Page 13 of 41 1 2 11 12 13 14 15 40 41
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: HemiChallenger] #43490
02/06/08 09:42 AM
02/06/08 09:42 AM
St Charles MO
70Coronet500Vert Offline
St Charles MO
Put in heat and AC. You will never regret it
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: 70Coronet500Vert] #43491
02/14/08 04:20 PM
02/14/08 04:20 PM
Millersville, PA
HemiChallenger Offline OP
Millersville, PA
Hey guys, just got back from a ski trip in vermont so havent been able to work on the bee obviously. But here is some stuff that got done the last two days...
The top of the drivers quarter was pretty well rotted as seen below...
So i cut a section out of the sunroof charger donor to patch it, its not the exact piece since its was junk too but it can work with some modification...
Then here she is welded in place...
Then back to the tail panel rot issue This car is so rusted
Here is the tail panel extension that we have to use drilled off...
Here is a patch for the top of it from the first donor car...
Then i drilled this piece apart to fix the right way...
I'll finish that piece up next and hopefully lay the whole back end in together before we start welding...
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: HemiChallenger] #43492
02/15/08 08:48 AM
02/15/08 08:48 AM
St Charles MO
St Charles MO
How many spot weld bits you gone through to date and how much are they are why aren't they in your budget numbers?
1970 Coronet Vert
1972 Charger
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: 70Coronet500Vert] #43493
02/15/08 08:52 AM
02/15/08 08:52 AM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
because most people dont figure in cost of materials till the end! those blair bits are reiliant if you keep the rpm low they last and last I dont have that kind of patiance so i tend to go thru them!
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: 70Coronet500Vert] #43494
02/15/08 09:01 AM
02/15/08 09:01 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I wonder if he's using reg drill bits? If so that would be cheap on the budget.
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: 70Coronet500Vert] #43495
02/15/08 10:23 AM
02/15/08 10:23 AM
Millersville, PA
Millersville, PA
Those numbers are not going to factored until the end. I will add a material cost for bits(5 packs as of now) and 6 cans on primer right now. I want to wait until all the hole drilling is dont and all the primer usage is done. Pretty much once the sheetmetal work is complete.
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: HemiChallenger] #43496
02/15/08 01:00 PM
02/15/08 01:00 PM
Appleton, Wisconsin
rtmike Offline
rtmike  Offline
Appleton, Wisconsin
This is one of my favorite posts ever! You guys are doing a great job on that car, and 71 Superbees are awesome cars to boot. Keep up the good work. It goes to show you that you do not need $250,000 to build a cool car!
Its not primer its perma gray.
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: rtmike] #43497
02/15/08 01:24 PM
02/15/08 01:24 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
nice work, guys. I guess I'd be considered young too, and it gives me hope that I can get the Demon looking sharp in $5,000 or so
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: sharpie] #43498
02/15/08 03:38 PM
02/15/08 03:38 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
you can use some cutting oil to help the life of the bits dramatically...
rapid tap is the best IMO
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: DJVCuda] #43499
02/15/08 07:30 PM
02/15/08 07:30 PM
Millersville, PA
Millersville, PA
Thanks guys for the compliments. I do use the lube made by blair with the tools to help but i consider 5 packs at most likely 1800 spot welds cut not to be too terrible.
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: HemiChallenger] #43500
02/15/08 09:36 PM
02/15/08 09:36 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Keep drillin
imagine if you had the drill welds in the Bee too instead of just peeling them apart you'd be up around 3600 drilled
I saw that car and I knew it was rough but not that rough... You guys are learning alot with that one...
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: QuickBpBp] #43501
02/15/08 11:55 PM
02/15/08 11:55 PM
Millersville, PA
Millersville, PA
Keep drillin
Funny you say that, the whole floor, trunk floor and back end was pretty much chisseled off lol. Wait until you see the post later tonight of what i just had to salvage to make the car work, i feel like this was a hand built car having to fab up all these pieces lol. Stay tuned
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: HemiChallenger] #43502
02/16/08 02:17 AM
02/16/08 02:17 AM
Millersville, PA
Millersville, PA
Did some more work today, mostly fabrication and fixing of some of the more seriously rusted out areas.
Here is the two extension pieces that go from the trunk extensions to the frame crossmember. As you can see the one is okay but the other is junk, sadly this is the best one from all three cars, so it had to be used.
I cut the upper lip and then the piece in half for the most part...
Here is what will be the new side...
Cut out the relief cut and the angled area at top...
Here are the two tabs i made...
Welded up the made up piece...
The one new tab welded on...
The finished product...
Also did the tail panel extension, top piece welded on...
Bottom piece fabricated and then welded on...
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: HemiChallenger] #43503
02/16/08 12:05 PM
02/16/08 12:05 PM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
You know...seeing your work continues to keep me going on my project without fear or concern of what lay ahead. Keep it up.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: EWJ] #43504
02/16/08 04:58 PM
02/16/08 04:58 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I love seeing this come together. I can't wait to see the finished product. I know it's been said before but you guys are doing an awesome job.
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: WILD BILL] #43505
02/17/08 12:01 AM
02/17/08 12:01 AM
Millersville, PA
Millersville, PA
Alright guys, no work today and a free day to work on the car! Got quite a bit done, i should have the back end completely tied together by the end of the day monday if all goes well. Had a lot of small prep work to do to get it this far like welding certain parts together so they would fit back in the car. I have to remove all the metal that was in the back end so i could punch holes to weld to other parts, borrowed the local farmers air punch and drilled them out to 3/8"...
I found a piece that will work for the curved part of the upper quarter, welded it on...
Mocked up everything in the rear end...
Put a few tack welds down so i could put the extensions on so i know they fit...
Did some more tacks, and placed the tail panel in...
She still needs some final adjustments and a mock up with those stupid big old brackets from the truck floor to the tail panel but other than that the fit looks pretty good...
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: HemiChallenger] #43506
02/18/08 09:10 PM
02/18/08 09:10 PM
Millersville, PA
Millersville, PA
Forgot to add, there was more rust found, this i some nasty stuff, unsure of how exactly i will go about repairing it but its going to have to be done...
Its part of the inner structure and its in a very tight work space
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: HemiChallenger] #43507
02/21/08 01:15 AM
02/21/08 01:15 AM
Clovis,NM
Dartman318 Offline
Dartman318  Offline
Clovis,NM
I have been silently following this thread.
I was brought home from the hospital in this 74' Charger.
Keeping her shaded by a Mesquite Tree....I like
A-bodies.
Need any little misc. stuff?
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: Dartman318] #43508
02/21/08 11:57 PM
02/21/08 11:57 PM
Millersville, PA
Millersville, PA
Dartman318 Actually there is all kinds of little nick nacks we need. Things like Door handles, strikers, door locking bars, hood latch and others. I'll have to compile a list and let you know...
Been welding a lot lately and just placing and double checking everything mostly. But greg took off the rear valance brackets from the tail panel and i welded in some patches seen below...
Then also drilled off the passenger spring hanger for the deck lid, it was toast as pictured before. And even better looking underneath it
Re: Project Young Gun: 1971 Super Bee Budget Build [Re: HemiChallenger] #43509
02/24/08 10:00 PM
02/24/08 10:00 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Good to see the rear sheet metal all coming back together. So do you think the deck lid spring hanger/inner wheel well rust happened because of a rear window leak into the trunk?
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
