who makes the best in car valve spring compressor #432791
08/09/09 04:50 PM
08/09/09 04:50 PM
Central Missouri Fort Leonard...
mopar65 Offline OP
mopar65  Offline OP
For a stock headed big block? I will be changing the springs on my 906 headed 440 big block 73 dart.I will be changing the springs with out pulling the heads. so i am looking for advice on which one to use. also it has to be able to clear tti 2 inch headers.I have a cheep parts store one that has a knob you turn to tightened down the spring. But after using it on my old 65 with some dual valve springs my hands hurt for 2 days. so i am looking for a better way. thanks Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: who makes the best in car valve spring compressor [Re: mopar65] #432792
08/09/09 05:11 PM
08/09/09 05:11 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I made one for my shaft rocker small block out of a old hyd rocker and a piece of flat bar, it works good, cut a notch in the rocker so the valve and keepers fall thru ,you may want to use a old rocker shaft so you don't scratch up a good one
Re: who makes the best in car valve spring compressor [Re: mopar65] #432793
08/09/09 05:41 PM
08/09/09 05:41 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Comp cams model # 5324 is the one I borrowed.....worked like a charm.
Re: who makes the best in car valve spring compressor [Re: Thumperdart] #432794
08/09/09 06:00 PM
08/09/09 06:00 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Re: who makes the best in car valve spring compressor [Re: MoparforLife] #432795
08/09/09 06:26 PM
08/09/09 06:26 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s the same as comps...........like everything else they sell, they claim it`s their own.
Re: who makes the best in car valve spring compressor [Re: Thumperdart] #432796
08/09/09 06:32 PM
08/09/09 06:32 PM
mopar65 Offline OP
mopar65  Offline OP
thanks for the reply's guys that is the one i was thinking about. but could not remember who made it.thanks Mopar65
Re: who makes the best in car valve spring compressor [Re: mopar65] #432797
08/09/09 07:55 PM
08/09/09 07:55 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I have the comp cams one Hyper Henry just left with it a couple hours ago. one hint make sure piston your are working on is at TDC and you may have to tap (hard) retainer with a plastic or brass hammer to unseat the keepers.
I made my air thingy by breaking apart a spark plug and welding a male air end to it
Re: who makes the best in car valve spring compressor [Re: Dodgem] #432798
08/09/09 08:00 PM
08/09/09 08:00 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I never use air.
Re: who makes the best in car valve spring compressor [Re: S/ST 3040] #432799
08/09/09 08:05 PM
08/09/09 08:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My 4 1/2 year old teflon seals held my valves up just fine although I understand sometimes air is mandatory.
Re: who makes the best in car valve spring compressor [Re: mopar65] #432800
08/09/09 08:05 PM
08/09/09 08:05 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
or go with John Dibartolomeo, a nice guy and avid racer. DRCraceproducts.com Got mine from him many many years ago.
Valve Spring Removal Tool
Finally a tool designed to work specifically with the high springs pressures of today's engines. This tool, with its detachable handle, will safely remove the valve springs while the cylinder heads are on the motor. Forget about bending or twisting tools, this one's right for the job. It will push the valve spring straight down and make a normally tough job an easy one. In addition to the below specifications, this tool can be had in "custom designed" configurations to fit special applications.
#1010 -- Small Block Chevy w/shaft rocker system "A"=3.495"
#1011 -- Big Block Chevy w/shaft rocker system "A"=1.55" to 1.65"
#1012 -- Small Block Mopar 318-360, 3.3 liter V6 "A"=4.450"
#1013 -- Big Block Mopar 383-440 "A"=4.825"
#1014 -- Small & Big Block Chevy w/stud rockers
#101013 -- Pivot shaft for Dart Big Chief heads "A"=2.150 & 2.660
RIP Monte Smith
Re: who makes the best in car valve spring compressor [Re: Thumperdart] #432801
08/09/09 08:09 PM
08/09/09 08:09 PM
S/ST 3040 Offline
S/ST 3040  Offline
So far, all the engines I've changed springs on, the valve would
hit the piston @ TDC before the spring would coil bind.
Re: who makes the best in car valve spring compressor [Re: S/ST 3040] #432802
08/09/09 08:37 PM
08/09/09 08:37 PM
Upper Midwest
Upper Midwest
they will do that when the timing chain or sprocket goes south too. Puts cute little eyebrows on top of the pistons among other nasties.
Re: who makes the best in car valve spring compressor [Re: MoparforLife] #432803
08/09/09 08:55 PM
08/09/09 08:55 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Over the winter someone on here said to run a rope in the plug hole with the piston @ tdc and pop the valve springs with no air, works great
Re: who makes the best in car valve spring compressor [Re: emarine01] #432804
08/09/09 09:13 PM
08/09/09 09:13 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
i use the one mancini sells. i use my compressor tester fitting/hose for the air pressure. works great
btw, if theres nothing in the cylinder such as a rope or air to stop the valve from opening, how can you compress the spring without also pushing the valve down at the same time? a valve stem seal cant have enough grip on the valve to hold it while you compress the spring
Re: who makes the best in car valve spring compressor [Re: emarine01] #432805
08/09/09 10:08 PM
08/09/09 10:08 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Thats what I did last time
Mopar Performance
Re: who makes the best in car valve spring compressor [Re: moparniac] #432806
08/09/09 10:22 PM
08/09/09 10:22 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
The one from mancini worked ok for me, no air, no rope, seals held up the valves. They were fairly new. If you have old seals it would be a good time to replace them. Only problem I had was by the master cylinder, seems my right hand fingers worked better than the left one's putting those keepers back in.
Re: who makes the best in car valve spring compressor [Re: mopar65] #432807
08/10/09 10:17 PM
08/10/09 10:17 PM
Macomb Michigan
65 Belv A990 Offline
Macomb Michigan
I bought this one from Mancini. It is a little pricey, but when it comes time to change heavy pressure springs it is hard to top this tool. The springs on my Indy SR's are 300 lbs on the seat and 645 lbs open and this compressor does not even break a sweat. I also have always used a piece of nylon rope with the end melted with a lighter stuffed in the cylinder with the piston brought up to top dead center to hold the valves.
Ed.
MoPower..... Better to be a racer for a moment than a spectator for a lifetime.
