Help me I.D. these rockers!! #425641
08/01/09 04:26 PM
08/01/09 04:26 PM
Hemiroid Offline OP
Hemiroid  Offline OP
I've had these laying around for like 15 years and now that my GTX needs some roller rockers these need to find a new home.
Fulcrum roller, roller tip, shaft mounted Cranes but I'll be damned if I can figure out what the heck they are. Help!!
Re: Help me I.D. these rockers!! [Re: Hemiroid] #425642
08/01/09 04:57 PM
08/01/09 04:57 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
ok i'm taking a guess here as i've seen Cranes like this on a set of W2 heads. i could be wrong & it's known to happen before but my best suggestion if you really want to know is ring Crane since they're back in bussiness.
Re: Help me I.D. these rockers!! [Re: rebel] #425643
08/01/09 05:07 PM
08/01/09 05:07 PM
Hemiroid Offline OP
Hemiroid  Offline OP
Before they went out of business I tried them and they were no help, even though they're the manufacturer!! Maybe the new guys know more
Re: Help me I.D. these rockers!! [Re: Hemiroid] #425644
08/01/09 05:10 PM
08/01/09 05:10 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
the Crane w2 rockers I had did not look anything like that mine didn't have bearings in them for the shafts either like those do
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Help me I.D. these rockers!! [Re: dusturbd340W5] #425645
08/01/09 05:48 PM
08/01/09 05:48 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
the W2's i was looking at were a set of "chapman" prepped heads. they were second hand for sale stuff, not regular heads as they were oval port & came with a matching manifold. the seller had them apart & was pointing out that they were as good as HS due to the roller fulcrums. i didn't buy them due to the hefty price & this was 10-12 years back but they did look similar. are these the same ratio or are some 1.5's & the others 1.6's?
Re: Help me I.D. these rockers!! [Re: Hemiroid] #425646
08/01/09 06:02 PM
08/01/09 06:02 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I didn't know Crane made a roller fulcrum rocker.
Re: Help me I.D. these rockers!! [Re: B5 Bee] #425647
08/01/09 09:49 PM
08/01/09 09:49 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
wouldn't W2's have a left and right offset for the intake's? or am I not seeing everything.
Re: Help me I.D. these rockers!! [Re: Hemiroid] #425648
08/01/09 10:08 PM
08/01/09 10:08 PM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
Those are for Dart Buick heads with 13/16 shaft!
Did a quick Google and ran across this message board: http://www.insidecompracing.com/showthread.php?t=2974
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: Help me I.D. these rockers!! [Re: BradD] #425649
08/01/09 10:53 PM
08/01/09 10:53 PM
Hemiroid Offline OP
Hemiroid  Offline OP
That's them! I remember now, I took them as partial payment of a debt that was owed to me for some headwork a LONG time ago. Thanks for the memory jolt!
