Page 122 of 167 1 2 120 121 122 123 124 166 167
sapphire blue [Re: 69DartGT] #38734
05/02/09 07:03 PM
05/02/09 07:03 PM
Does anyone have pictures of brightside sapphire blue on any car?
I've started my project black but now I'm itching to finish her off in blue
Re: New Paint job on a budget thread Part III [Re: 69DartGT] #38735
05/03/09 01:26 AM
05/03/09 01:26 AM
Ok thanks, that's an idea. I've rolled before and never before I had this problem with airbubbles. Nomather how thin the paint is. If I paint slow or fast, no pressure at all always those %$#@ bubbles.
Yesterday, I've painted as a test my rightfrontfender with only a brush, and that helped. No bubbles and the result looks promising.
Re: New Paint job on a budget thread Part III #38736
05/04/09 09:42 AM
05/04/09 09:42 AM
United States
DSLStuff Offline
DSLStuff  Offline
United States
I have been following this thread for a long time. I have to thank all of you for your work on this topic. My biggest obstacle on this was trying to get others to believe you that it WILL work.
This spring I just finished painting my 94 dodge drag truck. The best part so far was when I showed a guy the truck this past weekend and he didn't believe me when I said I painted it for ~$100 with a roller!
Started with this stock 200k mile truck
Then made it into this.
New paint!!
It is by no means perfect. We learned a lot on this first project, all the way to the end of the project. Trial and error made it turn out pretty good in the end.
94 Dodge Cummins Reg Cab Short Box 2wd "It only needs to look good at 100mph!"
Re: New Paint job on a budget thread Part III [Re: DSLStuff] #38737
05/04/09 09:48 AM
05/04/09 09:48 AM
United States
DSLStuff Offline
DSLStuff  Offline
United States
Some more pics of the process. The color is rustoleum dark hunter green, black and aluminum mixed to get the color I wanted. Oh and the hood in the action photo is rustoleum flat black. We have a hood for the stack and one for street legal exhaust.
Roll pan with a couple coats
Paint before buffing.
Done just before Topeka race April 2009
Re: New Paint job on a budget thread Part III [Re: DSLStuff] #38738
05/04/09 10:45 AM
05/04/09 10:45 AM
Piqua, Ohio
dodgeram440 Offline
Happy Birthday dodgeram440  Offline
Piqua, Ohio
Dude, that's a bad a$$ truck! But we need more info! How did you shorten it for the shortbed? What's that bar seen under the bed? Some kind of 4-link or something? With the aluminum paint mixed in, I'm assuming it has a metalic look to it. How did that turn out with all the sanding and stuff? Truck really looks great!
Having an issue [Re: dodgeram440] #38739
05/04/09 02:00 PM
05/04/09 02:00 PM
Alright, so I got 2 layers of paint on my car but I can see roller marks big time
I'm doing it in flat black by the way if that helps to solve my problem
So basically, I cant paint without having thos horrible roller marks. I am now wetsanding it all in order to get a uniform ( lol ) coat to try again
Also, I barely get any orange peel with flat color, I could almost call my car done if it wasnt for the horrible roller marks. Is there a way to avoid it? I'm very bad at this
Re: New Paint job on a budget thread Part III [Re: dodgeram440] #38740
05/04/09 04:06 PM
05/04/09 04:06 PM
United States
DSLStuff Offline
DSLStuff  Offline
United States
Thanks for the compliments
Bar you can see is a traction bar used with the factory leaf springs.
The paint turned out like what you see in the second picture of my second post. That is a close up of the front fender after 3 coats, 1 sanding of 800, and then one more coat.
Short video of the truck HERE
Re: New Paint job on a budget thread Part III [Re: DSLStuff] #38741
05/04/09 04:31 PM
05/04/09 04:31 PM
Canyon, Texas
gdub Offline
gdub  Offline
Canyon, Texas
I'm about ready to start the body work on my 51 ford truck, I had it sandblasted a number of years ago and it has since developed some surface rust, I am going to hit it with phosphoric acid then prime and do the bodywork. I think I've seen on here that you can use body filler over rustoleum primer and just wanted to make sure that would work OK.
Thanks,
Gary
Re: New Paint job on a budget thread Part III [Re: gdub] #38742
05/04/09 05:20 PM
05/04/09 05:20 PM
middleOnowhere CA
THEYOUNGGUN53 Offline
middleOnowhere CA
I would really sugjest doing it on the bare metal.
a car is never "done"
Re: New Paint job on a budget thread Part III [Re: THEYOUNGGUN53] #38743
05/04/09 06:28 PM
05/04/09 06:28 PM
St Andrews ,Manitoba ,Canada
C38coupe Offline
C38coupe  Offline
Nope, strip old finish acid treat, primer with rusty metal primer, let cure about 10 days, go over with fillers.....
Re: New Paint job on a budget thread Part III [Re: C38coupe] #38744
05/04/09 09:39 PM
05/04/09 09:39 PM
Canyon, Texas
gdub Offline
gdub  Offline
Canyon, Texas
That's what I was hoping to hear. I'll post some pics when I get it going.
thanks,
Gary
Re: New Paint job on a budget thread Part III [Re: gdub] #38745
05/07/09 01:28 PM
05/07/09 01:28 PM
Reykjavík, Iceland
I
Ivarb Offline
Ivarb  Offline
I
Reykjavík, Iceland
What type of polish and what type of pads do you guys use for buffing after last wetsand?
Re: New Paint job on a budget thread Part III [Re: Ivarb] #38746
05/08/09 11:12 AM
05/08/09 11:12 AM
Canada
Marq Offline
mopar addict
Marq  Offline
mopar addict
Canada
PADS: with my Cable Porter, I simply use the white foam pad that comes with that polisher. I use it to apply rubbing compounds, polishes and waxes. Occassionally I will put a microfiber cloth between the foam head and the paint... and use the microfiber to get the best shine I can.
I do know that some of the guys have used the wooly head on their polisher when doing the rubbing compound stage. That is because the wooly head gives them additional 'cutting' when trying to polish the surface. But you have to be careful because it may give 'too much' cutting IF YOU don't keep the polisher constantly moving and stay too long on one spot.
Now... back to a quick chat about rubbing compounds, polishes and waxes..
Once you have the paint wetsanded to its best point, you next move to using a Rubbing Compound. I believe originally that Charger made use of the Turtle Rubbing compound... which basically looks like a brown clay in a tub
The thing to keep in mind is that after you have taken your paintjob to the smoothest point using wetsanding.... you basically are continuing to further polish the surface with a rubbing compound. For example, if the sandpaper you worked it up to was 2000, 2500, or 3000 grit... well the rubbing compound is simply the next highest grit to get the surface even smoother.
Other then the Turtle Rubbing compound, there are also excellent polishing and cutting compounds made by 3M which basically do the same job. They are just like using liquified sandpaper - but at a higher level of grit.
You follow your 'rubbing compound' stage with a polish. Even plain old Turtle polish can be used at that point. Or just about any other car polish.
You need to watch out what is actually in the various polishes that are sold. Some are solely polishes... some are polishes with cleaners... some are polishes with waxing compounds... some are polishes with acrylic or synthetic shine compounds.
Ideally you want just a straight polishing wax... but you can substitute a polishing/cleanser as well.
Once you nail down the polishing stage..... you next move to the final 'waxing' stage. I tend to prefer using Meguirs 'pure Carnuba' wax... but most car waxes can do the job equally well. You have to remember that the whole objective of the waxing stage is to achieve 3 things :
a ) you are sealing the paint surface to reduce the amount of oxygen or other foreign matter that might want to get to the paint. It also provides some Ultra Violet protection to reduce future fading from the UV of the sun.
b ) you are trying to tweak up the shine by adding a layer of the refractive qualities of the wax. This gives the paint more depth and shine.
c ) you are trying to put a coating on the paint that will repel road grit, bird poo and smashed bugs from embedding in to the paint.
One thing that I have learned is that the acrylic type 'waxes' or the synthetic type waxes, that promise one year shines or diamond hard coatings, are best to stay away from. At this point you want a real wax on the car and not some synthetic shine.
Although I held high hopes for the Turtle ICE wax, NuShine and other synthetic shines... they all were crap in the end. I would have gotten the same result by spraying Armorall on the paint. It looks good when wet and fresh... but dries out to look like crap or that nothing was used.
Hope these thoughts help out...
Re: New Paint job on a budget thread Part III [Re: Marq] #38747
05/08/09 12:06 PM
05/08/09 12:06 PM
Southern, Ca.
69DartGT Offline OP
moparts member
69DartGT  Offline OP
moparts member
Southern, Ca.
Re: New Paint job on a budget thread Part III [Re: 69DartGT] #38748
05/08/09 12:28 PM
05/08/09 12:28 PM
Reykjavík, Iceland
I
Ivarb Offline
Ivarb  Offline
I
Reykjavík, Iceland
Helps alot, thank you guys.
Re: New Paint job on a budget thread Part III [Re: dodgeram440] #38749
05/09/09 11:15 AM
05/09/09 11:15 AM
usa
aussie Offline
aussie  Offline
usa
So the aluminum rustoleum does work, I want to do my car silver (aluminum).
The mix you made it really good, did the aluminum mix make the paint look uniformed because there was talk that metallic paint will not work with the roll-on method.
Re: New Paint job on a budget thread Part III [Re: aussie] #38750
05/10/09 11:42 AM
05/10/09 11:42 AM
United States
DSLStuff Offline
DSLStuff  Offline
United States
You have to keep it mixed really well. Other than that I did not have any trouble applying it. Not heavy spots, no sanding issues, etc.
Everyone is different. Maybe it would have turned out better without it I don't know. I am happy with it.
Re: New Paint job on a budget thread Part III [Re: DSLStuff] #38751
05/12/09 12:41 PM
05/12/09 12:41 PM
Reykjavík, Iceland
I
Ivarb Offline
Ivarb  Offline
I
Reykjavík, Iceland
I´m going to paint my ranger in june, should i put primer before paint og should I just wetsand the original paint and put the paint on.
What primer is the best? How do you guys do it. Do you roll the primer og spray it on?
I will post pictures of my car when I start my paintjob.
Re: New Paint job on a budget thread Part III [Re: Ivarb] #38752
05/12/09 01:00 PM
05/12/09 01:00 PM
Southern, Ca.
69DartGT Offline OP
moparts member
69DartGT  Offline OP
moparts member
Southern, Ca.
Just sanding the original paint is fine, but I did find that the area's I primed (just used lacquer primer) actually covered much better than the area's I sanded.
I cheated and sprayed the primer though.
Re: New Paint job on a budget thread Part III [Re: 69DartGT] #38753
05/15/09 06:31 PM
05/15/09 06:31 PM
arizona
70gs Offline
70gs  Offline
arizona
I wonder if its possible to mix this stuff in some rustoleum???
http://cgi.ebay.com/ebaymotors/Silver-Ho...alenotsupported
I was thinking of adding it to a shade of blue if it would work.
Also has anyone had home depot mix rustoleum paint to your desired color?
Thanks for any help
