Re: TTI Exhaust Test
[Re: Chris2581]
#434951
08/11/09 06:45 PM
08/11/09 06:45 PM
Posts: 4,247 Newfoundland
codfish
Newfoundland
.How "loud" are the Ultra Flo's??
They're not loud at all. Until you get on it!! codfish
[Re: MR_P_BODY]
#434953
08/11/09 08:07 PM
08/11/09 08:07 PM
Posts: 1,443 central ohio
nss guy
central ohio
Did you do any jetting for the best in each case
No Jetting changes, believe it or not it's not very sensitive to jetting changes, I run it slightly on the rich side.
[Re: wyoming]
#434954
08/11/09 08:11 PM
08/11/09 08:11 PM
nss guy
central ohio
Thats pretty surprising to me, especially since you had actually pulled the mufflers and pipes from the car, would have thought 60 lbs would have showed up as an adder even if the open headers didn't, pretty suprising, either the engine breathes better with the exhaust on or your tuned for it one.
I found out that after switching from an "H" Pipe to the X-pipe weight did not slow the car down. 100lbs was always a sure tenth with the H-pipe, switched to the X and 100lbs was maybe .03... I had to learn a whole new way to adjust the ET. The X-pipe does add more torque in my opinion.
[Re: nssracer1]
#434957
08/12/09 08:43 PM
08/12/09 08:43 PM
nss guy
central ohio
How big a shot of NOS did you use on those passes?
The pills were stamped 50hp, and the bottle wasn't heated. OOPS!!!!!!!
You tricked me into that answer
[Re: nss guy]
#434959
08/12/09 08:52 PM
08/12/09 08:52 PM
Posts: 6,354 Aurora, Oh.
max_maniac
Aurora, Oh.
On a serious note, In my experience the TTI X-Pipe actually made more power (torque) than open headers. I was actually hoping I could count on picking up .05+ by running uncapped. That is not the case, the X-pipe really helps.
Jim, on a serious note why are you running 10.60's when I know the car will run 10.30's sandbagging
Russ
[Re: nss guy]
#434961
08/12/09 09:42 PM
08/12/09 09:42 PM
max_maniac
Aurora, Oh.
Russ, The car will run 10.30's in 2000 or less DA on Radials. My M/T Radials lasted 52 passes!! I bought bias slicks Friday and they are a sure tenth plus slower. I thought I'd cover the 10.50 index by pulling the exhaust, not the case. Just wanted to pass the info.
Gotcha ---- I have MT's on mine and I should have stayed with the Hoosier radials like I had on the 64. I had good luck with those and ran them for a couple of years before they gave out. However that was on a lighter car and it was only a 9" tire and not a 10.5 so that could have helped with the longevity.
Russ
[Re: nss guy]
#434964
08/13/09 05:52 PM
08/13/09 05:52 PM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
My brothers car has a 3" TTI X-pipe exhaust feeding Borla Race mufflers and 2 1/2" tailpipes over the axles to factory appearing tips. I have been itchin to remove the exhaust to see if it benefits at all. I will be monitoring the wide band oxygen sensor and make the necessary adjustments so the air/fuel ratios are the same for comparison. It would be nice to know if the car didnt benefit from open exhaust because its a real pain in the booty to take the exhaust off at the track.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
