70/71 A body rally gauge cluster "no tach option" #435602
08/12/09 02:10 PM
08/12/09 02:10 PM
NC
alpha727 Offline OP
alpha727  Offline OP
NC
I read that the tach was an option for the 70/71 duster 340. Does anyone have a pic of a 70/71 A body rally cluster without a tach? Thanks
Re: 70/71 A body rally gauge cluster "no tach option" [Re: alpha727] #435603
08/12/09 02:52 PM
08/12/09 02:52 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
They just had a blank filler peice with some white rings painted on it.
This is an early barracuda, but all the rallye dash equiped a-bodies without a tach used the same part. It's hard to see, but you can make out the white circles.
http://andy440.com/com_July_2008.htm
Re: 70/71 A body rally gauge cluster "no tach option" [Re: Neil] #435604
08/12/09 03:08 PM
08/12/09 03:08 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's a 71 340 A-body no tach gauge pod
Re: 70/71 A body rally gauge cluster "no tach option" [Re: Neil] #435605
08/12/09 03:10 PM
08/12/09 03:10 PM
NC
alpha727 Offline OP
alpha727  Offline OP
NC
thanks
Re: 70/71 A body rally gauge cluster "no tach option" [Re: alpha727] #435606
08/12/09 03:25 PM
08/12/09 03:25 PM
Canada
Mr_Heaterbox Offline
Canada
Hi, just to let those know that are redoing this style of cluster that we make a PAINT MASK (you cannot decal this with overlays since the rings are raised plastic)for this insert that allows you to first paint the whole thing with a nice fresh black and the apply the mask over the dry black paint. You then spray it with white and peel the mask off leaving the white rings. Much neater than trying to brush paint or paint pen it.
FWIW, similar masks are available for the non-rallye dash gauges and delete panels for 68-70 B body standard (non-rallye dash).
Hope that tidbit might be helpful to somebody. -Brent
