Moog UCA offset bushings #429191
08/05/09 02:31 PM
08/05/09 02:31 PM
runningman Offline OP
super street
super street
I just want to double check the correct installation of these, a post on another forum mentioned that they should not be installed per the instructions and they should be "installed with the front bushing arrow pointing out and the rear bushing arrow pointing in in order to get a more positive caster" Is this correct? Also do I need the metal ferrules pressed on that came with them also? Thanks!
Matt
Re: Moog UCA offset bushings [Re: runningman] #429192
08/05/09 03:01 PM
08/05/09 03:01 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
http://www.moparts.org/Tech/Archive/susp/18.html
and no you do not need those retainer rings, actually cut them off before you and try and press out the bushing. Don't ask me how I figured that one out... Someone does sell repo's though.
Re: Moog UCA offset bushings [Re: runningman] #429193
08/05/09 03:13 PM
08/05/09 03:13 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Here is the oft-posted picture.
You might have seen one of my replies to a post, and the admonition to "ignore those directions and follow these directions" can indeed cause some concern. Here is a revisit, along with an explanation.
The offset bushing were originally marketed as "problem solvers" to solve the problem of "not enough camber". Therefore, some packages will include printed installation instructions to that end. Rather than try to remember by rote which instructions are the wrong ones, and which are the right ones, consider getting the concept straight. That way, it doesn't matter if you have your computer [or that screen print] handy or not when it comes time to do the job.
The bushings shift the control arm in the direction of the arrow molded into the rubber. If you install both the front and the rear bushings with the arrow pointing outward (as the included instructions might recommend), you are shifting the upper ball joint outboard, which is an increase in CAMBER. This isn't what you want.
If you install the front bushing pointing out, and the rear bushing pointing IN, you are shifting the upper ball joint rearward, which is an increase in CASTER. This IS what you want to do.
It's all about what direction you are moving the upper ball joint.
Down to just a blue car now.
Re: Moog UCA offset bushings [Re: 68HemiB] #429194
08/05/09 03:31 PM
08/05/09 03:31 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
But none the less important and with a good explanation of why...
Re: Moog UCA offset bushings [Re: 68HemiB] #429195
08/05/09 03:31 PM
08/05/09 03:31 PM
super street
super street
Wow, thanks for the timely and educational responses! The ferrules I am talking about are not the sleeves that were on the back side of the bushings but metal washers that look to be pressed on the front and backs of the bushings. I will try and get a pic to post. Thanks again!
Matt
Re: Moog UCA offset bushings [Re: runningman] #429196
08/05/09 03:50 PM
08/05/09 03:50 PM
super street
super street
It appears that these pieces are necessary. The bolts have a lot of play without those. I don't remember anyone mentioning them before though.
Re: Moog UCA offset bushings [Re: Lefty] #429197
08/05/09 03:50 PM
08/05/09 03:50 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I think I wrote that explantion, IIRC. The picture above it with the red circles is Richard Ehernberg's from Mopar Action magazine.
Re: Moog UCA offset bushings [Re: autoxcuda] #429198
08/05/09 04:18 PM
08/05/09 04:18 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
You don't remember correctly.
One of us advocates excessive negative camber in inappropriate applications.
The other used to align cars for a living.
Re: Moog UCA offset bushings [Re: 68HemiB] #429199
08/05/09 05:04 PM
08/05/09 05:04 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
So did you write it? Looks like the text in photoshop LE I use. I can't remember. Maybe I'm thinking of the picture I have of the UCA installed on my car with similar instructions on it.
I usually suggest a 1/4 or so degree negative, but more if you are into handling. The guys that ask for a handling setup or have handling parts on their car. I see a guy putting 17" rims on his car or a tubular UCA, or some sway bars..., I assume he want's to do some halfway agressive handling stuff. I think my assumption is wrong because it seems most are doing big rims just for looks and want to cruise around.
Re: Moog UCA offset bushings [Re: autoxcuda] #429200
08/05/09 06:07 PM
08/05/09 06:07 PM
BDW Offline
BDW  Offline
Actually I put that together. I could never understand why the bushings helped. After researching it, I took Eboogers pic and added the red arrows and text.
Re: Moog UCA offset bushings [Re: BDW] #429201
08/05/09 06:22 PM
08/05/09 06:22 PM
super street
super street
So you guys are installing these ferrules?
Re: Moog UCA offset bushings [Re: runningman] #429202
08/05/09 07:28 PM
08/05/09 07:28 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
I would.
Note to Steve W:
There is text that is part of the image, and text in my post above the image. When someone says "explanation", I take it to be the words in my post, not the text in the image.
Perhaps it is a dessert topping AND a floor wax...
Re: Moog UCA offset bushings [Re: 68HemiB] #429203
08/05/09 07:56 PM
08/05/09 07:56 PM
super street
super street
Thanks!
Re: Moog UCA offset bushings [Re: runningman] #429204
08/05/09 10:40 PM
08/05/09 10:40 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Another picture
Re: Moog UCA offset bushings [Re: autoxcuda] #429205
08/06/09 07:23 AM
08/06/09 07:23 AM
London, England
Gavin Offline
Gavin  Offline
London, England
Yes, use the ferrules. They are a press fit in the bushing ends after installation. A vice will do it fine.
Re: Moog UCA offset bushings [Re: Gavin] #429206
08/06/09 10:46 AM
08/06/09 10:46 AM
super street
super street
Thanks for the info!
Matt
Re: Moog UCA offset bushings [Re: Gavin] #429207
08/06/09 12:16 PM
08/06/09 12:16 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
The accusation has been leveled that I often use more words than necessary.
Here goes again.
Standard UCA bushings have the ferrules delivered as part of the bushing. Their presence does not keep the mechanic from installing them, as the full diameter of the outer shell can easily be accessed by whatever pressing/pounding device he cares to employ. Furthermore, the rotational orientation of the bushing matters not.
Offset UCA bushings are delivered with the ferrules loose because:
1. It would be tough to see the arrow and get across the proper installation orientation.
2. Once installed, the ferrules would obstruct the outer shell of the bushings on the "close" side, preventing the pressing/pounding device to make full contact.
Install the bushings into the control arms, then smack/press the ferrules onto the bushings.
Re: Moog UCA offset bushings [Re: 68HemiB] #429208
08/06/09 12:41 PM
08/06/09 12:41 PM
pgh pa
captaindodge Offline
pgh pa
Your best words so far "consider getting the CONCEPT straight"...
Re: Moog UCA offset bushings [Re: 68HemiB] #429209
08/06/09 12:45 PM
08/06/09 12:45 PM
super street
super street
Here goes again.
Thanks again for the great response!
Matt
Re: Moog UCA offset bushings [Re: runningman] #429210
02/21/12 07:44 PM
02/21/12 07:44 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
The good stuff...
Urethane UCA Offset Bushes
Rick
