Page 119 of 167 1 2 117 118 119 120 121 166 167
Re: RE: New Paint job on a budget thread Part III [Re: dodgeram440] #38674
04/06/09 11:48 PM
04/06/09 11:48 PM
Canada
Marq Offline
mopar addict
Marq  Offline
mopar addict
Canada
Ok, next question. This is the hood on my truck. I had sanded it to bare metal and shot it with Rustoleum rattle can primer a year or so ago. As you can see now, it has a few spots of rust. I just replaced the left fender and before I put it on, I filled the emblem holes, covered it all with rattle can primer, sanded it good, then rolled it with Rustoleum rusty metal primer.
My actual question is, do I need to resand the hood before I roll it with the rusty metal primer, or can I just roll it as is?
Ok... IF your hood presently has rust stains showing through the spray on primer... then I would resand it down to rid as much of that rusty surface as possible.
I would next go to the canned primer and roll it on. I don't think I would go with the spray can primer, as I don't have much faith in it for truly sealing oxygen from getting to the rust sites. Starve the rust of oxygen and it can't grow or spread.
Then sand that primered surface to get it a nice dull but extremely smooth surface upon which you can lay your coats of paint on to.
Re: RE: New Paint job on a budget thread Part III [Re: Marq] #38675
04/07/09 07:21 PM
04/07/09 07:21 PM
Piqua, Ohio
dodgeram440 Offline
Happy Birthday dodgeram440  Offline
Piqua, Ohio
Thanks. I was actually planning to sand it anyway. I guess I was wondering if the Rustoleum might work like those rust converter coatings that claim to convert rust to paintable primer. As I think about it, probably not. I just hope the roll on rustoleum primer helps prevent the rust from coming back. I've got the left fender primered, as seen in the previous photo, next is the hood then the right fender. Then I'll work back to the doors and cab, then on back to the bed.
Thanks again. I can't wait to get this truck all one color, even if it is just a primer.
Re: RE: New Paint job on a budget thread Part III [Re: dodgeram440] #38676
04/07/09 10:30 PM
04/07/09 10:30 PM
Southern, Ca.
69DartGT Offline OP
moparts member
69DartGT  Offline OP
moparts member
Southern, Ca.
I don't know if it helps but I used Rustoleums rusty metal primer straight out of the can on the inside of my truck bed, use foam brush in the tight area's and rolled the rest, no runs, drips or errors it went on very well.
Re: RE: New Paint job on a budget thread Part III [Re: 69DartGT] #38677
04/08/09 09:37 PM
04/08/09 09:37 PM
middleOnowhere CA
THEYOUNGGUN53 Offline
middleOnowhere CA
alright its finnaly time for some updates. Apparently lowes screwed me and gave me the wrong kind of primer, the guy handed me latex
so I had to spray rusto primer from a can onto the car. All of the primerd spots of the car means that the bondo is done there.
roof
left side of the deck lid still needs more work
right side of the car is fully done.
its getting there, slowely but shurly.
a car is never "done"
Re: RE: New Paint job on a budget thread Part III [Re: THEYOUNGGUN53] #38678
04/08/09 10:51 PM
04/08/09 10:51 PM
Southern, Ca.
69DartGT Offline OP
moparts member
69DartGT  Offline OP
moparts member
Southern, Ca.
If you have a spray gun just go down to your local autoparts store and get a quart of Dupilcolor gray lacquer primer along with some lacquer thinner and shoot the car, then a light sand tack rag and start rolling.
Look at the door then the rest I fully primed the door & the coverage was much better.
Re: RE: New Paint job on a budget thread Part III [Re: 69DartGT] #38679
04/08/09 11:03 PM
04/08/09 11:03 PM
middleOnowhere CA
middleOnowhere CA
I don't really have access to a spray gun or a compresser, so I'm just going to have to go back and ask the guy to give me the RIGHT stuff. The whole car is going to be primerd evenly though one way or another
Re: RE: New Paint job on a budget thread Part III [Re: THEYOUNGGUN53] #38680
04/08/09 11:21 PM
04/08/09 11:21 PM
Southern, Ca.
69DartGT Offline OP
moparts member
69DartGT  Offline OP
moparts member
Southern, Ca.
If you have a test piece maybe a spare old fender try rolling rustoleum rusty metal primer on it, I rolled it straight out of the can in my trucks bed it went on great actaully better than the finish paint, it self leveled zero high spots ridges etc, be worth a try.
Re: RE: New Paint job on a budget thread Part III [Re: 69DartGT] #38681
04/08/09 11:23 PM
04/08/09 11:23 PM
middleOnowhere CA
middleOnowhere CA
hm, I may try that. I have spare hoods, fenders, deck lids, you name it. You tend to collect alot of parts when your working on cars
Re: RE: New Paint job on a budget thread Part III [Re: THEYOUNGGUN53] #38682
04/09/09 05:53 AM
04/09/09 05:53 AM
middleOnowhere CA
middleOnowhere CA
hey Marq, is this what you had in mind for an evil Herbie
Re: RE: New Paint job on a budget thread Part III [Re: Marq] #38683
04/11/09 11:31 AM
04/11/09 11:31 AM
Read your guide Marq,and have some questions about Brightside. Sorry about my rusty english.
1.Original paint is good, no rust or flaking. I'm not sure what primer i must use. INTERLUX PRE-KOTE or YACHT PRIMER? What is the difference between these two? And can something happend when i'm using a 1k primer when the original paint on my car is 2k? Chemical reaction?
2.Do i have to sand the whole car before i apply INTERLUX PRE-KOTE or YACHT PRIMER? Can i just sand away paint that is a little higher than the rest after some touch-up over the years? Original paint is pretty good. I'm going to wash the car first with soap, then use some grease remover a couple of times.
3.If i sand through to metal when preparing the car, must i use a different primer than INTERLUX?
4.Is it better to use dry paper than wetsanding the INTERLUX PRE-KOTE or YACHT PRIMER?
5.I've read the manual (PRE-KOTE and Brightside), and i'm a little unsure about the drying time and laying the first coat of paint. I'm going to paint the car outside, so if it rains a couple of days i must wait to apply the first coat of paint. But in the manual it says this(pre-kote, UK manual): Apply 1-2 coats. If maximum overcoating time of previous coating/primer is exceeded, abrade using 220-320 grade wet or dry paper. How important is it to follow the manual in this case? Dp i really have to sand down the primer if i exceed the overcoating time?
6.When using thinner NR333 with a cloth before laying a new coat of paint, how long must i wait before painting?
7.When sanding, do you sand up and down, circles? Is there a special direction you sand?
8. How important is it to use High Density Foam Rollers? I'm not sure what i can get here in Norway.
Hope you can answer some of the questions. Thanks!
Re: RE: New Paint job on a budget thread Part III #38684
04/11/09 11:51 AM
04/11/09 11:51 AM
Southern, Ca.
69DartGT Offline OP
moparts member
69DartGT  Offline OP
moparts member
Southern, Ca.
captianc, 1st welcome to the board.
Brightside goes over most all primers, I used lacquer primer from my local auto parts store.
To thin the brightside I used mineral spirits, worked great, Marq should chime in soon.
Re: RE: New Paint job on a budget thread Part III #38685
04/11/09 09:32 PM
04/11/09 09:32 PM
USA
_
_Scott_ Offline
_Scott_  Offline
_
USA
captainc, If you had not mentioned it, I would not have noticed that english was not your first language.
Regarding sanding, nobody likes to sand any more than they have to. Unfortunaltely you must sand everywhere you want paint/primer to stick. If you skimp on that vital part of the paint preparation process, the new paint will eventually peel and flake off in the areas where the sanding was inadequate. That is also true for primer that was allowed to dry past the time specified in the instructions on the primer container.
Re: RE: New Paint job on a budget thread Part III [Re: _Scott_] #38686
04/13/09 05:48 PM
04/13/09 05:48 PM
middleOnowhere CA
middleOnowhere CA
alright, I finnaly went out and bought the RIGHT primer for the car. At least I'm hoping its the right kind, will the white bare metal rusto primer do the job?
Re: RE: New Paint job on a budget thread Part III [Re: THEYOUNGGUN53] #38687
04/13/09 06:08 PM
04/13/09 06:08 PM
middleOnowhere CA
middleOnowhere CA
heres the stuff
Re: RE: New Paint job on a budget thread Part III [Re: THEYOUNGGUN53] #38688
04/16/09 01:33 PM
04/16/09 01:33 PM
I don't see why not. Especially if you're going with Canvas White. My Jeep still had the original paint with no bare metal so I skipped the primer and just hit it with 400 before starting to roll. How's it going? Any more pics?
Re: RE: New Paint job on a budget thread Part III #38689
04/16/09 06:23 PM
04/16/09 06:23 PM
middleOnowhere CA
middleOnowhere CA
cool
its going well, I'm making progress, slowely but shurley. Not quite ready for progress pics yet, it'll look pretty much exactly the same as it did in the last pics. I'm almost done with the sides of the car, I still need to do more work on the deck lid and rear apron, then its just this damn roof. I'm finnaly making head way on the roof but its taking forever!
Re: RE: New Paint job on a budget thread Part III [Re: THEYOUNGGUN53] #38690
04/16/09 07:27 PM
04/16/09 07:27 PM
Southern, Ca.
69DartGT Offline OP
moparts member
69DartGT  Offline OP
moparts member
Southern, Ca.
One thing to remember that is an "oil based" primer so when we use that type you are limited to using Rustoleum type paints over it.
Not a big deal.
Re: RE: New Paint job on a budget thread Part III [Re: 69DartGT] #38691
04/17/09 01:08 AM
04/17/09 01:08 AM
middleOnowhere CA
middleOnowhere CA
.....your kidding...right?
Re: RE: New Paint job on a budget thread Part III [Re: THEYOUNGGUN53] #38692
04/17/09 10:20 PM
04/17/09 10:20 PM
California
1971ford Offline
1971ford  Offline
California
Do you guys strongly suggest a roll-on primer before the paint?
If its bare metal you are rolling the paint on, what do you sand it to for best adhension? what about if your applying the new paint on old paint, then what do you sand to?
Re: RE: New Paint job on a budget thread Part III [Re: THEYOUNGGUN53] #38693
04/18/09 01:50 PM
04/18/09 01:50 PM
Southern, Ca.
69DartGT Offline OP
moparts member
69DartGT  Offline OP
moparts member
Southern, Ca.
No I'm not, the only thing is you can't put lacquer or enamel over it. I used the rusty metal primer of my truck wothout any problem's I also used lacquer primer on my door and a few other places its all good.
