Lokar kickdown w/ Holley carb #386167
07/25/09 06:42 PM
07/25/09 06:42 PM
duals Offline OP
duals  Offline OP
72 Demon 340 that now has a 400 big block, kickdown was not hooked up due to trying to use the small block kickdown ( not me previous owner ), I purchased the Lokar kickdown cable which looks great but I was told if useing a Holley carb I would need some kind od adapter at the carb and could be bought at any big auto supply. Any pics of this bracket or ?
Re: Lokar kickdown w/ Holley carb [Re: duals] #386168
07/25/09 07:53 PM
07/25/09 07:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The special Mopar throttle lever extension is only needed when using the factory linkage, the Lokar uses tyhe existing hole in the bottom of the Holley throttle lever.
Re: Lokar kickdown w/ Holley carb [Re: John_Kunkel] #386169
07/25/09 08:09 PM
07/25/09 08:09 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
the lokar cable will not bolt on the stock mopar bracket..
you will need one of these...
http://www.arengineering.com/throttlebracket/Tbracket/tbracketframe.html
can be bought from mancini racing.
Tony
70 AARCuda Vitamin C
Re: Lokar kickdown w/ Holley carb [Re: 70AARcuda] #386170
07/25/09 09:12 PM
07/25/09 09:12 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
you dont need that.it attaches at the carb
Re: Lokar kickdown w/ Holley carb [Re: west] #386171
07/26/09 12:19 AM
07/26/09 12:19 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
i was not talking about the holley 20-7 bracket..i was talking about the stock mopar bracket that holds the throttle cable and kickdown linkage...
Tony
Re: Lokar kickdown w/ Holley carb [Re: duals] #386172
07/26/09 12:48 AM
07/26/09 12:48 AM
jacksboro,tn
1bad318 Offline
1bad440
1bad318  Offline
1bad440
jacksboro,tn
the pic of the sb with the lokar set-up shows everything needed.you do away with the stock throttle cable and kick down bracket.the kick down cable bolts to the throttle cable bracket that the lokar system uses
Re: Lokar kickdown w/ Holley carb [Re: 70AARcuda] #386173
07/26/09 02:43 AM
07/26/09 02:43 AM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
so was I
Re: Lokar kickdown w/ Holley carb [Re: west] #386174
07/26/09 07:34 AM
07/26/09 07:34 AM
Tampa Florida
MoparTod Offline
MoparTod  Offline
Tampa Florida
I have this system also mounted to my Holley and I have no issues. It worked great. Just make sure when you adjust your throttle pressure cable for the trans that you get it right. You can burn the transmission up quickly adjusted improperly.
Re: Lokar kickdown w/ Holley carb [Re: MoparTod] #386175
07/26/09 08:25 AM
07/26/09 08:25 AM
duals Offline OP
duals  Offline OP
Thanks everybody, pics were very helpful . Just need to get up off my butt and do it. lol
Re: Lokar kickdown w/ Holley carb [Re: west] #386176
07/26/09 08:30 AM
07/26/09 08:30 AM
CHRGR69 Offline
CHRGR69  Offline
Get the bracket from Lokar
Grandma always said I had "hands of gold"!
Re: Lokar kickdown w/ Holley carb [Re: duals] #386177
07/26/09 09:41 AM
07/26/09 09:41 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Why not just get a stock BB kick-down errr throttle pressure regulator linkage... anyway much easier to install.
Coming soon!!!!
Re: Lokar kickdown w/ Holley carb [Re: Mr.Yuck] #386178
07/26/09 09:49 AM
07/26/09 09:49 AM
CHRGR69 Offline
CHRGR69  Offline
Because some of us snap off the pivot pin on the tranny.
Re: Lokar kickdown w/ Holley carb [Re: CHRGR69] #386179
07/26/09 09:59 AM
07/26/09 09:59 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
hahaha I've done that before.... search this site for Lokar pictures. The instructions..well they aren't very good.
Coming soon!!!!
Re: Lokar kickdown w/ Holley carb [Re: Mr.Yuck] #386180
07/26/09 11:02 AM
07/26/09 11:02 AM
Ontario, Canada
8
84Stepside Offline
84Stepside  Offline
Ontario, Canada
i hear alot about people not setting throttle presure linkage correctly, i will be installing a lokar kit near the end of the summer, i was wonderings how you make sure the pressures are set correct? just with shift points?
Re: Lokar kickdown w/ Holley carb [Re: CHRGR69] #386181
07/26/09 04:35 PM
07/26/09 04:35 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
and some more pics...
