Re: Best fuel injection cleaner?
[Re: 360view]
#432946
08/10/09 12:36 PM
08/10/09 12:36 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Best Ive used is Castle they have a single can Fireball I believe or a 3 can set but for it you need a setup to use one can thru a vacuum line.Rocky
Chrysler Firepower
[Re: Wheeler]
#432951
08/13/09 10:07 AM
08/13/09 10:07 AM
Posts: 7,861 Witness Protection Program
Kudakidd
I've heard Chevron Techron is good but I've never used it - what do you guys like to use?
That's also what I've been told (by BMW techs) and it's what I use.
[Re: goldmember]
#432955
08/15/09 09:24 AM
08/15/09 09:24 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
[Re: 360view]
#432957
08/15/09 09:52 AM
08/15/09 09:52 AM
Posts: 8,162 USA
360view
USA
Hot Rod magazine article on ASNU http://www.hotrod.com/techarticles/engin...ay_pattern.htmlNote the picture of the hole end of a Holley fuel injector. Several years ago the EPA tested the then-available fuel injectors for an unusual project where they retro-fitted a VW TDI engine to run on ethanol and methanol with added spark plugs and added port fuel injectors. The EPA stated that the Holley injectors had the best spray pattern at that time, at least for alcohol spray
