Rockers for 440-1 heads??? #420805
07/27/09 08:52 PM
07/27/09 08:52 PM
Oklahoma
silverfish Offline OP
Oklahoma
Broke a rocker on the motor in my Cuda at the last race. 440-1 heads, Indy 1.5 ratio rockers. Wanted to get some T&D's but they say they are 6 to 8 weeks out and we have another race on August 15th. What do you guys have the best luck with? Are the Indy's doing ok? What about Harland Sharp? Or does anyone know of a place that keeps T&D rockers in stock? This is a 540" nitrous motor if it makes a difference. Any suggestions....
Re: Rockers for 440-1 heads??? [Re: silverfish] #420806
07/27/09 09:07 PM
07/27/09 09:07 PM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
I would use the Harland Sharpes before I would use Indy's . I think they break quite often .
Re: Rockers for 440-1 heads??? [Re: FY1TA] #420807
07/27/09 09:16 PM
07/27/09 09:16 PM
Oklahoma
Oklahoma
I've heard and read that also and now I've experienced it so I really don't want to go back with Indys. I've had good luck with Harland Sharp in the past but that was on smaller less powerful motors that weren't on nitrous and didn't turn as much rpm. Are they holding up well on higher rpm big blocks?
Re: Rockers for 440-1 heads??? [Re: silverfish] #420808
07/27/09 09:19 PM
07/27/09 09:19 PM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
Pete at Best Machine got my new T&D's pretty quick . You might want to give him a call .
Re: Rockers for 440-1 heads??? [Re: FY1TA] #420809
07/27/09 09:51 PM
07/27/09 09:51 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I'm running Harlands on my 500" 440-1 headed motor, 706/661 roller.
Re: Rockers for 440-1 heads??? [Re: ProSport] #420810
07/27/09 09:53 PM
07/27/09 09:53 PM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
Old Indy motor ran HS, new Indy motor TD.
Re: Rockers for 440-1 heads??? [Re: Lil Demon] #420811
07/27/09 11:42 PM
07/27/09 11:42 PM
Oklahoma
Oklahoma
What should I expect to pay for a set of T&Ds versus a set of Harlands? I see that Best Machine sells T&D so is that about the best place to get them? I wonder if anyone stocks them so they don't have to be ordered??
Re: Rockers for 440-1 heads??? [Re: silverfish] #420812
07/28/09 12:35 AM
07/28/09 12:35 AM
AndyF Online content
AndyF  Online Content
You might give Hughes a call. They have some nice rocker arm kits that I've used in the past.
Re: Rockers for 440-1 heads??? [Re: AndyF] #420813
07/28/09 01:16 AM
07/28/09 01:16 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
I have a set of T&D's in the Shelf, 1.6:1 ratio...., however, since I'm in Finland that doesn't help much. They have been tried three times, but didn't work in our application. I've been asking 550€ for them locally.
Plynouth VIP '67 TT IC EFI
Re: Rockers for 440-1 heads??? [Re: silverfish] #420814
07/28/09 07:25 AM
07/28/09 07:25 AM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
T&D's paired 980.00 I believe list price on the H S are more .
Re: Rockers for 440-1 heads??? [Re: silverfish] #420815
07/28/09 10:24 AM
07/28/09 10:24 AM
Baltimore,MD
Bill_LBSR Offline
Bill_LBSR  Offline
Baltimore,MD
I would run the Jesel paired roacker arm set up. One of the best upgrades I ever did to my 440-1's.
LBSR
Re: Rockers for 440-1 heads??? [Re: Bill_LBSR] #420816
07/28/09 01:46 PM
07/28/09 01:46 PM
Mid west
Gearhead383 Offline
Gearhead383  Offline
Mid west
When I made the switch to T&D's, I had to replace all my pushrods to a ball-ball style. If I had gone with H/S, I could have reused my old ones. Just another cost to consider when making the change.
Re: Rockers for 440-1 heads??? [Re: Gearhead383] #420817
07/28/09 02:30 PM
07/28/09 02:30 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I ran the Jesel system with a solid roller, and of coarse no problems. Before I ran the Indy/Dove rockers with a .650 flat tappet. If Harland Sharps are the same price as T&D I would go that route.
Have you contacted Jeff at MCH, or Todd Marsh, Dewayne Porter, and Best Machine...these guys are dealers of T&D..also Nick at Compu-flow...
I bet some one has a set on the self.
just some idea's
Re: Rockers for 440-1 heads??? [Re: Bob_Coomer] #420818
07/28/09 04:45 PM
07/28/09 04:45 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
what wrong with indy's
Re: Rockers for 440-1 heads??? [Re: mcat4321] #420819
07/28/09 05:13 PM
07/28/09 05:13 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Nothing in the intended application, In a 540 Cubic inch NOS motor IMO is not one of them. I bet the engine has a solid roller cam and 600-700+ lbs open pressure.
I betting the guys at Indy's own personal engine's doesnt have them in this type application for good reason.
I would use them in a second in a mech flat cam street car.
If there is money well spent in any performance engine it always pay to have good valve train equipment.
I would use stock stamped rocker arms in a street engine, even if I was given a NEW SET of ProForm rocker arms...WHY? I know the stock stuff can take the abuse for 100,000+ miles of use.
Re: Rockers for 440-1 heads??? [Re: mcat4321] #420820
07/28/09 05:28 PM
07/28/09 05:28 PM
Oklahoma
Oklahoma
This motor has between 50 - 60 passes and a rocker arm has already broken. Plus I've heard lots of other people have trouble with their rockers.
Thanks for all the info guys!
Re: Rockers for 440-1 heads??? [Re: Bob_Coomer] #420821
07/28/09 05:33 PM
07/28/09 05:33 PM
Oklahoma
Oklahoma
Good point. I really should have known better but when I first started this project with these heads it wasn't going to be this powerful of a motor. Live and learn I guess!
Re: Rockers for 440-1 heads??? [Re: silverfish] #420822
07/29/09 12:36 AM
07/29/09 12:36 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
In our use, some 200+ seat pressure and 600+ open, 0.683" roller. The Indy rockers lasted 2-3 years of street & strip use, a couple of thousand miles a year. Most likely you would need new pushrods even with the Harlan Sharps even though they use the cup end, the needed length is different than with the Indy/Doves, I think.
Re: Rockers for 440-1 heads??? [Re: silverfish] #420823
07/29/09 11:24 AM
07/29/09 11:24 AM
Lansing, MI
MuscleMike Offline
MuscleMike  Offline
Lansing, MI
1.5 & 1.6's in stock
Mike @MM
