1st time down the track in 22 years and carnage #427388
08/03/09 02:07 PM
08/03/09 02:07 PM
Davenport, IA
70shaker Offline OP
70shaker  Offline OP
Davenport, IA
Well I fianlly took the Challenger to the track. The last time I was on the track was 22 years ago.
Car ran 12.01 at 118 shifting at 6000 RPM.
Was making the next run with intent on shifting at 7000 RPM and the 8 3/4 let go on the launch.
Time for a Dana
Thanks for all the advice I have received on here getting back up to speed after 22 years.
Ex Hemi Racer
70 Challenger Hemi 4 speed clone
Re: 1st time down the track in 22 years and carnage [Re: 70shaker] #427389
08/03/09 02:12 PM
08/03/09 02:12 PM
Hemiroid Offline
Hemiroid  Offline
Sucks that it broke, but at least you know it's making power If it's an automatic remember to check the sprag after the rear end breakage.
Re: 1st time down the track in 22 years and carnage [Re: 70shaker] #427390
08/03/09 02:15 PM
08/03/09 02:15 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
12 flat at 118 ?... nice speed !!
Re: 1st time down the track in 22 years and carnage [Re: dOc !] #427391
08/03/09 02:22 PM
08/03/09 02:22 PM
Davenport, IA
70shaker Offline OP
70shaker  Offline OP
Davenport, IA
It has a 4 speed. It was spinning on the launch and I was going to try some different settings on the Cal Tracs but them came the breakage
Ex Hemi Racer
Re: 1st time down the track in 22 years and carnage [Re: 70shaker] #427392
08/03/09 02:26 PM
08/03/09 02:26 PM
Florida STAYcation
Florida STAYcation
A 12 flat combo ..in a fairly heavy E body ...with a 4 speed ?
An 8 3/4 is marginal at best !
Re: 1st time down the track in 22 years and carnage [Re: dOc !] #427393
08/03/09 05:36 PM
08/03/09 05:36 PM
Lehigh Acres, Florida
rickstershemi Offline
Ran an 8-3/4" in my Challenger for years with stock axles, welded spider's... , at 3,000#, Ran low 11's
Rickster
Re: 1st time down the track in 22 years and carnage [Re: 70shaker] #427394
08/03/09 05:47 PM
08/03/09 05:47 PM
cleveland Ohio
mloboda Offline
mloboda  Offline
cleveland Ohio
breakage
STICK SHIFT !!!!!!
NEVER, EVER PUT AN AUTOMATIC IN !!!!!!
Re: 1st time down the track in 22 years and carnage [Re: mloboda] #427395
08/03/09 09:14 PM
08/03/09 09:14 PM
Davenport, IA
70shaker Offline OP
70shaker  Offline OP
Davenport, IA
I pulled the rear apart and all it did was break the DS axle. I have never seen one break like this one. The break looks like it was machined.
Ex Hemi Racer
Re: 1st time down the track in 22 years and carnage [Re: 70shaker] #427396
08/03/09 09:23 PM
08/03/09 09:23 PM
I bet it broke right at the edge of the splines just outside the posi clutches or side gears Nice and smooth break on both ends with one to two twists in the splines before it broke at least all of the 8 3/4 stock axles I've broke at the track have been that way, the small ends make nice paper weights
Re: 1st time down the track in 22 years and carnage [Re: 70shaker] #427397
08/03/09 11:54 PM
08/03/09 11:54 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
4 speed will do that to a dana also, you need after marker axle
