Disc brake site back up! #428924
08/04/09 11:43 PM
08/04/09 11:43 PM
Chino Valley
RodStRace Offline OP
Chino Valley
http://www.rustyhope.com/home.html
Is back up. This guy has the disc brake conversions and splits flathead manifolds.
Re: Disc brake site back up! [Re: RodStRace] #428925
08/05/09 11:17 PM
08/05/09 11:17 PM
East TN.
Moparsky Offline
Moparsky  Offline
East TN.
Very cool looking old Mopar truck & love that tractor with the dual rear wheel set-up.
Re: Disc brake site back up! [Re: RodStRace] #428926
08/06/09 11:26 AM
08/06/09 11:26 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Cool
Moparlee
Re: Disc brake site back up! [Re: RodStRace] #428927
09/15/09 02:28 PM
09/15/09 02:28 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
do you know what rotors they use to put disc brakes on a 37 axle??? Ron...
I just sent him an email
Re: Disc brake site back up! [Re: Mopar Ron] #428928
10/22/09 05:47 AM
10/22/09 05:47 AM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
Think they have parts for 41' plymouth?
Re: Disc brake site back up! [Re: migsBIG] #428929
10/22/09 07:26 PM
10/22/09 07:26 PM
Chino Valley
Chino Valley
I don't have experience with his products, but he has very good feedback. I defer all questions to him.
Re: Disc brake site back up! [Re: migsBIG] #428930
10/22/09 10:46 PM
10/22/09 10:46 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
His "kits" consist of caliper brackets, the bearing spacer, and bolts to mount the caliper bracket. Then he gives you a list of parts and numbers from several auto parts chains so you can save money and buy your parts where ever you find the best prices. You do have to retap the bottom spindle bolt holes to a 5/8" fine thread. (He used to offer to do that for you for a fee, if you send him your spindles.) The 39 was the "old" style spindle, and when I was done, the spindle bearing nut and cotter key was real close to the end of the spindle, but it seemed to work OK.
I have install his kits on a 39 Plymouth and a 47 plymouth, both of which had different spindles and contained different parts and different lists. I think he can make you a special kit for a specific application if you need one. He will work with you to be sure everything works. I would do business with him again. Gene
Re: Disc brake site back up! [Re: migsBIG] #428931
10/22/09 11:33 PM
10/22/09 11:33 PM
Mopar Ron Offline
Mopar Ron  Offline
I sent him an email and he sent me this about what rotors to use. Ron...
"The rotor is a Volare/Aspen part, the calipers are GM late 70s Camaro. Bearings are for the Volare rotor."
Re: Disc brake site back up! [Re: Mopar Ron] #428932
10/23/09 05:33 AM
10/23/09 05:33 AM
San Jose,CA
migsBIG Offline
migsBIG  Offline
San Jose,CA
That looks like a very do-able kit. The Master
Power kit requires you to send them youe axle and wait 2 weeks. By the time you ship it there and back, could almost be a month to get them back.
Re: Disc brake site back up! [Re: migsBIG] #428933
10/25/09 03:36 PM
10/25/09 03:36 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Tapping out those 5/8" fine thread holes requires a bit of effort. The spindles are not the most simple things to hold in a vice so you get the threads cut straight, and the required drill and tap can add up pretty quickly. But it is do-able, and those disc brakes work well. Gene
Re: Disc brake site back up! [Re: poorboy] #428934
10/28/09 05:02 PM
10/28/09 05:02 PM
Lithonia, Ga
3
36PLYM Offline
36PLYM  Offline
Lithonia, Ga
I have used the kit for early Mopar cars pictured on his website. I got the kit from Plydo years ago.
It works really well, used 69 Fairlane rotors to get the 4 1/2 inch bolt pattern and late 70's mid size GM calipers. I did not tap out the holes, installed helicoil instead. Good thing about the stock calipers is Wilwood makes a light weight replacement, GMIII, for various discs thickness. I love this stuff!!
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: Disc brake site back up! [Re: 36PLYM] #428935
10/29/09 09:48 PM
10/29/09 09:48 PM
Lemont, IL
Not_A_Blazer Offline
super gas
super gas
Lemont, IL
Thanks for the link,that dual carb manifold conversion doesn't look like a bad deal.
