hits the stop. If the reading is the same (10* to the left of 0) you have TDC. If not adjust the pointer (or move the wheel) till the #'s are the same on either side of 0 TDC.
Now place your dial indicator on the intake liffter. Bring the lifter to max lift and zero the indicator. Now rotate untill you read .050 and record the #. Rotate back to 0 (max lift) and continue till you read .050 the other way. Record this #.
Add the 2 #'s togheter and divide by 2 and that is your intake CL. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: WILD BILL]
#437236
08/13/09 11:09 PM
08/13/09 11:09 PM
MR_P_BODY
Bob
Make that three
I do the install like you guys are saying with the .050 before and after, add then /2 For what Cab is saying about checking at the valve, I dont usually check it there.... I just advance the cam basically to give more torque and compensate for the valve train loss ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Ari440]
#437240
08/14/09 07:16 AM
08/14/09 07:16 AM
WILD BILL
BROOK PARK, OH
THANK YOU VERY MUCH BILL
