360 Magnum Swap Part 2. Thermostat Housing? #430465
08/07/09 02:18 AM
08/07/09 02:18 AM
Santa Rosa, NOR*CAL.
Just Cameron Offline OP
So when I was trying swap the chrome O-ring thermostat housing from the Edelbrock Performer to my 360 Magnum's RPM Air Gap I realized the LA water neck is way bigger that the one for my Magnum.
The stock one for truck radiators is way taller than I want to use.
10 minutes at the parts counter looking at ALL the Dodge Magnum factory units and all the SB Ford (The same bolt spacing/size as the Magnum) aftermakret chrome and factory units and I can not find one that will work with the stock 26" radiator.
What did you do?
Re: 360 Magnum Swap Part 2. Thermostat Housing? [Re: Just Cameron] #430466
08/07/09 02:32 AM
08/07/09 02:32 AM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
I have a truck one on there
Re: 360 Magnum Swap Part 2. Thermostat Housing? [Re: sharpie] #430467
08/07/09 03:44 AM
08/07/09 03:44 AM
The stamped steel unit?
What radiator hose did you use? Based on a "precise eyeballing" it looks like an earlier molded hose has the bend too far down to use one.
Re: 360 Magnum Swap Part 2. Thermostat Housing? [Re: Just Cameron] #430468
08/07/09 07:49 AM
08/07/09 07:49 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
grab one from a junkyard 5th ave. chrysler switched to the smaller t-stat and housing when they went to the C171 A/C compressor in the '79-80 time frame.
2017 Grand Cherokee Overland
Re: 360 Magnum Swap Part 2. Thermostat Housing? [Re: patrick] #430469
08/07/09 08:14 AM
08/07/09 08:14 AM
this one? ~1&11/16" tall. $15 to your doorstep
Re: 360 Magnum Swap Part 2. Thermostat Housing? [Re: RapidRobert] #430470
08/07/09 10:19 AM
08/07/09 10:19 AM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
Cameron, I used stock radiator hoses from a 74 Duster 360. Each have a couple letters on it - places to cut the hose. I ended up just cutting the hose in one place on each.
Re: 360 Magnum Swap Part 2. Thermostat Housing? [Re: patrick] #430471
08/07/09 10:21 PM
08/07/09 10:21 PM
Good to know! thanks.
Re: 360 Magnum Swap Part 2. Thermostat Housing? [Re: patrick] #430472
08/07/09 10:38 PM
08/07/09 10:38 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
1979 to be exact. Any AutoZone should have a cast iron one for about $10-12. Much better than the stamped steel piece anyway.
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: 360 Magnum Swap Part 2. Thermostat Housing? [Re: 69L78Nova] #430473
08/08/09 02:46 AM
08/08/09 02:46 AM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
It doesn't look too bad, the stamped steel one, does it?
