Re: Moog UCA offset bushings
[Re: runningman]
#429193
08/05/09 03:13 PM
08/05/09 03:13 PM
Posts: 9,312 SoCal
68HemiB
SoCal
Here is the oft-posted picture.
You might have seen one of my replies to a post, and the admonition to "ignore those directions and follow these directions" can indeed cause some concern. Here is a revisit, along with an explanation.
The offset bushing were originally marketed as "problem solvers" to solve the problem of "not enough camber". Therefore, some packages will include printed installation instructions to that end. Rather than try to remember by rote which instructions are the wrong ones, and which are the right ones, consider getting the concept straight. That way, it doesn't matter if you have your computer [or that screen print] handy or not when it comes time to do the job.
The bushings shift the control arm in the direction of the arrow molded into the rubber. If you install both the front and the rear bushings with the arrow pointing outward (as the included instructions might recommend), you are shifting the upper ball joint outboard, which is an increase in CAMBER. This isn't what you want.
If you install the front bushing pointing out, and the rear bushing pointing IN, you are shifting the upper ball joint rearward, which is an increase in CASTER. This IS what you want to do.
It's all about what direction you are moving the upper ball joint.
Down to just a blue car now.
[Re: 68HemiB]
#429195
08/05/09 03:31 PM
08/05/09 03:31 PM
runningman
super street
super street
Wow, thanks for the timely and educational responses! The ferrules I am talking about are not the sleeves that were on the back side of the bushings but metal washers that look to be pressed on the front and backs of the bushings. I will try and get a pic to post. Thanks again!
Matt
[Re: Lefty]
#429197
08/05/09 03:50 PM
08/05/09 03:50 PM
Posts: 27,467 So Cal
autoxcuda
So Cal
But none the less important and with a good explanation of why...
I think I wrote that explantion, IIRC. The picture above it with the red circles is Richard Ehernberg's from Mopar Action magazine.
[Re: 68HemiB]
#429199
08/05/09 05:04 PM
08/05/09 05:04 PM
autoxcuda
So Cal
You don't remember correctly.
One of us advocates excessive negative camber in inappropriate applications.
The other used to align cars for a living.
So did you write it? Looks like the text in photoshop LE I use. I can't remember. Maybe I'm thinking of the picture I have of the UCA installed on my car with similar instructions on it.
I usually suggest a 1/4 or so degree negative, but more if you are into handling. The guys that ask for a handling setup or have handling parts on their car. I see a guy putting 17" rims on his car or a tubular UCA, or some sway bars..., I assume he want's to do some halfway agressive handling stuff. I think my assumption is wrong because it seems most are doing big rims just for looks and want to cruise around.
[Re: 68HemiB]
#429203
08/05/09 07:56 PM
08/05/09 07:56 PM
runningman
super street
super street
[Re: Gavin]
#429206
08/06/09 10:46 AM
08/06/09 10:46 AM
runningman
super street
super street
[Re: 68HemiB]
#429209
08/06/09 12:45 PM
08/06/09 12:45 PM
runningman
super street
super street
Yes, use the ferrules. They are a press fit in the bushing ends after installation. A vice will do it fine.
The accusation has been leveled that I often use more words than necessary.
Here goes again.
Standard UCA bushings have the ferrules delivered as part of the bushing. Their presence does not keep the mechanic from installing them, as the full diameter of the outer shell can easily be accessed by whatever pressing/pounding device he cares to employ. Furthermore, the rotational orientation of the bushing matters not.
Offset UCA bushings are delivered with the ferrules loose because:
1. It would be tough to see the arrow and get across the proper installation orientation.
2. Once installed, the ferrules would obstruct the outer shell of the bushings on the "close" side, preventing the pressing/pounding device to make full contact.
Install the bushings into the control arms, then smack/press the ferrules onto the bushings.
Thanks again for the great response!
Matt
