Iron vs. aluminum block #385602
07/25/09 12:24 AM
07/25/09 12:24 AM
Hemiroid Offline OP
Hemiroid  Offline OP
I have to make a decision soon on what block to run and am looking for some input. Heads-up hemi, 65 belvedere trying to push the 1100 mark. I know the iron block will make more power, but it weighs a lot more as well. Is there anyone out there putting Worlds new block on a cnc diet? If so, any ideas on how light they can get? The one I saw weighed like 350lbs
There's no wheelie bars allowed so weight on the nose might not be a bad thing. I do like the repairability of alum and the light weight, so it makes for a tough decision on what way to go.
Thanks in advance for any help
Re: Iron vs. aluminum block [Re: Hemiroid] #385603
07/25/09 02:36 PM
07/25/09 02:36 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
IMo A filled aluminum block makes almost as much power as an iron block. Usually any power loss on aluminum blocks is from the cylinders moving around. Filling the block stabilizes the cylinders. Aluminum blocks are also less prone to cracking on high HP applications.
Re: Iron vs. aluminum block [Re: BobR] #385604
07/25/09 04:32 PM
07/25/09 04:32 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I went through this same dilemma this past fall. Last spring I built a Indy maxx block based moderate wedge around 560" or so. The block was a good piece, but the aluminum has its Pro's and Con's.
The weight loss with aluminum is offset by the loss in power against the iron block. Some say at least 30hp some say as much as 50 hp. Its substantial IMO. Things move around with the aluminum engine, looking at just the lash growth, no need to look further. The aluminum block almost had twice the lash growth.
Really the repairability is the only thing that IMO is worth the aluminum block.
This years engine (572 Hemi) I went a diff route going with the new World Hemi block with a 4.5 bore.
It is heavy easy 300+ lbs bare block and main caps. But this block looks to be very strong. And is very nicely finished.
With the cost of good used factory Hemi blocks $4K-$5K..Its a no brainier, I leave these to the resto crowd and picked up a new much stronger block for half that.
Here is a few pics to mull over.
Re: Iron vs. aluminum block [Re: Bob_Coomer] #385605
07/25/09 04:38 PM
07/25/09 04:38 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
hey hemmoriod hows work? i have a world prod iron block for my stuff its heavy but i think its a better deal for the cost.
Re: Iron vs. aluminum block [Re: ro23car] #385606
07/25/09 06:18 PM
07/25/09 06:18 PM
New Brunswick, Canada
TrxR Offline
TrxR  Offline
Ive been debating the same thing for next year. But mines for a 500CI turbo Dakota. I am a little concerned about the extra weight of the cast block in the nose of the truck. I thought I had decided on a KB block or a World Aluminum but Im still not sure. So I would like to hear everyone's opinions as well.
Re: Iron vs. aluminum block [Re: TrxR] #385607
07/25/09 08:17 PM
07/25/09 08:17 PM
Normally asperated, no power adder CGI or cast iron. Boost or power adders aluminum block
Re: Iron vs. aluminum block [Re: Cab_Burge] #385608
07/25/09 09:28 PM
07/25/09 09:28 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Good call, Cab. I agree. I have found that the aluminum blocks, once filled, are pretty close in ring seal to an iron block but if the engine is N/A there may be a few ponies in the iron deal. A dry, billet aluminum block is the best of the best imo.
Re: Iron vs. aluminum block [Re: ro23car] #385609
07/25/09 09:32 PM
07/25/09 09:32 PM
Hemiroid Offline OP
Hemiroid  Offline OP
Same crap, different day Keeping my bills paid, but working on and buying parts for two cars is KILLING me!!
Re: Iron vs. aluminum block [Re: BobR] #385610
07/25/09 09:36 PM
07/25/09 09:36 PM
Hemiroid Offline OP
Hemiroid  Offline OP
It's a heads-up, n/a all motor class. I'm kinda bringing a knife to a gun fight trying to compete with aerodynamic stangs with my taxicab but I love them too much to cave in to a newer body.
Re: Iron vs. aluminum block [Re: Hemiroid] #385611
07/25/09 09:41 PM
07/25/09 09:41 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Go for it!
The little old lady from Pasadena is back!
Re: Iron vs. aluminum block [Re: Barnstorm] #385612
07/25/09 10:19 PM
07/25/09 10:19 PM
Northeast Texas
MoparMuscle Offline
MoparMuscle  Offline
Northeast Texas
Yea, I wish I had one of the World iron blocks instead of the Keith Black that came with the Daytona.
100% Mopar No Juice Added
2016 Challenger R/T Blacktop 5.7 6 SPD
2009 Ram 1500 5.7
http://moparmuscle.biz
Re: Iron vs. aluminum block [Re: MoparMuscle] #385613
07/25/09 10:30 PM
07/25/09 10:30 PM
TrxR Offline
TrxR  Offline
Would it make any difference if it was going to be a street/strip engine running on pump fuel? Would you still go Aluminum for forced induction?
PS sorry about the post jacking
Re: Iron vs. aluminum block [Re: TrxR] #385614
07/26/09 12:22 AM
07/26/09 12:22 AM
Hemiroid Offline OP
Hemiroid  Offline OP
The ring seal is a little less critical in a blown application and the aluminum block is much lighter and easier to fix if you get a little too crazy with the manifold pressure
Of course the aluminum blocks cost more so $$ need to be considered as well.
Re: Iron vs. aluminum block [Re: TrxR] #385615
07/26/09 12:26 AM
07/26/09 12:26 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
No. You are probably limited to 10 pounds or less boost and that isn't going to hurt an iron block. When you start cramming in 30+ pounds even the best iron blocks are susceptible to cracks and fatigue. Aluminum tends to absorb nasty harmonics better than iron.
Re: Iron vs. aluminum block [Re: BobR] #385616
07/26/09 12:50 AM
07/26/09 12:50 AM
Wichita Kansas
CH3NO2 Offline
CH3NO2  Offline
Wichita Kansas
It's like the diff between a ballpeen hammer and a brass one. Steve
Engine by DeTar http://www.kansasbadman.com
Post deleted by Defbob [Re: CH3NO2] #385617
07/26/09 12:56 AM
07/26/09 12:56 AM
Re: Iron vs. aluminum block #385618
07/26/09 01:09 AM
07/26/09 01:09 AM
Hemiroid Offline OP
Hemiroid  Offline OP
The newer aluminum blocks are head and heels above the older ones when it comes to loss of power. Today the thicker sleeves reduce power losses.
I've heard that as well. I'll probably just go aluminum and move the weight around where it's needed. Plus with my lard *** any weight savings is a plus
Re: Iron vs. aluminum block [Re: MoparMuscle] #385619
07/26/09 01:44 AM
07/26/09 01:44 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well if you dont want that Keith Black block I think we can accomodate you with a World Iron block. I'll take that crappy KB piece of your hands
BTW my KB block seems to work just fine in it's NA application.
Post deleted by Defbob [Re: Al_Alguire] #385620
07/26/09 02:22 AM
07/26/09 02:22 AM
Re: Iron vs. aluminum block #385621
07/26/09 11:00 AM
07/26/09 11:00 AM
Northeast Texas
MoparMuscle Offline
MoparMuscle  Offline
Northeast Texas
What does an iron World block sell for?
2009 Ram 1500 5.7
