Page 2 of 3 1 2 3
Re: Are 3.91's enough gear? [Re: GTX MATT] #384935
07/24/09 04:07 PM
07/24/09 04:07 PM
Southern Cal
Noblewk Offline
Noblewk  Offline
Southern Cal
Nobody thinks the stock exhaust manifolds might be an issue?
I'm thinking since he states "It has poor performance off the line and until the RPM get up there." that the exhaust has no effect. Headers or Performance Exhaust has very little effect with low end "Grunt".
The cam has moved the Torque "LOW END Grunt" into a higher RPM Range.
A different Torque Converter that would allow the engine to "Slip into" the higher RPM Range should clear up his issues.
66 Dart GT, 402 11.18:109 Best 63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best 2000 Ram 2005 Durango Hemi.
Re: Are 3.91's enough gear? [Re: Noblewk] #384936
07/24/09 04:48 PM
07/24/09 04:48 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
That cam isn't that radical. I agree with previous that you should check cam timing. A good 2800-3000 stall should be plenty in a 440. Is your intake a dual plane? If not lose it and get a dual plane. Remember basically stock 440's don't make power over 5000-5500. There torque monsters down low. A bone stock 440 with 3;23's should roast the tires off.
Re: Are 3.91's enough gear? [Re: Dougsmopars] #384937
07/24/09 05:27 PM
07/24/09 05:27 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Your approach is similar to repairing a hole in a dam by adding berms to direct the flooding better... The issue is the cam is wrong. The 484 sounds small, but it has big duration numbers for its size and the rest of the engine can't support it. Therefore it can't support the car. You are looking at hundreds for a gear and convertor swap, or either by itself... Why not spend a few hundred on the right cam? If it's too much for you to handle, find a reputable shop to do it for you. You'll be much happier. It's a dog down low. It's still a dog when you rev because of the manifolds and the lack of compression. So instead of making it a dog you're going to try to minimize the dogginess? So what's the real reason your fear changing the cam? Is it an engine warranty issue or something? The package is perfect for what you do except for the cam. $300 in parts, maybe $400 in labor to pay a shop, and it's fixed permanently. $700 is a little more than buying a used chuck and installing it yourself, and a lot less than buying a convertor with that rear and installing both or having them installed.
Re: Are 3.91's enough gear? [Re: Dougsmopars] #384938
07/24/09 05:55 PM
07/24/09 05:55 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
The cam is ALL wrong. He'd be better off w/ a stock 440 cam than that 484. It is a bracket racing cam. It needs 10:1+ 3000+ stall 3.91's or better, intake, headers and the rest to work. Trust me a stockish 440 w/ 3.55's and that cam will net you a slow, non tire spinning B-body.
Coming soon!!!!
Re: Are 3.91's enough gear? [Re: Mr.Yuck] #384939
07/24/09 07:45 PM
07/24/09 07:45 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Until you put a 10" converter in it.
Re: Are 3.91's enough gear? [Re: VITC_GTX] #384940
07/24/09 07:53 PM
07/24/09 07:53 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I dont know a thing about the 484 cam, but i think 383man ran it in his sons dart with almost stock 383 and ran 12.30s. Big cams in low compression 440s can run well. Throw a 3500 stall in it and it will feel like a different car. Then if you are still unsatisfied with the performance you might consider a cam change.Even if you choose to put a smaller cam in it, the convertor will be a big boost.Should be an easy 13 sec car with street tires,12s with slicks. BUT, before you spend any real money, make sure what you have now is tuned properly.
Re: Are 3.91's enough gear? [Re: demon440] #384941
07/24/09 10:11 PM
07/24/09 10:11 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I think you should finish one car before you
tear apart another.
Don't you have 2 or 3 projects going on right now?
Or you could sell me your Demon.
Oh, that hurt
Yeah, I have two in bare metal and one in primer...
Re: Are 3.91's enough gear? [Re: jbc426] #384942
07/24/09 10:15 PM
07/24/09 10:15 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
What is your compression ratio? If your tune is good, the right converter and cam will do wonders with 3.54's.
What do you have the timing set at, initial and total? What do your plugs look like? You can easily change the cam and lifters with the motor in the car without removing the intake. You can always contact Dave over at Hughes Engines and talk to him about your set-up and see what he recommends.
Compression is stock (advertised 10.0:1) with the heads shaved .030". Not sure what actual would be...
I think timing is ~18 initial 35 total (or close to it) on FBO advise.
Re: Are 3.91's enough gear? [Re: Mr.Yuck] #384943
07/24/09 10:20 PM
07/24/09 10:20 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
284/484 MP cam <--- that be your problem... and if you have a carterbrock carb. 3.91's and more conver will help. or you can swap the cam out for something a more street friendly. I'd do the cam...much easier and cheaper.
I guess everyone's different but I would rather change a converter and rear end than a cam.
I hate cracking the motor open (nicely painted, etc) and I love the lope of the cam. The sound is the best part of the car.
Re: Are 3.91's enough gear? [Re: Mr.Yuck] #384944
07/24/09 10:21 PM
07/24/09 10:21 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
You could also get a shorter tire 26" a 275/50/15 They are a little wider i think about a 1 inch off the top of my head.
it would be a real easy way to see how your car likes a higher gear and free if you could borrow a set.
a 26" tire on a B-body would look silllllllly.
But it would be a good way to see how it would run with lower gears.
Re: Are 3.91's enough gear? [Re: VITC_GTX] #384945
07/24/09 11:00 PM
07/24/09 11:00 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I think a convertor would be the best fix. Lower gears aren't necessary and that cam would like more stall. That's assuming the tuneup is right.
Sheldon
Re: Are 3.91's enough gear? [Re: VITC_GTX] #384946
07/24/09 11:14 PM
07/24/09 11:14 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
The 484 cam is bigger than most think, you need more compression. If you want more low end power, cut the heads and install the cam at 106*.
Fix the motor first, then tune the converter and gear to it if needed.
Re: Are 3.91's enough gear? [Re: VITC_GTX] #384947
07/24/09 11:26 PM
07/24/09 11:26 PM
MNobody Offline
MNobody  Offline
I had l-60-14's on my 69 Charger, it didn't look bad
Re: Are 3.91's enough gear? [Re: VITC_GTX] #384948
07/25/09 12:08 AM
07/25/09 12:08 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
We rebuilt a '69 GTX 440 to stock specs,except used a 484 Mopar cam.Stock Carter AVS carb,iron intake and exhaust manifolds,906 heads unported-stock valves,only a .030 overbore.2-1/2 exhaust through Dynomax turbo mufflers.Auto 727 with a custom converter,mild stall.Initially it ran the stock 3.23 gear,then 4.10 gear.The GTX ran a 13.9 with the 4.10 gear,in drive shifts at 6200 RPM,never ran it with the 3.23.Tires are BFG 295/50/15's on 10" Weld wheels.The car has A/C and a choppy idle,but ok with the air on.It runs good with the 4.10's,but I always wanted to try it with a 3.55,the 3.23 gave it awesome top end and highway passing power though.I have tuned many stock or near stock 440's and think a 3.55 gear is perfect for an all around driver.The cam as installed may be your low end problem,you could try to advance the cam timing by 4*.BTW the 484 cam in the GTX will shred the tires!(I may have the gears backwards for the dragstip time,it may have been with the 3.23's)I'll check,it is a friends car,and the times were in the early '90's.
RT
Re: Are 3.91's enough gear? [Re: RTSrunner] #384949
07/25/09 01:00 AM
07/25/09 01:00 AM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
It's the cam, or you need more compression.. which do you want to fix? The 440 can handle the .484 but needs real 10:1 not Morpar magic wanna be factory maybe 9:1 that you have... I'd swap the cam
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: Are 3.91's enough gear? [Re: VITC_GTX] #384950
07/25/09 01:16 AM
07/25/09 01:16 AM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Re: Are 3.91's enough gear? [Re: forphorty] #384951
07/25/09 02:25 AM
07/25/09 02:25 AM
Grand Rapids, MI
11secondC Offline
11secondC  Offline
Grand Rapids, MI
1967 VIP 4400 lbs w/driver = 14.17@97, 2.08 60', worn out stock bottem end '62 413, 484 cam, 452's, 750 Carter + RPM, 1.75" headers, 2400 stall, 3.55's, 26" BFG's and it would boil those anywhere in first gear...
Re: Are 3.91's enough gear? [Re: 11secondC] #384952
07/25/09 08:53 AM
07/25/09 08:53 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
rather do a convert and rear than a cam??? come on over you can pull my trans and put n a 3k convert for me and I'll do your cam...lol
Really the 484 while some claim in runs well in a low comprssion non-geared car would be suprised how uch better their car would run w/ the right cam in it. Just because you can do a burn out doesn't mean the car is running it's best. If you are careful and clean as you go the engine won't get all nasty. A cam swap is probably your cheapest and best way to go. If you want to keep the 484 you'll need a 3k convert, 3.91's, headers, at least 2.5 exhaust, and probably nothing smaller than a 750DP carb. Also try advancing your timing to 38* @ 2200. Un-hook the vac advance.
Coming soon!!!!
Re: Are 3.91's enough gear? [Re: RTSrunner] #384953
07/25/09 08:58 AM
07/25/09 08:58 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
RT
I ran the sumit 488 cam in a 67 coronet w/ a basic cast piston (maybe 9:1) 440. stock 906 heads, headers, RPM intake 750DP, 175K convert (2800) car ran consistant 12.90 @ 104. It had the 484 in it when I got it and 3.55's. what a dog. it could barley run 14.0's IMO for a 440 powered B-body that's too slow.
Coming soon!!!!
Re: Are 3.91's enough gear? [Re: VITC_GTX] #384954
07/25/09 05:24 PM
07/25/09 05:24 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
with 10in 3500 convertor ,12s with 3.55s isnt hard to do . 99.9 percent of performance engines want more convertor than what you have now. Keep in mind that a STOCK 440 magnum has a torque peak that occurs at 3200 rpm. I feel that the biggest thing holding you back enginewise may be the manifolds. A set of small headers(1 3/4 primary) will boost the power from the bottom to the top. I forgot what carb you have, but a 750dp works great on mild 440s.
Page 2 of 3 1 2 3
