Re: who makes the best in car valve spring compressor
[Re: mopar65]
#432800
08/09/09 08:05 PM
08/09/09 08:05 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
or go with John Dibartolomeo, a nice guy and avid racer. DRCraceproducts.com Got mine from him many many years ago.
Valve Spring Removal Tool
Finally a tool designed to work specifically with the high springs pressures of today's engines. This tool, with its detachable handle, will safely remove the valve springs while the cylinder heads are on the motor. Forget about bending or twisting tools, this one's right for the job. It will push the valve spring straight down and make a normally tough job an easy one. In addition to the below specifications, this tool can be had in "custom designed" configurations to fit special applications.
#1010 -- Small Block Chevy w/shaft rocker system "A"=3.495" #1011 -- Big Block Chevy w/shaft rocker system "A"=1.55" to 1.65" #1012 -- Small Block Mopar 318-360, 3.3 liter V6 "A"=4.450" #1013 -- Big Block Mopar 383-440 "A"=4.825" #1014 -- Small & Big Block Chevy w/stud rockers #101013 -- Pivot shaft for Dart Big Chief heads "A"=2.150 & 2.660
RIP Monte Smith
[Re: S/ST 3040]
#432802
08/09/09 08:37 PM
08/09/09 08:37 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
So far, all the engines I've changed springs on, the valve would hit the piston @ TDC before the spring would coil bind.
they will do that when the timing chain or sprocket goes south too. Puts cute little eyebrows on top of the pistons among other nasties.
[Re: moparniac]
#432806
08/09/09 10:22 PM
08/09/09 10:22 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
The one from mancini worked ok for me, no air, no rope, seals held up the valves. They were fairly new. If you have old seals it would be a good time to replace them. Only problem I had was by the master cylinder, seems my right hand fingers worked better than the left one's putting those keepers back in.
[Re: mopar65]
#432807
08/10/09 10:17 PM
08/10/09 10:17 PM
Posts: 46 Macomb Michigan
65 Belv A990
Macomb Michigan
I bought this one from Mancini. It is a little pricey, but when it comes time to change heavy pressure springs it is hard to top this tool. The springs on my Indy SR's are 300 lbs on the seat and 645 lbs open and this compressor does not even break a sweat. I also have always used a piece of nylon rope with the end melted with a lighter stuffed in the cylinder with the piston brought up to top dead center to hold the valves.
Ed.
MoPower..... Better to be a racer for a moment than a spectator for a lifetime.
