Best fuel injection cleaner? #432942
08/09/09 08:19 PM
08/09/09 08:19 PM
Great White North
W
Wheeler Online content OP
Wheeler  Online Content OP
W
Great White North
Who makes the best fuel injection cleaner? I've heard Chevron Techron is good but I've never used it - what do you guys like to use?
Re: Best fuel injection cleaner? [Re: Wheeler] #432943
08/09/09 08:23 PM
08/09/09 08:23 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I blend my own cleaner,but I've had good results with Berryman B-12.
Re: Best fuel injection cleaner? [Re: Wheeler] #432944
08/09/09 08:28 PM
08/09/09 08:28 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Seafoam
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Best fuel injection cleaner? [Re: Wheeler] #432945
08/10/09 11:28 AM
08/10/09 11:28 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Yamaha Ring Free (expensive at boat stores)
Chrysler official Fuel Injector cleaner
Gumout Regane (clear bottle honey colored liquid)
Redline SI-1
Lubro-Moly Jectron and Ventril Sauber (BMW dealers)
are all good FI cleaners in addition to
Chevron Techron Concentrate Plus (Plus is important)
Re: Best fuel injection cleaner? [Re: 360view] #432946
08/10/09 12:36 PM
08/10/09 12:36 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Best Ive used is Castle they have a single can Fireball I believe or a 3 can set but for it you need a setup to use one can thru a vacuum line.Rocky
Chrysler Firepower
Re: Best fuel injection cleaner? [Re: therocks] #432947
08/11/09 12:28 PM
08/11/09 12:28 PM
Great White North
W
W
Great White North
Thanks for the info everyone. I did some research on various automotive message boards (including bobistheoilguy.com) - Chevron Techron, Redline SI, Amsoil PI and Gumout Regane were the highest rated fuel injection cleaners.
Yesterday, I purchased a bottle of Amsoil PI from Partsource. I put it in the tank of my daily driver (1994 GMC truck) so we'll see how it works.
Re: Best fuel injection cleaner? [Re: Wheeler] #432948
08/12/09 07:33 AM
08/12/09 07:33 AM
USA
3
360view Offline
360view  Offline
3
USA
what one FI cleaner has trouble dissolving
another brand of FI cleaner might successfully handle,
and vice versa
so mix it up and don't use the same brand every time
is my philosophy,
and there was an article in Motor Magazine years ago that recommended the same mix it up strategy
http://web.archive.org/web/20000818062832/http://www.motorage.com/edindex/0600pg032.htm
more on FI cleaner opinions at Moparts in the past
https://board.moparts.org/ubbthreads/show...rue#Post2774863
Re: Best fuel injection cleaner? [Re: therocks] #432949
08/12/09 03:30 PM
08/12/09 03:30 PM
Detroit
HogRidinFool Offline
Detroit
Try Mopar Combustion Clean (05183546AA).
Recommended in tech service bulletins and approved by engineering.
Re: Best fuel injection cleaner? [Re: HogRidinFool] #432950
08/13/09 12:22 AM
08/13/09 12:22 AM
colorado
chargermop Offline
chargermop  Offline
colorado
look for BG 44K best stuff out there bar none ...
Re: Best fuel injection cleaner? [Re: Wheeler] #432951
08/13/09 10:07 AM
08/13/09 10:07 AM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
That's also what I've been told (by BMW techs) and it's what I use.
Re: Best fuel injection cleaner? [Re: 360view] #432952
08/14/09 07:57 AM
08/14/09 07:57 AM
USA
3
360view Offline
360view  Offline
3
USA
can anyone think of a relatively cheap test that an
"average joe"
could run on fuel injector cleaners
that could determine
which are better than others ?
Re: Best fuel injection cleaner? [Re: 360view] #432953
08/14/09 11:12 PM
08/14/09 11:12 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Not trying to burst anyone's bubble here, but I heard a few years ago that injector cleaner is just octane boost. That's why people figure it works so well 'cause suddenly the car/truck feels like it has more power. It made sense to me, after all, what are fuel filters for?
Mo' Farts
Moderated by "tbagger".
Re: Best fuel injection cleaner? [Re: 360view] #432954
08/14/09 11:32 PM
08/14/09 11:32 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Well you could take the injectors in question out and test them,but most won't do it. A common drivability problem is a stall after starting. I have had this problem. With low fuel 4-5 gallons,added my own blend to the tank. The stalling was corrected and that was enough evedence for the time. Most add cleaner without a drivability issue and .
Re: Best fuel injection cleaner? [Re: goldmember] #432955
08/15/09 09:24 AM
08/15/09 09:24 AM
USA
3
360view Offline
360view  Offline
3
USA
Re: Best fuel injection cleaner? [Re: 360view] #432956
08/15/09 09:40 AM
08/15/09 09:40 AM
USA
3
360view Offline
360view  Offline
3
USA
Australian company ASNU video comparing different designs of fuel injectors and their spray patterns and turn-on and cut-off speeds:
http://www.youtube.com/watch?v=NIz5c9MLCls&feature=related
Re: Best fuel injection cleaner? [Re: 360view] #432957
08/15/09 09:52 AM
08/15/09 09:52 AM
USA
3
360view Offline
360view  Offline
3
USA
Hot Rod magazine article on ASNU
http://www.hotrod.com/techarticles/engin...ay_pattern.html
Note the picture of the hole end of a Holley fuel injector.
Several years ago the EPA tested the then-available fuel injectors for an unusual project where they retro-fitted a VW TDI engine to run on ethanol and methanol with added spark plugs and added port fuel injectors.
The EPA stated that the Holley injectors had the best spray pattern at that time, at least for alcohol spray
